1553D-125.000KWVDTL
1553D-125.000KWVDTL
    HCI(杭晶)
    SMD5032_6P
    低抖动,差分有源,封装:5032,6P,频率:125.000MHz,输出方式:LVDS,工作电压:2.5-3.3V,常温频差:±10ppm,工作温度:-40℃~+85℃,频率稳定度:±15ppm
1553D-125.000KWVDTL 数据手册
O OSCILLATOR UNIT WITH LVDS OUTPUT IN SMD 5.0X3.2MM S C I L L A T O R U 1553D N I T CERAMIC SEAM SEAL PACKAGE. PRODUCT FEATURES PRODUCT PHOTO (NOT IN SCALE)  Small dimensions 5.0x3.2x1.3 with 6 solder pads.  Highly reliable seam sealed ceramic package.  Wide frequency range.  Low jitter and phase noise.  RoHS compliant, LEAD-FREE and HALOGEN-FREE. APPLICATIONS  High speed communication  Telecom equipment  Handheld equipment PRODUCT SPECIFICATIONS 1553D PARAMETER Nominal frequency range CONDITIONS / REMARKS 10 ~ 1500MHz Fund., Overtone or PLL Supply voltage 1.8V / 2.5V / 3.3V Supply current 100mA Frequency stability ±25ppm / ±50ppm Other option possible Maximum, Fund mode lower ICC / ±100ppm –40 to +85°C or –55 to 125°C Operating temperature range Output waveform and load LVDS / 100Ω See note below. Other options available. RL between outputs Output voltage level HIGH 1.40V Typical Output voltage level LOW 1.10V Typical Rise and Fall times 1.5ns @ 20~80~20%VCC Symmetry (duty cycle) 45~55% Phase Jitter RMS @ outputs cross point
1553D-125.000KWVDTL 价格&库存
很抱歉,暂时无法提供与“1553D-125.000KWVDTL”相匹配的价格&库存,您可以联系我们找货
