R40N
industrial relays of small dimensions
• High load 40 A • AC coils - of up to 220 V AC,
DC coils - of up to 110 V DC, insulation class F: 155 °C
• For PCB • Small dimensions, light weight
• High shock and vibration resistance
• High quality, long life
• Applications: for automobile, machine, electronic equipment,
air conditioner, household appliance
• Recognitions, certifications, directives: RoHS,
Number and type of contacts
Contact material
Rated / max. switching voltage
AC
DC
Min. switching voltage
Rated load
AC1
DC1
Motor load
acc. to UL 508
Rated current
Max. breaking capacity
AC1
DC1
Contact resistance
1 CO, 1 NO
AgSnO2, AgCdO ❶
240 V / 300 V
110 V / 110 V
10 V
1 CO: 40 A / 30 A (NO/NC) / 240 V AC
1 NO: 40 A / 240 V AC
1 CO: 40 A / 30 A (NO/NC) / 30 V DC
1 NO: 40 A / 30 V DC
1 CO: 2 HP / 1,5 HP
250 V AC, (NO/NC), single-phase motor
1 NO: 2 HP
250 V AC, single-phase motor
1 CO: 1,5 kW / 1,1 kW 250 V AC, (NO/NC), single-phase motor
1 NO: 1,5 kW
40 A
1 CO: 9 600 VA / 7 200 VA (NO/NC)
1 NO: 9 600 VA
1 CO: 1 200 W / 900 W (NO/NC)
1 NO: 1 200 W
≤ 30 mΩ
Rated voltage
50/60 Hz AC
DC
Must release voltage
Operating range of supply voltage
Must operate voltage
Rated power consumption
AC
DC
12, 24, 110, 120, 220 V
5, 12, 24, 48, 110 V
DC: ≥ 0,1 Un
see Tables 1, 2
≤ 0,75 Un
2,0 VA
0,9 W
Insulation rated voltage
Overvoltage category
Flammability class
Insulation resistance
Dielectric strength
• between coil and contacts
• contact clearance
500 V AC
II
V-0
> 1 000 MΩ
AC3 acc. to IEC 60947-4-1
Coil data
Insulation according to EN 60664-1
General data
4 000 V AC
1 500 V AC
Operating / release time (typical values)
Electrical life
• resistive AC1
1 200 cycles/hour
• resistive DC1
1 200 cycles/hour
Mechanical life (cykle)
Dimensions (L x W x H)
Weight
Ambient temperature
(non-condensation and/or icing)
• operating
Cover protection category
Environmental protection
Shock resistance
Vibration resistance
Solder bath temperature
Soldering time
UL 94
500 V DC, 60 s
type of insulation: reinforced
type of clearance: micro-disconnection
15 ms / 10 ms
105 1 CO: 40 A / 30 A (NO/NC), 240 V AC
105 1 CO: 40 A / 30 A (NO/NC), 30 V DC
107
32,5 x 27,6 x 20,5 mm
30 g
1 NO: 40 A, 240 V AC
1 NO: 40 A, 30 V DC
-55...+100 oC
IP 64 or IP 67
EN 60529
RTII or RTIII
EN 61810-7
20 g
1,5 mm DA (constant amplitude) 10...55 Hz
max. 260 oC
max. 5 s
The data in bold type relate to the standard versions of the relays.
❶ AgCdO contact material in electrical contacts is only for use in electrical
and electronic equipment (EEE) in compliance with directive RoHS2 2011/65/EU in restricted categories of EEE covered by this directive. Relpol S.A.
is not responsible for usage relays with AgCdO contact material in categories of EEE where it is prohibited by the directive RoHS2 2011/65/EU.
23.12.2020
Contact data
1
www.relpol.com.pl
Export Sales Department phone +48 68 47 90 832, 951 • e-mail: export@relpol.com.pl
R40N
Dimensions
Connection diagrams (pin side view)
12,5
14
2,4
12
27,6
5,3
A1
A2
11
1 CO
17,5
32,5
14
0,5
20,5
A1
4,2
A2
0,8
1,2
0,8
1,5
0,8
11
1 NO
1,2
Pinout (solder side view)
1 CO
15,4
2,54
2 × Ø 1,1
2,54
2,54
2,54
17,8
2,54
2,54
2 × Ø 1,1
2 × Ø 2,1
14
3 × Ø 2,1
14
17,8
3,8
7,7
3,8
15,4
1 NO
Mounting
PRECAUTIONS:
1. Ensure that the parameters of the product described in its specification provide a safety margin for the appropriate operation of the device or system and never use
the product in circumstances which exceed the parameters of the product. 2. Never touch any live parts of the device. 3. Ensure that the product has been connected
correctly. An incorrect connection may cause malfunction, excessive heating or risk of fire. 4. In case of any risk of any serious material loss or death or injuries
of humans or animals, the devices or systems shall be designed so to equip them with double safety system to guarantee their reliable operation.
23.12.2020
Relays R40N are designed for direct PCB mounting.
2
www.relpol.com.pl
R40N
Coil data - DC voltage version
Coil code
Table 1
Rated voltage
V DC
Coil resistance
at 20 °C
Ω
Coil operating range
V DC
Acceptable
resistance
min. (at 20 °C)
max. (at 20 °C)
1005
5
28
± 10%
3,8
6,5
1012
12
160
± 10%
9,0
15,6
1024
24
640
± 10%
18,0
31,2
1048
48
2 560
± 10%
36,0
62,4
1110
110
13 445
± 10%
82,5
143,0
Coil data - AC 50/60 Hz voltage version
Coil code
Rated voltage
V AC
Table 2
Coil resistance
at 20 °C
Ω
V AC 50 Hz
Acceptable
resistance
min. (at 20 °C)
max. (at 20 °C)
5012
12
27
± 10%
9,0
5024
24
120
± 10%
18,0
15,6
31,2
5110
110
2 360
± 10%
82,5
143,0
5120
120
3 040
± 10%
90,0
156,0
5220
220
13 490
± 10%
165,0
286,0
Ordering codes
Cover protection
category
Type
R 4 0 N —
Contact
material
Number and type
of contacts
Connection
mode
Coil code
Contact material
10 - AgCdO
30 - AgSnO2
see Tables 1, 2 page 3
11 - 1 CO
21 - 1 NO
2 - in cover, IP 64 version
8 - in cover, IP 67 version
Connection mode
5 - for PCB
R40N-3011-85-1012
R40N-1021-25-5024
relay R40N, for PCB, one changeover contact, contact material AgSnO2, coil voltage
12 V DC, in cover IP 67
relay R40N, for PCB, one normally open contact, contact material AgCdO, coil voltage
24 V AC 50/60 Hz, in cover IP 64
23.12.2020
Examples of ordering codes:
3
www.relpol.com.pl
