Hour Meters / Timers, electromechanical
DIN Formate Timers – H 57
Product features
• 7- or 8-digit hour meter
• High shock and impact resistance
• Without reset, small dimensions
• Large optical figures
• Protection IP 52, suitable for any mounting position
• UL-approval
Your benefit
• 5 years warranty* – high reliability means
your end product sells better
• Data retention if power is lost
• Long service life
Applications
general time counting, service intervals for measuring devices ( respiratory ventilators, oxygen
machines, dialysis machines), small appliances,
UV lamps, display panels in vehicles
RoHS
* subject to use in accordance with the technical data
Technical data:
Power consumption:
Rated voltages:
On time:
Display:
Accuracy:
Count mode:
Height of figures:
Colour of figures:
Ambient temperature:
Mounting position:
Protection:
Housing:
screw terminal for cable diameter up to 2.5 mm2
[1612.9 square inch] tightening torque max. 0.8 Nm
10 ... 30 V DC:
approx. 500 mW
100 ... 130 V DC:
approx. 750 mW
20 ... 30 V AC, 50 Hz:
approx. 0.3 VA
42 ... 48 V AC, 50 Hz:
approx. 0.25 VA
100 ... 130 V AC, 50 Hz:
approx. 0.6 VA
187 ... 264 V AC, 50 Hz:
approx. 1.2 VA
360 ... 440 V AC, 50 Hz:
approx. 1.65 VA
20...30/42...48/100...130/187...264/360...440 V AC,
50 or 60 Hz, 10...30/100...130 V DC
100 %
7 for AC 99999.99
8 for DC 999999.99
AC: Supply frequency + 30 ms
DC: < 0.003 % (24 h)
adding
4 mm [0.158“]
white and red on black
–15 ... +50°C [5 ... 122 °F]
any
up to IP 52, DIN 40 050 front side
plastic
Weight:
H 57: 48 g [1.673 oz]; AH 57: 84 g [2.963“]
base mount socket No. 48: 36 g [1.27“]
slip-on bezel 55
8 g [0.282“]
slip-on bezel 72
13 g [0.459“]
Operating indicator of the running time meter:
AC:
fast rotating wheel with red dashes
DC:
1/100 h display turns continuously by 1 digit in 36 s
Test voltage:
2000 V AC , 50 Hz for AC counters
Options:
further voltages on request
Counter with wire entry from behind, screw fixing from rear.
Art-No. 3.228.401.XXX.044
Colour of housing:
grey:
Art-No. 3.22X.400.XXX
Flat pin
0.8 x 6.3 mm [0.032 x 0.248“]
Welded cover
(IP 65 from front)
IP 65 version:
order code: 3.22X.XXX.XXX.422
Seals required between the counter and the bezel:
H 57:
N.511.018
H 57.55:
N.511.018 + N.511.017
H 57.72:
N.511.018 + N.511.016
(with the IP 65 version, the seal is included in the delivery)
Approvals:
UL for USA and Canada E128604
the version 360 ... 440 V AC
is not UL listed
H 57
69
1.9
Ø
48 [1.89]
1
50
45 [1.772]
7 [0.276]
28 [1.103]
Voltage
10 ... 30
20 ... 30
42 ... 48
100 ... 130
187 ... 264
360 ... 440
6/2009
Art-No. (AC), 50 Hz
Art-No. (AC), 60 Hz
3.220.401.071*
3.220.401.072
3.220.401.074*
3.220.401.075*
3.220.401.079
*standard stock model
3.220.401.081*
3.220.401.082
3.220.401.084*
3.220.401.085*
3.220.401.089
1 max. 9
3
45+0.6
[1.772+0.024]
3 Screw terminal
Art-No. (V DC)
3.220.401.351*
3.220.401.381
Further standard stock models:
3.220.401.075.422 187 ... 264 V AC,IP 65
3.220.401.351.422 10 ... 30 V DC,IP 65
www.kuebler.com
187
Timers
Electrical connection:
很抱歉,暂时无法提供与“3.220.401.351”相匹配的价格&库存,您可以联系我们找货
