NUP4114HMR6T1G
NUP4114HMR6T1G
    HJKE(皓辰芯)
    SOT23-6
    ESD抑制器/TVS二极管 单向 5V 4.5A 60W SOT23-6
NUP4114HMR6T1G 数据手册
NUP4114HMR6T1G 4-Line Ultra Low Capacitance TVS Array WWW.HJKEIC.COM Features • Ultra low capacitance: 0.3pF typical (I/O to I/O) • Ultra low leakage: nA level • Operating voltage: 5V • Low clamping voltage • Up to four data lines and one power line protects • JEDEC SOT23-6 package • Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±20kV Contact discharge: ±15kV – IEC61000-4-5 (Lightning) 4.5A (8/20μs)  SOT-23-6 6 5 4 1 2 3 RoHS Compliant Mechanical Characteristics  Package: SOT23-6   Lead Finish: Matte Tin Case Material: “Green” Molding Compound.  Terminal Connections: See Diagram Below  Marking Information: See Below Circuit diagram P4HM Applications  USB 2.0 Power and Data lines protection  Digital Visual Interface (DVI)  Monitors and Flat Panel Displays   Video Graphic Cards Notebook and PC Computers P4HM = Device Marking Code Dot denotes Pin1 Marking (Top View) Ordering Information 1 Part Number Packaging Reel Size NUP4114HMR6T1G 3000/Tape & Reel 7 inch NUP4114HMR6T1G Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 60 W Peak Pulse Current (8/20µs) IPP 4.5 A ESD per IEC 61000−4−2 (Air) ±20 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range ±15 kV TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 5 V Any I/O pin to ground V IT = 1mA, any I/O pin to ground 0.5 µA VRWM = 5V, any I/O pin to ground 6 Test Condition Reverse Leakage Current IR Forward Voltage VF 1.0 1.2 V IF = 15mA, ground to pin 1,3,4,5,6 Clamping Voltage VC 9 12 V IPP= 1A (8 x 20µs pulse), any I/O pin to ground Clamping Voltage VC 12 15 V IPP= 4.5A (8 x 20µs pulse), any I/O pin to ground Junction Capacitance CJ 15 18 V IPP = 17A (8 x 20µs pulse), any Vcc pin 5 to ground Clamping Voltage VC 0.3 0.4 pF VR = 0V, f = 1MHz, any I/O pin to I/O pin Junction Capacitance CJ 0.6 0.8 pF VR = 0V, f = 1MHz, any I/O pin to ground Note 1: I/O pins are Pin 1, 3, 4 and 6. 2 NUP4114HMR6T1G Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Clamping Voltage vs. Peak Pulse Current Peak Pulse Power vs. Pulse Time TLP Curve Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 X 20μs Pulse Waveform 8 kV Contact per IEC61000−4−2 3 NUP4114HMR6T1G SOT23-6 Package Outline Drawing DIMENSIONS SYM MILLIMETERS MIN. A A1 A2 b c D E1 E e e1 L θ MAX. 0.090 1.450 0.000 0.150 0.090 1.300 0.250 0.500 0.100 0.200 2.800 3.100 1.500 1.750 2.650 3.000 0.950(BSC) 1.800 2.000 0.300 0.600 0° 8° INCHES MIN. 0.0035 0.057 0.000 0.006 0.035 0.051 0.010 0.020 0.004 0.008 0.110 0.122 0.060 0.069 0.104 0.120 0.037(BSC) 0.071 0.079 0.012 0.024 0° 8° Suggested Land Pattern X SYM C G C G P X Y Z Z Y P 4 DIMENSIONS MILLIMETERS 2.50 1.40 0.95 0.60 1.10 3.60 MAX. INCHES 0.098 0.055 0.037 0.024 0.043 0.141
NUP4114HMR6T1G 价格&库存
很抱歉,暂时无法提供与“NUP4114HMR6T1G”相匹配的价格&库存,您可以联系我们找货
