GR Series
General Purpose Thick Film Chip Resistors
Version. H
FEATURE
Tiny and light with thick film technology
High reliability
RoHS complaint
Compatible with reflow and wave soldering type
MSL class:MSL 1
Applications
Home appliances
Telecommunications
Smart wears
Computer, notebook, workstation, tablet, and peripherals
Instruments and meters
etc.
MANUFACTURER PART NO.
For example:GR1206J100KT5G00-GR1206 ±5% 100KΩ T/R-5000
Series
Size
Tol.
Nominal Resistance Value
PKG
SPQ
Feature
TCR
2 codes
4 codes
1 code
2~5 codes
1 code
1 code
1 code
2 codes
GR
1206
J
100K
T
5
G
00
0R=Jumper(< 50mΩ)
1R①=1Ω
4R7=4.7Ω
4K7②=4.7KΩ
100K=100KΩ
4M7③=4.7MΩ
22M=22MΩ
T=T/R
4=4K
5=5K
A=10K
B=15K
C=20K
D=50K
E=60K
General Purpose
Thick Film Chip
Resistors
Note:
0105
0201
0402
0603
0805
1206
1210
1812
2010
2512
D=±0.5%
F=±1%
J=±5%
① R=Radix, 100 , Ω
④
② K=Kilo, 103, KΩ
④ T/R=Taping in Reel Package.
G=Std.
S=P.C.⑤
00=Refer to item
RELIABILITY.
③ M=Mega, 106, MΩ
⑤ P.C.=Personal and Customized.
CHARACTERISTICS
Resistance Value Range
Series
Rated Power
MWV①
MOV②
DWV③
Jumper
MRC④
Jumper
MOC⑤
±0.5%
±1%
±5%
Jumper
GR0105
1/32W
15V
30V
0.5A
1A
10Ω-10MΩ
1Ω-10MΩ
< 50mΩ
GR0201
1/20W
25V
50V
0.5A
1A
1Ω-10MΩ
1Ω-10MΩ
< 50mΩ
GR0402
1/16W
50V
100V
100V
1A
2A
1Ω-10MΩ
1Ω-22MΩ
1Ω-22MΩ
< 50mΩ
GR0603
1/10W
75V
150V
300V
1A
2A
1Ω-10MΩ
1Ω-22MΩ
1Ω-100MΩ
< 50mΩ
GR0805
1/8W
150V
300V
500V
2A
5A
1Ω-10MΩ
1Ω-22MΩ
1Ω-100MΩ
< 50mΩ
GR1206
1/4W
200V
400V
500V
2A
10A
1Ω-10MΩ
1Ω-22MΩ
1Ω-100MΩ
< 50mΩ
GR1210
1/2W
200V
500V
500V
2A
10A
1Ω-10MΩ
1Ω-22MΩ
1Ω-100MΩ
< 50mΩ
GR1812
3/4W
200V
500V
500V
2A
10A
1Ω-10MΩ
1Ω-22MΩ
1Ω-100MΩ
< 50mΩ
GR2010
3/4W
200V
500V
500V
2A
10A
1Ω-10MΩ
1Ω-22MΩ
1Ω-100MΩ
< 50mΩ
GR2512
1W
200V
500V
500V
2A
10A
1Ω-10MΩ
1Ω-22MΩ
1Ω-100MΩ
< 50mΩ
Note:
① MWV=Max. Working Voltage.
② MOV=Max. Overload Voltage.
④ MRC=Max. Rated Current
⑤ MOC=Max. Overload Current
③ DWV=Dielectric Withstanding Voltage
This document is subject to change without notice. The products described herein, and this document are subject to specific disclaimers,
set forth at GiantOhm official website, http://www.giantohm.com/download/cid/22.html
QA-SP-001
General Purpose Thick Film Chip Resistors - GR Series
Page 1 / 9
GR Series
Version. H
POWER DERATING CURVE
Operating temperature range:
0105 size: from -55℃ to +125℃; 0201~2512 size: from -55℃ to +155℃.
