DATA SHEET
AUTOMOTIVE GRADE SURGE
CHIP RESISTORS
SR series
20%, 10%, 5% 1%, 0.5%
sizes 0201/0402/0603/0805/1206/1210/1218/2010/2512
Product specification – February 14, 2025 V.14
RoHS compliant & Halogen free
2
Chip Resistor Surface Mount
SR
SERIES
12
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes
SR0201 to SR2512 chip resistors
with lead-free terminations made by
thick film process.
Part number is identified by the series name, size, tolerance, packaging
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
Telecommunications
Power supplies
Car electronics
GLOBAL PART NUMBER
SR XXXX X X X XX XXXX L
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0201 / 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512
(2) TOLERANCE
D = ± 0.5%
FEATURES
AEC-Q200 qualified
Superior to RC series in pulse
withstanding voltage and surge
withstanding voltage.
MSL class: MSL 1
Halogen free epoxy
RoHS compliant
Products with lead-free
terminations meet RoHS
requirements
Pb-glass contained in electrodes,
resistor element and glass are
exempted by RoHS
Reduce environmentally
hazardous waste
High component and equipment
reliability
F = ± 1%
J = ± 5%
K = ± 10%
M = ± 20%
(3) PACKAGING TYPE
R = Paper taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
– = Based on spec.
(5) TAPING REEL & POWER
07 = 7 inch dia. Reel & Standard power
7W = 7 inch dia. Reel & 2 x standard power
13 = 13 inch dia. Reel
7T = 7 inch dia. Reel & 3 x standard power
47 = 7 inch dia. Reel & 4xstandard power
(6) RESISTANCE VALUE
1 Ω ≤ R ≤ 1M Ω
There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need
to mention the last zero after R/K/M, e.g.1K2, not 1K20.
Detailed coding rules of resistance are shown in the table of “Resistance rule of global
part number”.
(7) DEFAULT CODE
Letter L is the system default code for ordering only. (Note)
Resistance rule of global part
number
Resistance coding
Example
rule
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XXKX
(10 to 97.6 KΩ)
10K = 10,000 Ω
97K6= 97,600 Ω
XXXK
(100 KΩ)
O RDERING EXAMPLE
The ordering code for an SR0805
chip resistor, value 10 KΩ with
± 5% tolerance, supplied in 7-inch
tape reel is: SR0805JR-0710KL.
100K = 100,000 Ω
www.yageo.com
Feb. 14, 2025 V.14
SR
SERIES
3
12
MARKING
SR0201 / SR0402
No Marking
ynsc007
Fig. 1
SR1218
YNSC099-1
Fig. 2
E-24 series: 3 digits
First two digits for significant figure and 3rd digit for number of zeros
Value=10 KΩ
SR0603 / SR0805 / SR1206 / SR1210 / SR2010 / SR2512
YNSC001
Fig. 3
Value=10 KΩ
NOTE
For further marking information, please refer to data sheet “Chip resistors marking”.
TAPING REEL & POWER
Table 1
POWER, W (P70)
TYPE
CODING
07
0201 1/20
7W
7T
47
1/10
1/5
0402 1/16
1/8
1/5
0603 1/10
1/5
1/4
1/3
0805 1/8
1/4
1/3
1/2
1206 1/4
1/2
3/4
1
1210 1/2
1
1218 1
2010 3/4
1.5
1.25
2512 1
2
www.yageo.com
Feb. 14, 2025 V.14
SR
SERIES
4
12
CONSTRUCTION
The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added at each
end and connected by a resistive glaze. The resistive glaze is covered by a lead -free glass. The composition
of the glaze is adjusted to give the approximately required resistance value. The whole element is covered
by a protective overcoat. The top of overcoat is marked with the resistance value. Finally, the two external
terminations (Ni/matte tin) are added, as shown in Fig.4.
