NVMFS5C673NLWFAFT1G-HXY 数据手册
HXY
NVMFS5C673NLWFAFT1G
ELECTRONICS CO.,LTD
N-Channel Enhancement Mode MOSFET
HUAXUANYANG
Description
D
The NVMFS5C673NLWFAFT1G uses advanced trench
D
D
D
technology to provide excellent R DS(ON), low gate charge
S
and operation with gate voltages as low as 4.5V. This
S
S
G
device is suitable for use as a Battery protection or
G
S
in other Switching application.
S
"S
Pin 1
General Features
DFN5X6-8L
(TDSON-8-EP(5.1x5.9))
VDS = 60V ID = 65A
D
RDS(ON) < 11mΩ V GS=10V
Application
G !
Battery protection
S
N-Channel MOSFET
Load switch
Uninterruptible power supply
Package Marking and Ordering Information
Product ID
Pack
Brand
Qty(PCS)
NVMFS5C673NLWFAFT1G
DFN5X6-8L
HXY MOSFET
5000
Absolute Maximum Ratings (TC=25°C unless otherwise noted)
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
60
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V
65
A
ID@TC=70℃
49
A
IDM
Pulsed Drain Current2
180
A
EAS
Single Pulse Avalanche Energy3
56
mJ
PD@TC=25℃
Total Power Dissipation4
89
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
RθJA
Thermal Resistance Junction-Ambient 1
62
℃/W
Shenzhen HuaXuanYang Electronics CO.,LTD
www.hxymos.com
HXY
NVMFS5C673NLWFAFT1G
ELECTRONICS CO.,LTD
HUAXUANYANG
Electrical Characteristics (TJ=25°C unless otherwise specified)
Symbol
Parameter
Test Condition
Min.
Typ.
Max.
Units
Drain-Source Breakdown Voltage
VGS=0V, ID=250μA
60
V
Zero Gate Voltage Drain Current
VDS=60V, VGS=0V,
1.0
μA
Gate to Body Leakage Current
VDS=0V, VGS= ±20V
±100
nA
Gate Threshold Voltage
VDS=VGS, ID=250μA
1.0
1.6
2.5
V
Static Drain-Source on-Resistance
VGS=10V, ID=20A
8
11
note3
VGS=4.5V, ID=10A
14
pF
370
pF
pF
19
nC
4.8
nC
4.5
nC
4.9
ns
31
ns
23
ns
Turn-off Fall Time
8.7
ns
Maximum Continuous Drain to Source Diode Forward
Current
65
A
ISM
Maximum Pulsed Drain to Source Diode Forward Current
240
A
VSD
Voltage
1.4
V
34
ns
14
nC
V (BR)DSS
IDSS
IGSS
V GS(th)
RDS(on)
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Qgs
Total Gate Charge
Gate-Source Charge
Q gd
Gate-Drain(“Miller”) Charge
td(on)
tr
Turn-on Delay Time
td(off)
tf
Turn-off Delay Time
IS
Turn-on Rise Time
trr
Body Diode Reverse Recovery Time
Q rr
Charge
VDS=25V, VGS=0V,
f=1.0MHz
VDS=30V, ID=20A,
VGS=10V
V DD=30V, ID=20A,
RG=1.6Ω, VGS=10V
VGS=0V, IS=30A
TJ=25℃,
IF=20A,dI/dt=100A/μs
mΩ
Notes:1. Repetitive Rating: Pulse Width Limited by Maximum Junction Temperature
2. EAS condition: TJ=25℃, VDD=30V, VG=10V, RG=25Ω, L=0.5mH, IAS=12A
3. Pulse Test: Pulse Width≤300μs, Duty Cycle≤0.5%
www.hxymos.com
HXY
NVMFS5C673NLWFAFT1G
ELECTRONICS CO.,LTD
HUAXUANYANG
Typical Performance Characteristics
Figure 2: Typical Transfer Characteristics
Figure1: Output Characteristics
40
ID (A)
10V
ID (A)
30
4.5V
25
4V
30
TJ=125℃
15
VGS=3V
25℃
10
10
5
VDS(V)
2
3
4
5
1.6
2.4
3.2
4.0
Figure 4: Body Diode Characteristics
Figure 3:On-resistance vs. Drain Current
18
VGS(V)
IS(A)
RDS(ON) (mΩ)
1.0E+01
15
1.0E+00
VGS=4.5V
12
1.0E-01
9
1.0E-02
125℃
VGS=10V
6
1.0E-03
3
1.0E-04
ID(A)
40
Figure 5: Gate Charge Characteristics
10
8
1.0E-05
0.0
0.2
0.4
TJ=25℃
VSD(V)
0.6
0.8
1.0
Figure 6: Capacitance Characteristics
VGS(V)
C(pF)
VDS=30V
ID=30A
104
Ciss
6
4
103
Coss
102
Crss
2
Qg(nC)
40
50
60
VDS(V)
10
40
50
www.hxymos.com
HXY
NVMFS5C673NLWFAFT1G
ELECTRONICS CO.,LTD
HUAXUANYANG
Figure 7: Normalized Breakdown Voltage vs.
