TCS9819
Ultra-small Package High-precision Voltage Detector With delay Circuit
General Description
Features
TCS9819 Series is a series of high-precision voltage
Highly accuracy: ±1%
detectors with a built-in delay time generator of fixed
Low power consumption:TYP 0.9uA (VDD=3V)
time developed using NMOS process. Internal oscillator
Detect
and counter timer can delay the release signal without
voltage
range : 1.0V~6.5V
in
increments
external parts. Detect voltage is extremely accurate with
Operating voltage range:0.7V~7.0V
minimal temperature drift. NMOS output configurations
Detect voltage temperature characteristics:
are available.
TYP±100ppm/℃
Output configuration: NMOS
Typical Application
Package
Power monitor for portable equipment such as
3-pin SOT23、SOT23-3
notebook computers, digital still cameras, PDA,
4-pin DFN1.2*1.6-4
and cellular phones
5-pin SOT23-5
Constant voltage power monitor for cameras, video
6-pin DFN2*2-6
equipment and communication devices.
Power monitor for microcomputers and reset for
CPUs.
System battery life and charge voltage monitors
Typical Application Circuit
100K
VDD
DS
VOUT
VSS
Ver.1.0 May.31.2019 page 1
0.1V
TCS9819
Selection Guide
product series
Detect voltage
Delay time(DS low)
TCS9819-CM263
2.63V
50ms
SOT23
2.93V
50ms
SOT23-3
2.93V
50ms
SOT23
TCS9819-DD293
2.93V
50ms
DFN1.2*1.6-4
TCS9819-E308
3.08V
50ms
SOT23-5
TCS9819-DF14
1.4V
20ms
DFN2*2-6
TCS9819-E22
2.2V
50ms
SOT23-5
TCS9819-E40
4.0V
50ms
SOT23-5
TCS9819-E263
2.63V
50ms
SOT23-5
TCS9819-E293
2.93V
50ms
SOT23-5
TCS9819-C38
3.8V
50ms
SOT23-3
TCS9819B-C293
TCS9819-CM293
Ver.1.0 May.31.2019 page 2
Package
TCS9819
Pin Configuration
VDD
3
VDD 1
4
VDD
VOUT
5
4
6
VDD
NC 2
5
NC
3
4
VSS
3 VSS
VOUT 2
1
2
1
2
3
VSS
VOUT
DS
VSS
NC
SOT23/SOT23-3
VOUT 1
NC
DFN1.2*1.6-4
NC
SOT23-5
DFN2*2-6
Pin Assignment
PIN Number
Pin Name
SOT23/SOT23-3
DFN1.2*1.6-4
SOT23-5
DFN2*2-6
1
3
2
4
VSS
2
2
4
1
VOUT
3
1
5
6
VDD
1
DS
4
3
2,3,5
NC
Block Diagram
Ver.1.0 May.31.2019 page 3
Function
Ground
Output Voltage
Input Voltage
ON/OFF switch for delay
time
TCS9819
Absolute Maximum Ratings
Parameter
Symbal
Ratings
Units
VDD Input Voltage
VDD
8
V
Output Current
IOUT
50
mA
VOUT
Vss-0.3~ VDD +0.3
V
Output Voltage
NMOS
Continuous Total Power
Dissipation
Thermal
resistance(Junction to air)
SOT23-3
0.5
SOT23
0.4
DFN1.2*1.6-4
Pd
0.42
SOT23-5
0.6
DFN2*2-6
1.3
SOT23-3
250
SOT23
330
DFN1.2*1.6-4
θJA
300
SOT23-5
200
DFN2*2-6
95
W
℃/W
Operating Ambient Temperature
TOpr
-40~+85
Storage Temperature
Tstg
-55~+150
Maximum junction temperature
TJ
-40~+150
Soldering temperature and time
Tsolder
260℃, 10s
MM
400
V
HBM
4000
V
ESD
Ver.1.0 May.31.2019 page 4
TCS9819
Electrical Characteristics (-VDET(S)=1.0V to 6.5V±1% ,Ta=25OC , unless otherwise noted)
Parameter
Detect
Symbol
Conditions
-VDET(S)
-VDET
Voltage
Hysteresis
Range
Supply
Current1
×0.99
VHYS
0.03
ISS1
(below 2.5V)
Current2
VDD=5V
ISS2
(2.5V-4.5V)
VDD=7V
(4.5V-6.5V)
Output
IOUT
VDS=0.5V
Current
N-ch
VDD=0.7V
Operating
voltage
VDD
A /C Series
VDD=-VDET+1V
B Series
DS low
Td1
Delay time
Td2
Temperature
characteristics
VDET
Ta ( VDET)
VDD=-VDET+1V
DS high
∆Ta= -40℃ ~ 85℃
Typ
-VDET(S)
Max.
-VDET(S)
×1.01
Units
Test
circuit
V
1
0.06
0.1
V
0.6
1.0
uA
2
0.9
1.5
1.4
2.8
uA
2
1.8
3.6
0.01
0.16
mA
3
0.7
7
V
1
32.5
50
72.5
ms
1
13
ms
1
25
50
75
us
4
±100
±350
ppm/℃
1
VDD=2V
VDD=3V
Supply
Min.