STRUCTURE GRAPH
RATED VOLTAGE
Resistors should have a Rated Voltage DC or AC corresponding to Rated Power which can be calculated
by formula as below.
The Rated Voltage of certain resistance value should be the calculated result or Max. Working Voltage of
product series whichever less.
Formula:
E=Rated voltage(V)
P=Rated power(W)
R=Nominal resistance(Ω)
E= P×R
DIMENSIONS
Unit: mm
Figure
Type
L
W
H
A
B
0105
0.40±0.02
0.20±0.02
0.13±0.02
0.10±0.03
0.10±0.03
0201
0.60±0.03
0.30±0.03
0.23±0.03
0.10±0.05
0.15±0.05
0402
1.00±0.10
0.50±0.05
0.35±0.05
0.20±0.10
0.25±0.10
0603
1.60±0.10
0.80±0.10
0.45±0.10
0.30±0.20
0.30±0.20
0805
2.00±0.15
1.25±0.15
0.55±0.10
0.40±0.20
0.40±0.20
1206
3.10±0.15
1.55±0.15
0.55±0.10
0.45±0.20
0.45±0.20
1210
3.10±0.10
2.60±0.20
0.55±0.10
0.50±0.25
0.50±0.20
1812
4.50±0.20
3.20±0.20
0.55±0.20
0.50±0.20
0.50±0.20
2010
5.00±0.10
2.50±0.20
0.55±0.10
0.60±0.25
0.50±0.20
2512
6.35±0.10
3.20±0.20
0.55±0.10
0.60±0.25
0.50±0.20
QA-SP-001
Page 2 / 9
GR Series
Version. H
RELIABILITY
Item
Test Method
(R2-R1)
TCR(PPM/℃)=
×106
R1×(T2-T1)
Temperature
Coefficient of
Resistance
(T.C.R.)
R1=Value in room temperature
R2=Value in test temperature -55℃ or +125℃
T1=Room temperature
T2=Test temperature -55℃ or +125℃
Reference: IEC 60115-1 6.2
Insulation
Resistance
Dielectric
Withstanding
Voltage
Short Time
Over Load
Intermittent
Overload
Resistance to
Solvent
Solderability
Resistance to
Soldering Heat
Thermal Shock
Solder Joint
Endurance Test
Resistance to
Dry Heat
Using the parallel clamp method: 100±15VDC voltage is applied between the
electrode and the substrate within 60 seconds. Test the insulation resistance
between the terminal and the back of the part.
Reference: IEC 60115-1 12.1.3.5
Apply an alternating current between the electrode and substrate, with the
effective value of the maximum overload voltage referring to the DWV
characteristics, and maintain the pressure for 60 ± 5 seconds.
Reference: IEC 60115-1 12.2.4
Apply 2.5 times of rated voltage or maximum overload voltage (whichever is
the smallest) for 5 seconds
Reference: IEC 60115-1 8.1.4.2
Put it in the thermostat, apply 2.5 times of rated voltage, 1 second ON, 25
seconds OFF, 10000+400
cycles, take it out and stand for 60 minutes, then
−0
measure the change rate of resistance value.
Reference: IEC 60115-1 8.4.4
Immerse in isopropanol solvent at room temperature (23±5℃) for 5min, wipe
10 times with a hard toothbrush, repeat 3 times, take out and blow dry for
examination
Reference: IEC 60115-1 11.3.2 method1
Pretreatment:
dry heat 155℃, 4H, after take out, stand at room temperature for 2 hours.
Test method B1:
Dip the resistance in a tin furnace at 245±5℃ for 5 seconds, then take it out
and observe the solder area under a microscope;
Method D: 260±5℃,T=30+5/-0s.
Reference: J-STD-002 & IEC 60115-1 11.1.4.3
Reflow test, time above 217 °C is 60s-150s, time above 250 ± 5°C is 30±5s.