OUTLINES
For 2512 1%, 0.5%
marking layer
marking layer
overcoat
overcoat
protective glass
protective glass
resistive layer
resistive layer
inner electrode
termination (Ni/matte tin)
inner electrode
inner electrode
inner electrode
YNSC095-1
ceramic substrate
YNSC095
resistive layer
protective glass
overcoat
Fig. 4-1
Fig. 4-2
Chip resistor outlines
DIMENSIONS
Table 2
TYPE
L (mm)
W (mm)
H (mm)
I1 (mm)
I2 (mm)
SR0201
0.60± 0.03
0.30± 0.03
0.23± 0.03
0.12± 0.05
0.15± 0.05
SR0402
1.00± 0.05
0.50± 0.05
0.35± 0.05
0.20± 0.10
0.25± 0.10
SR0603
1.60± 0.10
0.80± 0.10
0.45± 0.10
0.25± 0.15
0.25± 0.15
SR0805
2.00± 0.10
1.25± 0.10
0.50± 0.10
0.35± 0.20
0.35± 0.20
SR1206
3.10± 0.10
1.60± 0.10
0.55± 0.10
0.45± 0.20
0.45± 0.20
SR1210
3.10± 0.10
2.60± 0.15
0.55± 0.10
0.45± 0.15
0.50± 0.20
SR1218
3.10± 0.10
4.60± 0.10
0.55± 0.10
0.45± 0.20
0.40± 0.20
SR2010
5.00± 0.10
2.50± 0.15
0.55± 0.10
0.55± 0.15
0.55± 0.20
SR2512
6.35± 0.10
3.10± 0.15
0.55± 0.10
0.60± 0.20
0.60± 0.20
SR0201/0402
For dimension, please refer to Table 1
SR0603/0805/1206/
1210/2010/2512
I1
SR1218
Side view for all type
I1
I1
W
W
Fig. 5 Chip resistor dimensions
H
W
I2
L
L
L
YNSC096_1
www.yageo.com
Feb. 14, 2025 V.14
SR
SERIES
5
12
ELECTRICAL CHARACTERISTICS
Table 3
TYPE
POWER
CHARACTERISTICS
Max.
Max.
Dielectric
RESISTANCE Operating Temperature
RANGE
Range Working Overload Withstanding
Voltage
Voltage
Voltage
1/20W
SR0201
1/10W
1Ω ≤ R < 10Ω
-100~+350 ppm°C
50 V
10Ω ≤ R ≤ 1MΩ
± 200 ppm°C
25 V
50 V
75 V
100 V
100 V
150V
300V
300V
500V
1000V
1000V
1/5W
Temperature
Coefficient of
Resistance
1/16W
SR0402
1/8W
1/5W
1/10W
SR0603
1/5W
1/4W
1/3W
SR0805
1/8 W
E24/E96 0.5%, 1%
E24 5%, 10%, 20%
1/4W
1Ω ≤ R ≤ 10MΩ
1/3W
for 0402, 0603, 0805,
1206, 2010
1/2W
1/4 W
SR1206
1/2W
3/4W
1Ω ≤ R ≤ 1MΩ
for 0201, 1210, 1218,
2512
–55 °C to +155 °C
10Ω ≤ R ≤ 10MΩ
± 100 ppm/ °C
500V
1000V
1000V 1Ω ≤ R < 10Ω
± 200 ppm/ °C
500V
1000V
1000V
200 V
400 V
500 V
200 V
400 V
500 V
500 V
1000 V
1000 V
1W
SR1210
SR1218
SR2010
SR2512
1/2W
1W
1W
1.5W
3/4W
1.25W
1W
2W
www.yageo.com
Feb. 14, 2025 V.14
SR
SERIES
6
12
FOOTPRINT AND SOLDERING PROFILES
Recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 4 Packing style and packaging quantity
PACKING STYLE
Paper taping reel (R)
Embossed taping reel (K)
REEL DIMENSION
SR0201/0402
SR0603/0805/1206
SR1210
SR1218/2010/2512
7" (178 mm)
10,000
5,000
5,000
13" (330 mm)
50,000
20,000
20,000
7" (178 mm)