Note: 1、-VDET(S) :Specified Detection Voltage value
2、-VDET :Actual Detection Voltage value
3、Release Voltage:+VDET=-VDET+VHYS
Ver.1.0 May.31.2019 page 5
TCS9819
Test Circuits:
1.
2.
3.
4.
Functional Description
1.
Basic Operation: NMOS Output (Active Low)
1-1. When the power supply voltage (VDD) is higher than the release voltage (+VDET), the Nch transistor is OFF to
provide VDD (high) at the output. Since the Nch transistor N1 in Figure 1 is OFF, the comparator input voltage
is
(RB RC )VDD
R A RB R C
1-2. When the VDD goes below +VDET, the output provides the VDD level, as long as VDD remains above the
detection voltage (–VDET).
When the VDD falls below –VDET (point A in Figure 2), the Nch transistor
becomes ON, the VSS level appears at the output. At this time the Nch transistor N1 in Figure 1 becomes ON,
the comparator input voltage is changed to
RB VDD
R A RB
1-3. When the VDD falls below the minimum operating voltage, the output becomes undefined, or goes to VDD when
Ver.1.0 May.31.2019 page 6
TCS9819
the output is pulled up to VDD.
1-4. The VSS level appears when VDD rises above the minimum operating voltage. The VSS level still appears
even when VDD surpasses the –VDET, as long as it does not exceed the release voltage +VDET.
1-5. When VDD rises above +VDET (point B in Figure 2), the Nch transistor becomes OFF to provide VDD at the
output. The VDD at the OUT pin is delayed for Td due to the delay circuit.
2.
Delay Circuit
2-1. Delay Time
The delay circuit delays the output signal from the time at which the power voltage (VDD) exceeds the
release voltage (+VDET) when VDD is turned on. The output signal is not delayed when the VDD goes below
the detection voltage (–VDET). (Refer to Figure 2.) The delay time (tD) is a fixed value that is determined by a
built-in oscillation circuit and counter.
2-2. DS Pin (ON/OFF Switch Pin for Delay Time)
The DS pin should be connected to Low or High. When the DS pin is High, the output delay time becomes
short since the output signal is taken from the middle of counter circuit (Refer to Figure 3).
Ver.1.0 May.31.2019 page 7
TCS9819
Directions for use
1、 Please use this IC within the stated maximum ratings. Operation beyond these limits may cause degrading or
permanent damage to the device.
2、 When a resistor is connected between the VDD pin and the input with NMOS output configurations, oscillation
may occur as a result of voltage drops at RIN if load current(IOUT) exists.(refer to the Oscillation Description(1)
below)
3、 When a resistor is connected between the VDD pin and the input with NMOS output configurations, oscillation
may occur as a result of through current at the time of voltage release even if load current(IOUT) does not exist.
(refer to the Oscillation Description(2) below)
4、 With a resistor connected between the VDD and the input, detect and release voltage will rise as a result of the
IC’s
5、 supply current flowing through the VDD pin.
6、 In order to stabilize the IC’s operations, please ensure that VDD pin’s input frequency’s rise and fall times are
more than several u Sec/V.
1、 Output current oscillation with the NMOS output configuration
When the voltage applied at IN rises, release operations commence and the detector’s output voltage increase.
Load current(IOUT) will flow at RL. Because a voltage drop(RIN*IOUT) is produces at the RIN resistor, located
between the input(IN) and the VDD pin. The load current will flow via the IC’s pin. The voltage drop will also lead to
a fall in the voltage level at the VDD pin. When the VDD pin voltage level falls below the detect voltage level, detect
operations will commence. Fllowing detect operations, load current flow will cease and since voltage drop at RIN
will disapper, the voltage level at the VDD pin will rise and release operations will begin over again. Oscillation
may occur with this “release-detect-release” repetition. Further, this condition will also appear via means of a
similar mechanism during detect operations.
2、 Oscillation as a result of through current
Since the TCS9819 series are NMOS IC’s, through current will flow when the IC’s internal circuit switching
operates(during release and detect operations). Consequently, oscillation is liable to occur as a result of drops in
voltage at the through current’s resistor (RIN) during release voltage operations.(refer to diagram 2) since
hysteresis exists during detect operations, oscillation is unlikely to occur.