Reference: IEC 60115-1 11.2.4.3& MIL-STD-202 Method 210
High and low temperature test is carried out according to the upper and lower
limits of the application temperature of the parts, the residence time of the
upper and lower limits of the temperature is 30min, and the temperature
conversion time is less than 30s, lasting 500 cycles
Reference: IEC 60115-1 10.1.4
The SMD resistance was welded to the test board and bent with the standard
pressure block. After standing for 60 sec. under the corresponding deformation
condition, the change rate of resistance value of the part was tested.
Size
0402, 0603, 0805 0105, 0201, 1206, 1210
1812, 2010, 2512
Depth 5mm
3mm
2mm
Reference: IEC 60115-1 9.8.4
Put it in an oven at 155±5℃ for 1000+48
−0 hrs., take it out and let it stand for
more than 1hr., then measure the change rate of resistance value
Reference: IEC 60115-1 7.3
Acceptable criterion
GR0105:
1Ω≤R<10Ω: -200~+600PPM/℃
10Ω≤R<100Ω:
±300PPM/℃
≥100Ω:
±200PPM/℃
GR0201:
1Ω≤R≤10Ω: -100~+350PPM/℃
>10Ω:
±200PPM/℃
GR0402~2512:
1Ω≤R≤10Ω: ±200PPM/°C
10 Ω<R≤10M: ±100PPM/°C
10M<R≤22MΩ: ±200PPM/°C
22M<R≤100MΩ: ±300PPM/°C
9
≥ 10 Ω
Test to confirm if the presence of
current or arc breakdown by
≥10uA
1% series:△R/R=±(1.0%+0.05Ω)
5% series:△R/R=±(2.0%+0.05Ω)
0105:△R/R=±(2.0%+0.05Ω)
Jumper:< 50mΩ
△R/R=±(5.0%+0.05Ω)
Jumper:< 50mΩ
No obvious damage, peeling,
swelling phenomenon
1. Solder coverage over 95%
2. No more than 5% of the partially
exposed substrate, non-wetted
plating or ceramic substrate part.
△R/R=±(1.0%+0.05Ω)
Jumper:< 50mΩ
△R/R=±(1.0%+0.05Ω)
Jumper:< 50mΩ
△R/R=±(1.0%+0.05Ω)
Jumper:< 50mΩ
5% series:△R/R=±(3.0%+0.05Ω)
0105:△R/R=±(3.0%+0.05Ω)
Jumper:< 50mΩ
QA-SP-001
Page 3 / 9
GR Series
Version. H
Item
Test Method
Place it in a constant temperature and humidity box with 40±2℃ and
90~96%RH and apply the voltage (IEC 60115-1 10.4 Table 22) for 1000 hrs.
Take it out and stand for 30 minutes before applying rated voltage for 1
minute, and then measure the change rate.
Reference: IEC 60115-1 10.4
Jumper:< 100mΩ
Put in an oven at 70±2℃, apply rated voltage, 90 min ON, 30 min OFF, 1000
hrs., take out and stand for more than 60 min, then measure the resistance
change rate.
Reference: IEC 60115-1 7.1
Jumper:< 100mΩ
Low
temperature
load test
-55℃, unpowered, 1 hr.: Rated voltage/current for 45 minutes, then
unpowered within 15 minutes, return to room temperature, take out and stand
for 24 hours, then measure the change rate of resistance value.
Reference: IEC 60115-1 10.2.4
Jumper:< 50mΩ
Shear force
test
Weld the part to the PCB. Apply the corresponding test stress from the side of
the part with the test terminal for 10s. Check the appearance of the welded end
of the part under the stress condition
Size 0201
0402
0603, 0805, 1206, 1210, 1812, 2010, 2512
Test force 2N
10N
18N
Reference: IEC 60115-1 9.7
Without visible damage.