4,000
NOTE
1. For paper/embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”.
RESISTANCE
FUNCTIONAL DESCRIPTION
RANGE
OPERATING TEMPERATURE RANGE
MRA632
Pmax
PT040–55 °C to +155 °C 100 m to 910 m
Range:
(%Prated)
2
± 200 ppm/°C
POWER RATING
100
PT060
Each
type rated power at 70 ±°C:
200 ppm/°C
3
SR0201:
1/20W, 1/10W, 1/5W
SR0402:
PT080 1/16W, 1/8W, 1/5W
50
200 ppm/°C
SR0603:
1/10W, 1/5W, 1/4W,±1/3W
5
SR0805: 1/8W,
1/4W,
1/3W,
100 MΩ
TO 910
MΩ 1/2W
PT120 1/4W, 1/2W, 3/4W, 1W
SR1206:
100 mΩ
0 > 100 mΩ
6
SR1210:
1/2W, 1W
55
155
SR1218: 1W, 1.5W
Tamb ( C)
PT201
± 100 ppm/°C
± 75 ppm/°C
SR2010: 3/4W, 1.25W
Fig. 6 Maximum dissipation (P max ) in percentage of rated power
SR2512: 1W, 2W
as a function of the operating ambient temperature (T amb)
PT251
± 100 ppm/°C
± 75 ppm/°C
R ATED VOLTAGE
2
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=
(P X R)
or max. working voltage whichever is less
Where
V = Continuous rated DC or AC (rms) working voltage (V)
P = Rated power (W)
R = Resistance value (Ω)
www.yageo.com
Feb. 14, 2025 V.14
SR
SERIES
7
12
Pulse load Behavior
Fig. 7-1 Pulse-Load behavior
Fig. 7-2 Pulse-Load behavior
www.yageo.com
Feb. 14, 2025 V.14
SR
SERIES
8
12
Pulse load Behavior
Fig. 7-3 Pulse-Load behavior
Peak Continuous Pulse Power (SR series J/K/M tol)
10,000.0
Permissible electric power (W)
1,000.0
100.0
10.0
2512
1218
2010
1210
1.0
1206
0805
0603
0.1
0402
0201
0.0
0.000001
0.00001
0.0001
0.001
0.01
0.1
1
Pulse duration(Sec)
Maximum permissible peak continuous pulse power as a function of pulse duration
Follow EN140401-802
Paverage ≤ P( amb)
Pulse-SR002
Fig. 7-4 Pulse-Load behavior
www.yageo.com
Feb. 14, 2025 V.14
SR
SERIES
9
12
TESTS AND REQUIREMENTS
Table 5 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
High Temperature
Exposure
AEC-Q200 Test 3
1,000 hours at TA = 155 °C, unpowered
± (2.0%+0.05Ω) for D/F tol
Moisture Resistance
MIL-STD-202 Method 106
Biased
Humidity
MIL-STD-202 Method 108
AEC-Q200 Test 7
MIL-STD-202 Method 103
± (3.0%+0.05Ω) for others
Each temperature / humidity cycle is defined at
8 hours, 3 cycles / 24 hours for 10d. with 25 °C
/ 65 °C 95% R.H, without steps 7a & 7b,
unpowered
± (0.5%+0.05Ω) for D/F tol
1,000 hours; 85 °C / 85% RH
10% of operating power
± (1.0%+0.05Ω) for D/F tol
± (2.0%+0.05Ω) for others
Measurement at 24± 4 hours after test
conclusion.
Operational Life
Resistance to
Soldering Heat
AEC-Q200 Test 8
1,000 hours at 125 °C, derated voltage applied
for 1.5 hours on, 0.5 hour off, still-air required
AEC-Q200 Test 15
Condition B, no pre-heat of samples
± (1.0%+0.05Ω)
MIL-STD-202 Method 210
Lead-free solder, 260± 5 °C, 10± 1 seconds
immersion time
No visible damage
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
Thermal Shock
MIL-STD-202 Method 107
-55/+125 °C
Number of cycles is 300. Devices mounted
± (1.0%+0.05Ω) for others
Maximum transfer time is 20 seconds.
Dwell time is 15 minutes. Air – Air
ESD
AEC-Q200 Test 17
Human Body Model,
AEC-Q200-002
1 pos. + 1 neg. discharges
± (3.0%+0.05Ω)
0201: 500V
0402/0603: 1KV
0805 and above: 2KV
Solderability
- Wetting
AEC-Q200 Test 18
Electrical Test not required Magnification 50X
J-STD-002
SMD conditions:
Well tinned (≥95% covered)
No visible damage
(a) Method B, aging 4 hours at 155 °C dry heat,
dipping at 235± 3 °C for 5± 0.5 seconds.
(b) Method B, steam aging 8 hours, dipping at
215± 3 °C for 5± 0.5 seconds.
