TM3F1GUAI
TM3F1GUAI
    TM(天微)
    LGA-8(6x8)
    SD NAND闪存是一种用于低功耗应用的嵌入式存储解决方案。SD NAND由NAND闪存和采用LGA 8封装的高性能控制器组成。NAND区域需要3.3V电源电压(VCC)。SD NAND闪存基于先进的...
TM3F1GUAI 数据手册
SD NAND Product TM3FxxxUXX 1 Description SD NAND Flash is an embedded storage solution for low-power application.The SD NAND consists of the NAND flash and the high-performance controller with the LGA 8 package. 3.3V supply voltage (VCC) is required for the NAND area.The SD NAND Flash is based on an advance 8-pin interface (clock, command, Data*4, power and ground). The SD NAND Flash is fully compliant with SD2.0/SD3.0 interface and operation is similar to SD card. 2 Features  Advance     Advanced dynamic ECC engine to improve reliability Copyrights Protection Mechanism--Complying with highest security of SDMI standard Low power consumption, with the standby energy saving management mode automatically High-speed Flash Controller inside  Interface     Support clock frequencies 50MHz/208Mhz Complies to SD specifications version 2.x/3.x with 1-I/O and 4-I/O Supports SPI Mode Support UHS-I (SDR50, SDR104, DDR50)  Power Supply and Consumption  Voltage range: 2.7V ~ 3.6V  Standby: 100uA (Typical)  Operating current: 40mA(Typical)  Temperature  Operation: -25OC to 85OC  Storage: -65OC to 150OC  Reliability  P/E cycles with ECC: 100K  MTBF: 1,000,000hours Note:The 1Gb-4Gb capacity only supports a clock of 50MHz and is an SD2.0 interface. 1 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 3 Block Architecture 2 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 4 Pin Description 4.1 Device Top View 4.2 Pin Definition Pin # 1 2 3 4 5 6 7 8 Note: Name DAT2 DAT3 CLK GND CMD DAT0 DAT1 VCC SD Mode Type Description I/O/PP Data Line (bit 2) I/O/PP Data Line (bit 3) I Clock S Supply Voltage Ground PP Command/Response I/O/PP Data Line (bit 0) I/O/PP Data Line (bit 1) S Supply Voltage Name RSV CS CLK GND DI DO RSV VCC SPI Mode Type Description — Reserved I Chip Select (neg true) I Clock S Supply Voltage Ground I Data In O/PP Data Out — Reserved S Supply Voltage  S: power supply; l: input; O: output using push-pull drivers; PP: I/O using push-pull drivers.  The extended DAT lines(DAT1-DAT3) are input on power up. They start to operate as DAT lines after SET_BUS_WIDTH command. The host shall keep its own DAT1-DAT3 lines in input mode, as well, while they are not used. It is defined so, in order to keep compatibility to MultiMediaCards.  After power up this line is input with 50KOhm pull-up (can be used for card detection or SPI mode selection). The pull-up should be disconnected by the user, during regular data transfer, with SET_CLR_CARD_DETECT(ACMD42)command. 3 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 5 SD Bus Mode Protocol The SD bus has six communication lines and three supply lines:  CMD: Command is bi-directional signal.  DAT0-3: Data lines are bi-directional signals.  CLK: Host clock signal  VCC: Power supply.  GND: Ground The following figure shows the bus topology with one host in SD Bus mode. 4 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 6 SPI Bus Mode Protocol The SPI mode consists of a secondary communication protocol that is offered by Flash-based SD Memory Cards. This mode is a subset of the SD Memory Card protocol, designed to communicate with a SPI channel, commonly found in Motorola's (and lately a few other vendors') micro controllers. The interface is selected during the first reset command after power up (CMD0) and cannot be changed once the part is powered on. The SPI standard defines the physical link only, and not the complete data transfer protocol. The SD Memory Card SPI implementation uses a subset of the SD Memory Card protocol and command set. The advantage of the SPI mode is the capability of using an off-the-shelf host, hence reducing the design-in effort to minimum. The disadvantage is the loss of performance of the SPI mode versus SD mode (e.g. Single data line and hardware CS signal per card). The commands and functions in SD mode defined after the Version 2.00 are not supported in SPI mode. The card may respond to the commands and functions even if the card is in SPI mode but host should not use them in SPI mode.  