Loading Life in
Moisture
Load Life
SOLDERING TEMPERATURE
Recommendation only. Please adjust it according to the actual application
Lead-free IR Reflow Soldering Profile
Lead-free Double-Wave Soldering Profile
Note:
The Max. Temp. is 260+5
−0 ℃ within 10 sec
Reference: J-STD-020D
Note:
Suit for ≥ 0603 size
Manual soldering in 350±10℃ within 3 sec.
SOLDERING PAD
Resistance value would be lower than nominal value because of joint with soldering material, so
designing circuit should adjust the pad size
Unit: mm
Type
A
B
C
0105
0.2
0.5
0.2
0201
0.3
1.0
0.4
0402
0.5
1.5
0.6
0603
0.8
2.1
0.9
0805
1.2
3.0
1.3
1206
2.2
4.2
1.6
1210
2.2
4.2
2.8
1812
3.1
5.9
3.0
2010
3.5
6.1
2.8
2512
3.8
8.0
3.5
QA-SP-001
Page 4 / 9
GR Series
Version. H
WORKING ENVIRONMENT
If user intends to use products in special environments or states (including but not limited to the following),
it is necessary to approve special characteristics and reliability for the following or other application
environments.
A.
High temperature, high moisture.
B.
Near the sea, or corrosive gas, such as Cl2, H2S, NH3, SO2 and NO2, etc.
C.
Unverified liquids, such as water, oil, chemical or organic solvent.
D.
Unverified resin or paint to cover products.
E.
Products should be washed with water soluble cleaner even if non cleaning flux.
STORAGE / CARRY CONDITIONS
A.
Temperature: 25±5℃
B.
Humidity: 60±15%RH
C.
Storage life: 0105/0201 size: 1 year; ≥0402 size: 2 years. FIFO.
D.
Please hold box correct orientation when storing and carrying. It is strictly prohibited to fall or squeeze
the box, otherwise the product electrode or body may be damaged.
TAPING SPECIFICATIONS
A. Taping drawing
Carrier Taping A
Carrier Taping B
Embossed Taping
B.
Taping Dimensions
Type or Size
Carrier
Taping
A
Carrier
Taping
B
unit: mm
A±0.2
B±0.2
C±0.05
E±0.1
F±0.05
G±0.1
W±0.2
T±0.1
2.0
∅D+0.1
−0
0105
0.24±0.05
0.45±0.05
1.5
1.75
3.5
4.0
8.0
0.40
0201
0.40±0.05
0.70±0.05
2.0
1.5
1.75
3.5
4.0
8.0
0.47
0402
0.67±0.1
1.17±0.1
2.0
1.5
1.75
3.5
4.0
8.0
0.47
0603
1.10
1.90
2.0
1.5
1.75
3.5
4.0
8.0
0.67
0805
1.65
2.40
2.0
1.5
1.75
3.5
4.0
8.0
0.81
1206
1.90
3.45
2.0
1.5
1.75
3.5
4.0
8.0
0.81
1210
2.85
3.50
2.0
1.5
1.75
3.5
4.0
8.0
0.81
QA-SP-001
Page 5 / 9
GR Series
Version. H
Type or Size
Embossed
Taping
F±0.05
G±0.1
W±0.2
T±0.1
1.50
∅D+0.25
−0
E±0.1
2.00
∅D+0.1
−0
1.50
1.75
5.50
4.00
12.00
1.00
4.80
2.00
1.50
1.50
1.75
5.50
4.00
12.00
1.00
6.70
2.00
1.50
1.50
1.75
5.50
4.00
12.00
1.00
A±0.2
B±0.2
C±0.05
2010
2.90
5.60
1812
3.50
2512
3.50
REEL SPECIFICATION
A. Reel drawing
B. Reel dimension
Type
0105
0201
0402
0603
0805
1206
1210
1812
2010
2512
SPQ PCS/Rl.
