TPT7487-SOBR
TPT7487-SOBR
    3PEAK(思瑞浦)
    WSOP-16
TPT7487-SOBR 数据手册
TPT7487/TPT7488 Isolated Full- and Half-Duplex RS485 Transceiver Features Applications • • Exceeds Requirements of EIA-485 Standard • • • • • Supply Voltage: 3.0 V ~ 5.5 V • • • • • • Latch-up Performance Exceeds 600 mA Hot Plug Circuitry - Tx and Rx Outputs Remain ThreeState During Power-up/Power-down Data Rate: 500-kbps Isolated RS485 • Up to 5-kV RMS Isolation Rating ±15-kV IEC 61000-4-2 Contact Discharge ±20-kV IEC 61000-4-2 Air Discharge Safety-Related Certifications: – – – 5000-VRMSIsolation Rating per UL 1577 Communication Infrastructure The TPT748x features a fail-safe receiver, which supports the output of the receiver to be logic high when the differential input (bus pin A/B) of the receiver is open, short, or idle. Bus-Pin Protection (Between Bus pins and GNDB) VDE Certification according to DIN VDE V 0884-17(IEC60747-17) Industrial Control The TPT7487 is a ±15-kV IEC61000 ESD protected, 3.0-V ~ 5.5-V isolated RS485 transceivers that meet the RS-485 and RS-422 standards for Half Duplex communication. The TPT7488 is isolated Full Duplex RS485. ±200-kV/μs typ Static CMTI, ±150-kV/μs typ Dynamic CMTI – Motor Drives Description Full Fail-safe Receiver (Open, Short, Terminated) – – Home Appliance Transmitters in this family deliver exceptional differential output voltages into the RS-485 required 54-Ω load. The 500-kbps device has very low bus currents, so they present a true “1/8 unit load” to the RS-485 bus. This allows up to 256 transceivers on the network without using repeaters. Receiver (Rx) inputs feature a “Full Fail-Safe” design, which ensures a logic-high Rx output if Rx inputs are floating, shorted, or on a terminated but undriven bus. CQC Certification per GB 4943.1 CSA, TUV, and CB Certifications The TPT748x is available in the WSOP16 package and is characterized from −40°C to +125°C. Functional Block Diagram VCCA VCCB VCCA RE VCCB RE A A R R R R B Isolation Capacitor B Isolation Capacitor Isolation Capacitor Isolation Capacitor Z D D D D Y Isolation Capacitor Isolation Capacitor Isolation Capacitor DE Isolation Capacitor DE GNDA www.3peak.com GNDB GNDA 1 / 20 GNDB CA202301115A1 TPT7487/TPT7488 Isolated Full- and Half-Duplex RS485 Transceiver Table of Contents Features................................................................................................................................................................1 Applications......................................................................................................................................................... 1 Description........................................................................................................................................................... 1 Functional Block Diagram...................................................................................................................................1 Revision History...................................................................................................................................................3 Pin Configuration and Functions....................................................................................................................... 4 Specifications.......................................................................................................................................................6 Absolute Maximum Ratings (1) .......................................................................................................................6 ESD, Electrostatic Discharge Protection........................................................................................................ 6 Recommended Operating Conditions............................................................................................................ 6 Thermal Information........................................................................................................................................7 Insulation Specifications................................................................................................................................. 7 Safety-Related Certifications.......................................................................................................................... 9 Electrical Characteristics.............................................................................................................................. 