CS: Chip select signal from host to card.  CLK: Clock signal from host to card.  DataIn: Data signal from host to card.  DataOut: Card to host data signal. . 5 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 7 Card Initialize To initialize the SD NAND, follow the following procedure is recommended example. 1).Supply Voltage for initialization Host System can apply the Operating Voltage from initialization to the card. Apply more than 74 cycles of Dummy-clock to the SD card. 2).Select operation mode (SD mode or SPI mode) In case of SPI mode operation, host should drive 1 pin (CD/DAT3) of SD Card I/F to “Low” level. Then, issue CMD0. In case of SD mode operation, host should drive or detect 1 pin of SD Card I/F (Pull up register of 1 pin is pull up to “High” normally) Card maintain selected operation mode except re-issue of CMD0 or power on below is SD mode initialization procedure. 3).Send the ACMD41 with Arg = 0 and identify the operating voltage range of the Card. 4).Apply the indicated operating voltage to the card. Reissue ACMD41 with apply voltage storing and repeat ACMD41 until the busy bit is cleared. (Bit 31 Busy = 1) If response time out occurred, host can recognize not SD Card. 5).Issue the CMD2 and get the Card ID (CID). 6).Issue the CMD3 and get the RCA. (RCA value is randomly changed by access, not equal zero) 7).Issue the CMD7 and move to the transfer state. If necessary, Host may issue the ACMD42 and disabled the pull up resistor for Card detect. 8).Issue the ACMD13 and poll the Card status as SD Memory Card.Check SD_CARD_TYPE value. If significant 8 bits are “all zero”, that means SD Card. If it is not, stop initialization. 9).Issue CMD7 and move to standby state. Issue CMD9 and get CSD. Issue CMD10 and get CID. 10).Back to the Transfer state with CMD7. 11).Issue ACMD6 and choose the appropriate bus-width. Then the Host can access the Data between the SD card as a storage device. 6 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX SPI Mode Initialization Flow 7 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX Normal SD initial flow 8 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 8 Function Description The sector size of the SD NAND Flash is 512-byte which is the same as that in an IDE magnetic disk drive. To write or read a sectors, the host computer software simply issues a Read or Write command to the SD NAND Flash. 8.1 ECC TITAN SD NAND Flash provides the internal ECC which can protect user data without other controlling sequence. ECC could use the spare area in NAND FLASH memory and the occupied size is determined by the +ECC protected abilities. The ECC default setting is enabled after device power up. 8.2 Bad Block Manage The device occasionally contains bad blocks. Please read one word of first page of first spare in each block. TITAN makes sure that every invalid block has data at this word. If the data of the word is “0”, define the block as a bad block. 8.3 Automatic Sleep Mode TITAN SD NAND Flash provides automatic entrance and exit from sleep mode. If no further commands are received within 5msec, chip would enter sleep mode. The host does not have to take any action for this to occur. TITANSD NAND Flash provide ultra-low power consumption during sleep mode (around 100uA) and suitable for IoT application. 8.4 Wear Leveling Wear-leveling is an intrinsic part of the Erase Pooling functionality of SD using NAND memory. The Wear Level command is supported as a NOP operation to maintain backward compatibility with existing software utilities. 