20,000
15,000
10,000
5,000
5,000
5,000
5,000
4,000
4,000
4,000
unit: mm
A±0.5
B±0.5
C±0.5
D±1
M±2
W±1
2.0
2.0
2.0
2.0
2.0
2.0
2.0
2.0
2.0
2.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
13.0
21.0
21.0
21.0
21.0
21.0
21.0
21.0
21.0
21.0
21.0
60.0
60.0
60.0
60.0
60.0
60.0
60.0
60.0
60.0
60.0
178.0
178.0
178.0
178.0
178.0
178.0
178.0
178.0
178.0
178.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
13.8
13.8
13.8
LABEL SPECIFICATION
A. Produce Label(Ref.)
B. Customer Label(Ref.)
QA-SP-001
Page 6 / 9
GR Series
Version. H
PACKING BOX
A. Packing Type
Taping in reel / Bulk in plastic bag.
B.
Inner box
The inner box has several capacities hold 1 reel, 2 reels, 3 reels, 4 reels, 5 reels and 10 reels.
C. Out box
The out box has two capacities hold 6- or 8-pieces inner box.
NOTE OF COVER TAPE PEEL OFF
A. Figure of cover tape peel off.
B.
Please keep peeling speed under 300mm per minute.
C. Please keep the angle between cover tape and direction of unreeling narrower than 10 degree.
D. There is limit of adhesive force between cover tape and carrier tape or embossed tape shown as following
table.
Size of chip resistors
0105, 0201
0402
0603 and above
Adhesive force limit
6~30gf
10~40gf
10~70gf
QA-SP-001
Page 7 / 9
GR Series
Version. H
LEGAL DISCLAIMER
GiantOhm and its distributors or agents (hereinafter referred to as GiantOhm) shall not bear any
responsibility for any error, inaccuracy or incompleteness contained in any product related information
(including but not limited to product specifications, data, pictures, and charts). GiantOhm may change, revise, or
improve product related information at any time without prior notice.
GiantOhm makes no commitment, guarantee for the suitability of its products for special purposes or the
continuous production of any of its products. To the maximum extent permitted by law, GiantOhm does not
assume any of the following responsibilities:
A.
All liabilities arising from the application or use of any GiantOhm’s products.
B.
All liabilities, including but not limited to the loss of profits or direct damage, indirect damage, special
damage, punitive damage, derivative damage, or incidental damage caused by or related to
C.
All implied warranties, including fitness for a particular purpose, non-infringement, and
merchantability.
GiantOhm defines this product as a general consumer electronic purpose, which is not applicable to any
medical lifesaving or life-sustaining equipment, nor to any application that may cause casualties in case of
failure of GiantOhm’s products.
All technical suggestions on product application provided by GiantOhm are provided free of charge.
GiantOhm assumes no obligation and responsibility for adopting such technical suggestions and available
results, and all risks of adopting such suggestions shall be borne by the buyer. All risks and responsibilities
arising from the buyer's use of GiantOhm’s products in combination with other materials or raw materials, or in
any combination in its manufacturing process, shall be borne by the buyer, regardless of any oral or written
technical instructions, suggestions or other requirements given by GiantOhm for the use of the products.
The information provided above is only to explain the product specifications. If the product is not changed,
GiantOhm has all the rights to modify the above contents without prior notice, and the product change will be
notified to the customer by ECN.
QA-SP-001
Page 8 / 9
GR Series
Version. H
VERSION HISTORY
Version
Date
Change Item(s)
Description
A
2022/05/25
First version
B
2022/10/31
Reliability
Updated test items, test methods and acceptable criterion.
C
2023/01/31
Characteristics
0402~2512 size, Resistance Value range extended to 22MΩ
D
2023/02/03
Full
Add 1812 size
E
2023/04/27
Full
Add 0105 size
0603~2512 size, Resistance Value range extended to 100MΩ
F
2023/07/21
Reliability
Updated test items, test methods.
G
2023/12/26
Full
Add Packing Specifications.
Full
Add Jumper Description in MPN
Add Jumper test acceptable criterion.
Add Moisture sensitivity level description.
H
2024/05/13
QA-SP-001
Page 9 / 9