Figure 8: Normalized on Resistance vs.
RDS(on)
VBR(DSS)
2.5
1.3
1.2
2.0
1.1
1.5
1.0
1.0
0.9
Tj (℃)
-50
100
150
200
Figure 9: Maximum Safe Operating Area
Tj (℃)
-50
100
150
200
Figure 10: Maximum Continuous Drain Current
vs. Case Temperature
ID(A)
1000
0.5
-100
ID(A)
72
Limited by RDS(on)
60
10μs
100
48
100μs
1ms
10
36
10ms
100ms
24
DC
TC=25℃
Single pulse
1
0.1
0.1
12
VDS (V)
10
1
50
Tc (℃)
75
100
125
150
175
Figure.11: Maximum Effective
Transient Thermal Impedance, Junction-to-Case
101
ZthJ-C(℃/W)
100
10-1
PDM
D=0.5
t1
D=0.2
D=0.1
t2
D=0.05
D=0.02
D=0.01
Notes:
Single pulse 1.Duty factor D=t1/t2
2.Peak T J=PDM*ZthJC+TC
TP(s)
10-2
10-3 -6
10
10-5
10-4
10-3
10-2
10-1
100
101
www.hxymos.com
HXY
NVMFS5C673NLWFAFT1G
ELECTRONICS CO.,LTD
HUAXUANYANG
DFN5X6-8L(TDSON-8-EP(5.1x5.9)) Package Information
SYMBOL
A
A1
D
D1
B
B1
C
C1
C2
Ɵ1
L1
L2
L3
H
MM
MIN
4.95
4.82
5.98
5.67
0.9
3.95
0.35
8°
0.63
1.2
3.415
0.24
NOM
5
4.9
6
5.75
0.95
0.254REF
4
0.4
1.27TYP
10°
0.64
1.3
3.42
0.25
INCH
MAX
5.05
4.98
6.02
5.83
1
MIN
0.195
0.190
0.235
0.223
0.035
4.05
0.45
0.156
0.014
12°
0.65
1.4
3.425
0.26
8°
0.025
0.047
0.134
0.009
NOM
0.197
0.193
0.236
0.226
0.037
0.010REF
0.157
0.016
0.5TYP
10°
0.025
0.051
0.135
0.010
MAX
0.199
0.196
0.237
0.230
0.039
0.159
0.018
12°
0.026
0.055
0.135
0.010
www.hxymos.com
HXY
NVMFS5C673NLWFAFT1G
ELECTRONICS CO.,LTD
HUAXUANYANG
Attention
■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle
applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications
whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG
ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein
in such applications.
■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products
specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein.
■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance,
characteristics, and functions of the described products in the independent state, and are not guarantees of the performance,
characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and
states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the
■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with some probability. It is possible that these probabilistic failures could
give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other
property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures
include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design.
■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein
are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the
export license from the authorities concerned in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including
photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production.
HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding
its use or any infringements of intellectual property rights or other rights of third parties.
■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc.
When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use.
www.hxymos.com