Ver.1.0 May.31.2019 page 8
TCS9819
Type Characteristics
1、Supply current vs. Ambient temperature
VDD=5V,-VDET=2.63V
VDD=2.5V,-VDET=2.63V
Iss VS.TEMP
1.2
2.7
2.4
2.1
1.8
1.5
1.2
0.9
0.6
0.3
1
Iss(uA)
Iss(uA)
Iss VS.TEMP
0.8
0.6
0.4
0.2
-16 10
40
50
60
70
80
90 100 110 120
40
TEMP(℃)
VDET(V)
Iss(uA)
2
1.5
1
0.5
2
2.5
3
3.5
4
4.5
5
5.5
6
6.5
7
7.5
2.72
2.7
2.68
2.66
2.64
2.62
2.6
2.58
2.56
2.54
-16
10
Iout(N) VS. VDD
12
T=-15℃
Iout(mA)
10
T=23℃
T=85℃
6
4
2
0.7
1
1.2
40
50
60
70
TEMP(℃)
4、 Output current vs. Input voltage
N-ch VDS=0.5V,-VDET=2.63V
0.2
90 100 110 120
+VDET
-VDET
VDD(V)
8
80
VDET VS TEMP
2.5
1
70
3、Detect, Release voltage vs. Ambient temperature
-VDET=2.63V
Iss VS VDD
0.5
60
TEMP(℃)
2、Supply current vs. Input voltage
-VDET=2.63V (T=25℃)
1.7
2.2
2.5
VDD(V)
Ver.1.0 May.31.2019 page 9
80
90 100 110 120
TCS9819
Package Information
Package Type:SOT23-3
DIM
Millimeters
Inches
Min
Max
Min
Max
A
1.05
1.45
0.0413
0.0571
A1
0.0000
0.0059
A2
0.9
1.3
0.0354
0.0512
A3
0.6
0.7
0.0236
0.0276
b
0.25
0.5
0.0098
0.0197
c
0.1
0.25
0.0039
0.0098
D
2.8
3.1
0.1102
0.1220
E
2.6
3.1
0.1023
0.1220
E1
1.5
1.8
0.0591
0.0709
e
L
0.95(TYP)
0.25
L1
θ
c1
0.0374(TYP)
0.6
0.0098
0.59(TYP)
0.0232(TYP)
8°
0.2(TYP)
Ver.1.0 May.31.2019 page 10
0.0000
8°
0.0079(TYP)
TCS9819
Package Type:SOT23
DIM
Millimeters
Inches
Min
Max
Min
Max
A
0.9
1.15
0.0354
0.0453
A1
0.0000
0.0055
A2
0.9
1.05
0.0354
0.0413
b
0.28
0.52
0.0110
0.0205
c
0.07
0.23
0.0028
0.0091
D
2.8
3.0
0.1102
0.1181
e1
1.8
2.0
0.0709
0.0787
E
1.2
1.4
0.0472
0.0551
E1
2.2
2.6
0.0866
0.1024
e
0.95(TYP)
0.0374(TYP)
L
0.55(TYP)
0.0217(TYP)
L1
0.25
0.55
0.0098
0.0217
θ
8°
0.0000
8°
c1
0.25(TYP)
Ver.1.0 May.31.2019 page 11
0.0098(TYP)
TCS9819
Package Type:DFN1.2*1.6-4
DIM
Millimeters
Inches
Min
Max
Min
Max
A
0.5
0.6
0.0197
0.0236
A1
A3
0.152 (TYP)
0.006 (TYP)
D
1.5
1.7
0.0591
0.0669
E
1.1
1.3
0.0433
0.0512
D1
0.56
0.76
0.0221
0.0299
E1
0.7
0.9
0.0276
0.0355
b
0.25
0.35
0.0098
0.0138
b1
0.175
0.275
0.0069
0.0108
e
L
k
0.6 (TYP)
0.15
0.0236 (TYP)
0.25
0.2 (TYP)
Ver.1.0 May.31.2019 page 12
0.0059
0.0098
0.0079 (TYP)
TCS9819
Package Type:SOT23-5
DIM
Millimeters
Inches
Min
Max
Min
Max
A
1.05
1.45
0.0413
0.0571
A1
0.0000
0.0059
A2
0.9
1.3
0.0354
0.0512
A3
0.6
0.7
0.0236
0.0276
b
0.25
0.5
0.0098
0.0197
c
0.1
0.23
0.0039
0.0091
D
2.82
3.05
0.1110
0.1201
e1
1.9(TYP)
0.0748(TYP)
E
2.6
3.05
0.1024
0.1201
E1
1.5
1.75
0.0512
0.0689
e
L
0.95(TYP)
0.25
L1
θ
c1
0.0374(TYP)
0.6
0.0098
0.59(TYP)
0.0232(TYP)
8°
0.2(TYP)
Ver.1.0 May.31.2019 page 13
0.0000
8°
0.0079(TYP)
TCS9819
Package Type:DFN2*2-6
DIM
Millimeters
Inches
Min
Max
Min
Max
A
0.7
0.8
0.0276
0.0315
A1
A2
0.203(TYP)
0.008(TYP)
b
0.18
0.4
0.0071
0.0157
D
1.9
2.1
0.0748
0.0827
E
1.9
2.1
0.0748
0.0827
E1
0.5
0.9
0.0197
0.0354
e
0.65(TYP)
0.0256(TYP)
L
0.25
0.426
0.0098
0.0168
K
0.2
一
0.0079
一
D1
1
1.45
0.0393
0.0571
Ver.1.0 May.31.2019 page 14
很抱歉,暂时无法提供与“TCS9819-CM293”相匹配的价格&库存,您可以联系我们找货