9 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 9 Registers Six registers are defined within the card interface: OCR, CID, CSD, RCA, DSR and SCR. These can be accessed only by corresponding commands. The OCR, CID, CSD and SCR registers carry the card/content specific information, while the RCA and DSR registers are configuration registers storing actual configuration parameters Register OCR CID CSD RCA DSR SCR SD Status Width 32 128 128 16 16 64 512 Comment Operation Conditions Register Card IDentification Card-Specific Data Relative Card Address Driver Stage Register SD CARD Configuration Register Status Bits and Card Features 9.1 OCR Register The 32-bit operation conditions register stores the VDD voltage profile. Additionally, this register includes status information bits. One status bit is set if the power up procedure has been finished. This register includes another status bit indicating the capacity status after set power up status bit. Bit Position 0-3 4 5 6 7 8 9 10 11 12 13 14 15 OCR Fields Definition Bit Position 16 17 18 19 20 21 22 23 24(1) 25-29 30 31 Reserved Reserved Reserved Reserved Reserved for low voltage range Reserved Reserved Reserved Reserved Reserved Reserved Reserved 2.7 ~ 2.8 OCR Fields Definition 2.8 ~ 2.9 2.9 ~ 3.0 3.0 ~ 3.1 3.1 ~ 3.2 3.2 ~ 3.3 3.3 ~ 3.4 3.4 ~ 3.5 3.5 ~ 3.6 Switching to 1.8V Accepted (S18A) Reserved Card Capacity Status (CCS)(2) Card power up status bit (busy)(3) (1) Only UHS-I card supports this bit. (2) This bit is valid only when the card power up status bit is set. (3) This bit is set to LOW if the card has not finished the power up routine. 10 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 9.2 CID Register The CID register is 16 bytes long and contains a unique identification number as shown in below table. Name Width CID Slice Manufacture ID (MID) 8 [127:120] OEM/Application ID (OID) 16 [119:104] Product Name (PNM) Product Revision (PRV) Serial Number (PSN) Reserved 40 8 32 4 [103: 64] [63:56] [55:24] [23:20] Manufacture Data Code (MDT) 12 [19:8] CRC7 checksum (CRC) Not used, always 1 7 1 [7:1] [0:0] Comment The manufacturer IDs are controlled and assigned by the SD Card Association. Identifies the card OEM and/or the card contents. The OID is assigned by the 3C.* 5 ASCII characters long Two binary coded decimal digits 32 Bits unsigned integer Manufacture date–yym (offset from 2000) Calculated 11 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 9.3 CSD Register The Card-Specific Data register provides information regarding access to the device contents. The CSD defines the data format, error correction type, maximum data access time, whether the DSR register can be used, etc. The programmable part of the register (entries marked by W or E, see below) can be changed by CMD27. The types of the entries in the table below are coded as follows: R = readable, W(1) = writable once, W = multiple writable. Field CSD_STRUCTURE TAAC NSAC TRAN_SPEED CCC READ_BL_LEN READ_BL_PARTIAL WRITE_BLK_MISALIGN READ_BLK_MISALIGN DSR_IMP C_SIZE VDD_R_CURR_MIN VDD_R_CURR_MAX VDD_W_CURR_MIN VDD_W_CURR_MAX C_SIZE_MULT ERASE_BLK_EN SECTOR_SIZE WP_GRP_SIZE WP_GRP_ENABLE R2W_FACTOR WRITE_BL_LEN WRITE_BL_PARTIAL FILE_FORMAT_GRP COPY PERM_WRITE_PROTECT TMP_WRITE_PROTECT FILE_FORMAT CRC - Width 2 6 8 8 8 12 4 1 1 1 1 2 12 3 3 3 3 3 1 7 7 1 2 3 4 1 5 1 1 1 1 2 2 7 1 Value 00b 00 0000b xxh xxh 32h or 5Ah 01x110110101b xh 1b xb xb xb 00b xxxh xxxb xxxb xxxb xxxb xxxb xb xxxxxxxb xxxxxxxb xb 00b xxxb xxxxb xb 00000b xb xb xb xb xxb 00b xxxxxxxb 1b Type R R R R R R R R R R R R R R R R R R R R R R R R R R R R/W(1) R/W(1) R/W(1) R/W R/W(1) R/W R/W - CSD-slice [127:126] [125:120] [119:112] [111:104] [103:96] [95:84] [83:80] [79:79] [78:78] [77:77] [76:76] [75:74] [73:62] [61:59] [58:56] [55:53] [52:50] [49:47] [46:46] [45:39] [38:32] [31:31] [30:29] [28:26] [25:22] [21:21] [20:16] [15:15] [14:14] [13:13] [12:12] [11:10] [9:8] [7:1] [0:0] 12 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 9.4 RCA Register The writable 16-bit relative card address register carries the device address that is published by the device during the identification. This address is used for the addressed host-device communication after the identification procedure. The default value of the RCA register is 0x0000. The value 0x0000 is reserved to set all cards into the Stand-by State with CMD7 9.5 DSR Register The 16-bit driver stage register is described in detail in Chapter 6.5. It can be optionally used to improve the bus performance for extended operating conditions (depending on parameters like bus length, transfer rate or number of devices). The CSD register carries the information about the DSR register usage. The default value of the DSR register is 0x404. 