(c) Method D, steam aging 8 hours, dipping at
260± 3 °C for 30± 0.5 seconds.
www.yageo.com
Feb. 14, 2025 V.14
TEST
Board Flex
SR
SERIES
TEST METHOD
PROCEDURE
REQUIREMENTS
AEC-Q200 Test 21
Chips mounted on a 100mm x 40mm glass
epoxy resin PCB (FR4)
± (1.0%+0.05Ω)
AEC-Q200-005
10
12
Bending for 0201/0402: 5 mm
0603/0805: 3 mm
1206 and above: 2 mm
Holding time: minimum 60 seconds
Temperature
Coefficient of
Resistance (T.C.R.)
MIL-STD-202 Method 304
At +25/–55 °C and +25/+125 °C
Refer to table 2
Formula:
R2–R1
T.C.R= ------------------------- × 106 (ppm/°C)
R1(t2S–t1)
Where
t1=+25 °C or specified room temperature
t2=–55 °C or +125 °C test temperature
R1=resistance at reference temperature in ohms
R2=resistance at test temperature in ohms
Short Time
Overload
IEC60115-1 8.1
2.5 times of rated voltage or maximum
overload voltage whichever is less for 5 sec
at room temperature
± (2.0%+0.05Ω)
www.yageo.com
Feb. 14, 2025 V.14
SR
SERIES
11
12
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 14
Feb. 14, 2025
- Extend resistance range of 0402,0603,0805,1206,2010 to 10Mohm.
Version 13
Jul. 23, 2024
- Upgrade the working voltage of 1206 and 1210 to 500V
Version 12
Apr. 23, 2024
- Add continuous pulse curve
Aug. 31, 2023
- Upgrade the working voltage of 2512 to 500V
Version 11
- Merge F/D tol
Add size 0201
Version 10
Upgrade the working voltage of 0402 to 75V
Aug. 02, 2022 -
Upgrade the working voltage of 0603 to 150V
Upgrade the working voltage of 0805 to 500V
I2 dimension updated, for size 1206, size 2010, size 2512
Version 9
Aug. 04, 2021
- Upgrade to Automotive Grade
Version 8
Jul. 22, 2019
- Update power rating
- Extend resistance range of 0402 ~ 2512 to 1Mohm,
Version 7
Sep. 27, 2018
- Tighten TCR of all sizes for 10Ω < R ≤ 1MΩ from ± 200 ppm/°C to
± 100 ppm/°C
- Add SR1210, SR1218, SR2010 7W (double power)
Version 6
Oct. 02, 2017
Version 5
Nov.11, 2016
Version 4
Sep. 01, 2015
Version 3
Jul. 31, 2015
Version 2
Jan. 06, 2014
Version 1
Mar 18, 2011
Version 0
Oct 19, 2004
- Add SR0402 7T (triple power), SR0805 47 (quadruple power),
SR2512 7W (double power)
- Update 7T power for 1206
- Update SR0603 Dielectric Withstanding Voltage to 150V
- Update 7T power for 0603/0805 & 7W for 1210
- Comply with AEC-Q200 standard
- Add SR0402/0603/1210
- Update electrical characteristic
- Change to dual brand datasheet that describes SR0805 to SR2512 with
RoHS compliant
- Define global part number
www.yageo.com
Feb. 14, 2025 V.14
SR
SERIES
12
12
LEGAL DISCLAIMER
YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any
errors, inaccuracies or incompleteness contained in any product related information, including but not limited
to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or
improvements to product related information at any time and without notice.
YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any
particular purpose or the continuing production of any of its products. To the maximum extent permitted by
law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii)
any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all
implied warranties, including warranties of fitness for a particular purpose, non -infringement and
merchantability.
YAGEO products are designed for general purpose applications under normal operation and usage conditions.
Please contact YAGEO for the applications listed below which require especially high reliability for the
prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace
equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster
prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly
public information network equipment, data-processing equipment , Medical devices, Military equipment, Power
generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and
Undersea equipment, or for any other application or use in which the failure of YAGEO products could result
in personal injury or death, or serious property damage. Particularly YAGEO Corporation and its affiliates
do not recommend the use of commercial or automotive grade products for high reliability
applications or manned space flight.
Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights
for revising this content without further notification, as long as products are unchanged. Any product change
will be announced by PCN.
www.yageo.com
Feb. 14, 2025 V.14
