GXTS03
GXTS03
    GXCAS(中科银河芯)
    DFN-8
    I2C、SMBus接口数字温度传感器
GXTS03 数据手册
GXTS03 GXCAS Technology High-Accuracy Digital Temperature Sensor IC DESCRIPTION The GXTS03 is GXCAS’s new high accuracy digital temperature sensor. Its functionality includes enhanced signal processing, two distinctive a n d u s e r selectable I2C addresses and communication speeds of up to 1 MHz. The DFN package has a footprint of 3 x 3 mm2 while keeping a height of 0.75 mm. This allows for integration of the GXTS03 into a great variety of applications. Additionally, the wide supply voltage range of 2.4 V to 5.5 V guarantees compatibility with a wide range of applications. FEATURES   Fully calibrated and linearized digital output  Wide supply voltage range, from 2.4 V to 5.5 V  I2C Interface with communication speeds up to 1MHz and two user selectable addresses  Typical accuracy of  0.3 °C from 0°C to +90°C  ±0.1°C Accuracy from 35°C to +45°C  Very fast start-up and measurement time PIN CONFIGURATIONS SDA 1 ADDR 2 ALERT 3 SCL 4 GXCAS TS03 2020XXX 8 GND 7 P 6 nRST 5 VDD Content 1 Sensor Performance.............................................2 2 Specifications .......................................................3 3 Pin Assignment ....................................................5 4 Operation and Communication.............................6 5 Packaging...........................................................12  Measures Temperatures from -40~125℃ 2ms  Converts Temperature to 16-Bit Digital Word in Thermometer Resolution is 16 Bits  8-Pin DFN package www.galaxy-cas.com 1 GXTS03 1 1.1 Sensor Performance Temperature Sensor Performance Parameter Accuracy tolerance Accuracy tolerance Condition Value Units typ., 35°C to 45°C 0.1 °C 0.3 0.24 0.12 0.06 0.015 -40 to 125 typ., 0°C to 90°C Resolution Specified Range Low Medium High Typ. - Response time 63% >1 Long Term Drift max
GXTS03 价格&库存
很抱歉,暂时无法提供与“GXTS03”相匹配的价格&库存,您可以联系我们找货
GXTS03
    • 1+3.60501
