ABS205 THRU ABS210
ABS 2.0 AMP Plastic-Encapsulate Bridge Rectifier
ABS Plastic-Encapsulate Bridge Rectifier
Features
Reverse Voltage
50-1000 V
Forward Current
2.0 Ampere
•Ideal for printed circuit board
•Small size, simple installation
•High surge current capability
•Reliable low cost construction utilizing molded plastic technique
•High temperature soldering guaranteed: 260/10 seconds at 5lbs., (2.3kg) tension
Applications
ABS
General purpose 1 phase Bridgerectifier applications
Mechanical Data
•Case: ABS
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Function Diagram
XXXX
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
Maximum Repetitive Peak Reverse Voltage
VRRM
V
Maximum DC blocking Voltage
VDC
V
Device marking code
Maximum RMS Voltage
Maximum Average Forward Rectified Current
@60Hz sinewave, Resistance load,TL (Fig.1)
Non-repetitive Peak Forward Surge Current
@ t=8.3ms Half-sine wave
Rating for fusing (t=8.3ms, Ta=25 ℃ )
Storage temperature
Junction temperature
Typical Thermal Resistance
Rev:2.0
VRMS
UNIT ABS205
V
IF(AV)
A
I²t
A²S
Tj
IFSM
Tstg
RθJ-A
RθJ-L
ABS205
50
35
50
ABS21
ABS22
ABS24
ABS26
ABS28
ABS210
100
200
400
600
800
1000
ABS21
70
100
A
ABS22
140
200
ABS24
280
400
2.0
600
560
800
ABS210
700
1000
14.9
-55 ~ +150
℃ /W
75
Zhuhai Hongjiacheng Technology co., Ltd
420
ABS28
60
℃ /W
ABS26
-55 ~ +150
18
1 of 3
ABS205 THRU ABS210
Electrical Characteristics (Ta=25℃ Unless otherwise noted)
PARAMETER
Maximum instantaneous forward
voltage
TEST CONDITIONS
SYMBOL
VR=VDC,TA=25℃
IR1
4.0V DC,1MHz
CJ
IF=1.0A
Maximum DC reverse currentat
rated DC blocking voltage
VR=VDC,TA=100℃
Typical junction capacitance
VF
IR2
UNIT
V
ABS205 ABS21
ABS22
ABS24
1.0
500
pF
25
60
AVERAGERECTIFIELDOUTPUTCURRENT(A)
2.0
PEAKFORWARDSURGECURRENT(A)
40
1.2
30
0.8
60
80
100
LEADTEMPERATURE(℃)
120
140
INSTANTANEOUSREVERSECURRENT(μA)
INSTANTANEOUSFORWARDCURRENT(A)
10
Tj=125℃
10
0.1
1
0.1
0.4
100
NUMBEROFCYCLES
100
1.0
0.6
0.8
1.0
INSTANTANEOUSFORWARDVOLTAGE(V)
Fig.3 Typical Forward Voltage
Rev:2.0
1
Fig.2 Maximum Non-Repetitive Peak Forward Surge Current
Tj=25℃
Pulsewidth=300us
1%DutyCycle
10
Fig.1 Forward Current Derating Curve
0.01
8.3msSingleHalfSineWave
(JEDECMethod)
50
1.6
ABS28 ABS210
5.0
μA
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
2.4
ABS26
1.2
1.4
0.01
Tj=25℃
60
80
100
120
PERCENTOFRATEDPEAKREVERSEVOLTAGE(%)
140
Fig.4 Typical Reverse Characteristics
2 of 3
ABS205 THRU ABS210
Ordering Information
PACKAGE
PACKAGE CODE
ABS
R3
REEL(pcs)
Package Outline Dimensions (ABS)
5000
BOX(pcs)
CARTON(pcs)
10000
Symbol
A
A1
DELIVERY MODE
100000
Millimeters
Dimensions
Min.
Max.
0.2
1.25
13''
Min.
0.049
0.057
4.1
0.126
0.141
3.9
C
0.15
0.35
0.006
E
4.2
4.6
0.165
D
F
G
0.5
4.8
0.3
6.2
Max.
1.45
B
B1
Inches
0.8
5.1
0.8
7.0
0.008
0.02
0.031
0.014
0.197
0.201
0.181
0.012
0.031
0.244
0.275
Suggested Pad Layout
X
Symbol
Y
N
Rev:2.0
M
Millimeters
Dimensions
Inches
Min.
Max.
Min.
M
5.72
5.9
0.225
0.232
N
4.0
4.2
0.157
0.165
Y
1.0
1.2
0.039
0.047
X
0.9
1.1
0.035
0.043
Max.
3 of 3
很抱歉,暂时无法提供与“ABS210”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.15191
- 100+0.14211
- 500+0.13231
- 2000+0.11761
- 5000+0.11271
- 10000+0.10977
- 国内价格
- 20+0.23069
- 200+0.18231
- 600+0.15542
- 5000+0.13187
- 10000+0.11783
- 20000+0.11027