9.6 SCR Register In addition to the CSD register, there is another configuration register named SD CARD Configuration Register (SCR). SCR provides information on the SD Memory Device's special features that were configured into the given device. The size of SCR register is 64 bits. This register shall be set in the factory by the SD Memory Device manufacturer. The following table describes the SCR register content Field SCR_STRUCTURE SD_SPEC DATA_STAT_AFTER_ERASE SD_SECURITY SD_BUS_WIDTHS SD_SPEC3 CMD_SUPPORT - Width 4 4 1 3 4 1 13 14 32 Type R R R R R R R R CSD-slice [63:60] [59:56] [55:55] [54:52] [51:48] [47] [46:34] [33:32] [31:0] 13 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product 10 Electronic characteristic 10.1 Absolute Maximum Ratings Parameter Storage Temperature Ambient Operation Temperature Applied Input/Output Voltage 10.2 DC Characteristics Parameters Supply Voltage (VCC) Input Leakage Current Output Leakage Current Operation Current (Read 50MHz)(32Gb) Operation Current (Write 50MHz)(32Gb) Standby Current Value -65OC ~ 150OC -40OC ~ 85OC 0V ~ VCC*1.1 Min 2.7 ----------- TM3FxxxUXX Typical 3.3 ----30 30 100 Max 3.6 5 5 ------- UNIT V uA uA mA mA uA 14 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 11 Reference Design Note: RDAT and RCMD(10K~100kΩ) are pull-up resistors protecting the CMD and the DAT lines against bus floating when SD NAND is in a high-impedance mode. The host shall pull-up all DAT0-3 lines by RDAT, even if the host uses the SD NAND as 1-bit mode only in SD mode. It is recommended to have 2.2uF capacitance on VCC. RCLK reference 0~120 Ω. 15 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 12 Part Information TM 3F xxx U X X TITAN I:-40℃~85℃ K:-40℃~105℃ J:-40℃~125℃ A:A version 3F:SD NAND Flash 01G:1Gb 02G:2Gb 04G:4Gb 16G:16Gb 32G:32Gb 64G:64Gb 256:256Gb 512:512Gb U:3.3V Product Description: Part Number Capacity Sequential Read Sequential Write Package TM3F01GUAI 1Gb(128MB) 15MB/S 5MB/S LGA8-6*8 TM3F02GUAI 2Gb(256MB) 15MB/S 5MB/S LGA8-6*8 TM3F04GUAI 4Gb(512MB) 17MB/S 10MB/S LGA8-6*8 TM3F16GUAI 16Gb(2GB) 22MB/S 8MB/S LGA8-6.6*8 TM3F32GUAI 32Gb(4GB) 70MB/S 15MB/S LGA8-6.6*8 Note: Different testing environments can lead to differences in read and write speeds. 16 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX 13 Package LGA8-6*8 Top View Side View Bottom View Dimensions Item D E A A1 b L e Unit mm mm mm mm mm mm mm 8.10 6.10 0.80 0.05 0.85 1.05 Spec (8.00) (6.00) (0.75) (0.02) (0.80) (1.00) 7.90 5.90 0.70 0.00 0.75 0.95 1.27BSC 17 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX LGA8-6.6*8 1 8 4 5 8 1 5 Top View 4 Side View Bottom View Dimensions D E D1 E1 A A1 A2 b L e mm mm mm mm mm mm mm mm mm mm 8.10 6.70 6.10 3.90 0.80 0.27 0.05 0.85 1.05 (8.00) (6.60) (6.00) (3.80) (0.75) (0.25) (0.02) (0.80) (1.00) 7.90 6.50 5.90 3.70 0.70 0.23 0.00 0.75 0.95 1.27BSC 18 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX LGA-9*10 1 8 4 5 8 1 4 5 Top View Side View Bottom View Dimensions Item D E D1 E1 A A1 A2 b L e h Unit mm mm mm mm mm mm mm mm mm mm mm 10.10 9.10 6.10 3.90 0.80 0.27 0.05 0.85 1.05 (10.00) (9.00) (6.00) (3.80) (0.75) (0.25) (0.02) (0.80) (1.00) 9.90 8.90 5.90 3.70 0.70 0.23 0.00 0.75 0.95 Spec 1.27BSC 1.0REF 19 www.titanmec.com ©Titan Micro Electronics V1.5 SD NAND Product TM3FxxxUXX LGA-9*12.5 1 8 4 5 Top View Side View Bottom View Dimensions Item D E D1 E1 A A1 aaa bbb eee fff SE SE1 SD e Unit mm mm mm mm mm mm mm mm mm mm mm mm mm mm 9.10 12.60 0.10 0.10 0.15 0.05 5.67BS 3.425B 0.635B 1.27BS 0.85 0.75 C SC SC C Spec (9.00) (12.50) 8.90 12.40 3.91 11.45 0.80 0.27 (3.81) (11.35) (0.75) (0.25) 3.71 11.25 0.70 0.23 L b mm mm 0.90 0.80 0.80 0.70 20 www.titanmec.com ©Titan Micro Electronics V1.5
TM3F1GUAI 价格&库存
很抱歉,暂时无法提供与“TM3F1GUAI”相匹配的价格&库存,您可以联系我们找货
TM3F1GUAI
    • 5+19.50000
    库存:5