10 Electrical Characteristics (continued).......................................................................................................11 Switching Characteristics..............................................................................................................................12 Test Circuits and Waveforms........................................................................................................................ 13 Detailed Description.......................................................................................................................................... 15 Overview.......................................................................................................................................................15 Functional Block Diagram.............................................................................................................................15 Feature Description...................................................................................................................................... 16 Tape and Reel Information................................................................................................................................ 17 Package Outline Dimensions........................................................................................................................... 18 WSOP16.......................................................................................................................................................18 Order Information.............................................................................................................................................. 19 IMPORTANT NOTICE AND DISCLAIMER......................................................................................................... 20 www.3peak.com 2 / 20 CA202301115A1 TPT7487/TPT7488 Isolated Full- and Half-Duplex RS485 Transceiver Revision History Date Revision 2022-03-10 Rev.Pre.0 2022-09-08 Rev.A.0 Released Version 2023-11-15 Rev.A.1 Updated new format and EC table www.3peak.com Notes Initial Version 3 / 20 CA202301115A1 TPT7487/TPT7488 Isolated Full- and Half-Duplex RS485 Transceiver Pin Configuration and Functions TPT7487 WSOP16 Top View VCCA 1 16 VCCB GNDA 2 15 GNDB R 3 14 NC /RE 4 13 B DE 5 12 A D 6 11 NC NC 7 10 NC GNDA 8 9 GNDB Table 1. Pin Functions: TPT7487 Pin No. Name I/O 1 VCCA − Logic-side power supply 2 GNDA − Ground connection for VCCA 3 R O Receiver output 4 /RE I Receiver enable. This pin disables the receiver output when high or open and enables the receiver output when low. 5 DE I Driver enable. This pin enables the driver output when high and disables the driver output when low or open. 6 D I Driver input 7 NC − Not Connected 8 GNDA − Ground connection for VCCA 9 GNDB − Ground connection for VCCB 10 NC − Not Connected 11 NC − Not Connected 12 A I/O Transceiver non-inverting input or output (I/O) on the bus side 13 B I/O Transceiver inverting input or output (I/O) on the bus side 14 NC − Not Connected 15 GNDB − Ground connection for VCCB 16 VCCB − Transceiver-side power supply www.3peak.com Description 4 / 20 CA202301115A1 TPT7487/TPT7488 Isolated Full- and Half-Duplex RS485 Transceiver TPT7488 WSOP16 Top View VCCA 1 16 VCCB GNDA 2 15 GNDB R 3 14 A /RE 4 13 B DE 5 12 Z D 6 11 Y NC 7 10 NC GNDA 8 9 GNDB Table 2. Pin Functions: TPT7488 Pin No. Name I/O 1 VCCA — Logic-side power supply 2 GNDA — Ground connection for VCCA 3 R O Receiver output 4 /RE I Receiver enable. This pin disables the receiver output when high or open and enables the receiver output when low. 5 DE I Driver enable. This pin enables the driver output when high and disables the driver output when low or open. 6 D I Driver input 7 NC — Not Connected 8 GNDA — Ground connection for VCCA 9 GNDB — Ground connection for VCCB 10 NC — Not Connected 11 Y O Driver non-inverting output 12 Z O Driver inverting output 13 B I Receiver inverting input on the bus side 14 A I Receiver non-inverting input on the bus side 15 GNDB — Ground connection for VCCB 16 VCCB — Transceiver-side power supply www.3peak.com Description 5 / 20 CA202301115A1 TPT7487/TPT7488 Isolated Full- and Half-Duplex RS485 Transceiver Specifications Absolute Maximum Ratings (1) Parameter Min Max Unit VCC Supply Voltage, VCCA, VCCB −0.5 6 V VIO Voltage at Logic Pin: D, DE, /RE, R −0.5 6 V VBUS Voltage at Bus Pin: A, B −15 15 V TA Operating Temperature Range −40 125 °C TJ Maximum Junction Temperature −40 150 °C TS Storage Temperature Range −65 150 °C TLead Lead Temperature (Soldering, 10 sec) - 260 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. (2) This data was taken with the JEDEC low effective thermal conductivity test board. (3) This data was taken with the JEDEC standard multilayer test boards. ESD, Electrostatic Discharge Protection Parameter Condition Value Unit IEC-61000-4-2, Contact Discharge Bus pin to GNDB ±15 kV IEC-61000-4-2, Air-Gap Discharge Bus pin to GNDB ±20 kV Bus pin to GNDB ±18 kV All Pins except bus pin ±7 kV IEC HBM HBM, per ANSI/ESDA/JEDEC JS-001 (1) CDM CDM, per ANSI/ESDA/JEDEC JS-002 (2) All pins ±1.5 kV LU Latch up, per JESD78 All pins ±600 mA (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Recommended Operating Conditions Parameter Min Max Unit VCC Supply Voltage 3.0 5.5 V VI Input Voltage at any Bus Terminal −7 12 V VIH High-level Input Voltage (driver, driver enable, and receiver enable inputs) 2 VCC V VIL Low-level Input Voltage (driver, driver enable, and receiver enable inputs) 0 0.8 V VID Differential Input Voltage −7 12 V www.3peak.com 6 / 20 CA202301115A1 TPT7487/TPT7488 Isolated Full- and Half-Duplex RS485 Transceiver Parameter RL Differential Load Resistance Min Max Unit 54 - Ω Thermal Information Package Type θJA θJC Unit WSOP16 75 41 °C/W Insulation Specifications Parameter CLR External clearance CPG External creepage DTI DTC CTI Conditions WSOP16 Unit > 8.0 mm > 8.0 mm > 22 μm 0.8 mm > 600 V I - For Rated Mains Voltage ≤ 150 VRMS I-IV - For Rated Mains Voltage ≤ 300 VRMS I-IV - For Rated Mains Voltage ≤ 600 VRMS I-IV - For Rated Mains Voltage ≤ 1000 VRMS I-III - Climatic category 40/125/21 - Pollution degree 2 - AC voltage 1414 VPK Distance through the insulation Shortest terminal-to-terminal distance through air Value Shortest terminal-to-terminal distance across the package surface Minimum internal gap (internal clearance) Distance through the Minimum internal distance across the conductors Molding compound inside the package Comparative tracking index Material group Over-voltage category DIN V VDE V 0884-17 (1)(2) VIORM Maximum repetitive isolation voltage VIOWM Maximum working isolation voltage AC voltage; TDDB Test 1000 VRMS DC voltage 1414 VDC VIOTM Maximum transient isolation voltage VTEST = VIOTM, t = 60 s (qualification); VTEST = 1.2 x VIOTM, t = 1 s (100% production) 7070 VPK VIOSM Maximum surge isolation voltage (3) Test method per IEC 62368-1, 1.2/50 μs waveform, VTEST = 1.3 × VIOSM (qualification) 6500 VPK qpd Apparent charge Method a, After Input/Output safety test subgroup 2/3, Vini = VIOTM, tini = 60 s; Vpd(m) = 1.2 × VIORM, tm = 10 s ≤5 pC www.3peak.com 7 / 20 CA202301115A1 TPT7487/TPT7488 Isolated Full- and Half-Duplex RS485 Transceiver Parameter CIO Isolation capacitance Conditions Isolation resistance WSOP16 Method a, After environmental tests subgroup 1, Vini = VIOTM, tini = 60 s; Vpd(m) = 1.6 × VIORM, tm = 10 s ≤5 Method b1; At routine test (100% production) and preconditioning (type test), Vini = 1.2 x VIOTM, tini = 1 s; Vpd(m) = 1.875 × VIORM, tm = 1 s ≤5 VIO = 0.4 × sin (2πft), f = 1 MHz VIO = 500 V, T A= 25°C RIO Value VIO = 500 V, 100°C ≤ T A≤ 125°C VIO = 500 V at T S= 150°C Unit ~ 0.5 pF > 1012 Ω > 1011 Ω > 109 Ω UL 1577 VISO Withstanding isolation VTEST= VISO, t = 60 s(qualification); VTEST= 1.2 × VISO, t voltage = 1 s (100% production) 5000 VRMS (1) All pins on each side of the barrier are tied together creating a two-terminal device. (2) This coupler is suitable for safe electrical insulation only within the safety operating ratings. Compliance with the safety ratings shall be ensured by means of suitable protective circuits. (3) Testing must be carried out in oil. www.3peak.com 8 / 20 CA202301115A1 TPT7487/TPT7488 Isolated Full- and Half-Duplex RS485 Transceiver Safety-Related Certifications VDE UL Certified according Certified according to UL 1577 and to DIN VDE V CSA Component 0884-17 Acceptance Notice 5A TUV CQC CSA Certified according to EN IEC 62368-1 Certified according and EN IEC to GB 4943.1 61010-1 Certified CSA C22.2 No. 62368-1 Certified according and CAN/CSAto EN IEC 62368-1 C22.2 No. 60601-1 400Vrms basic insulation (SOP, QSOP) and 600V rms reinforced insulation (WSOP) working voltage per CSA C22.2 No. 62368-1:19 3rd, IEC 62368-1:2018 Ed. 3(in pollution degree 2, material group I) 2 MOPP (Means of Patient Protection) insulation requirements for 250Vrms (WSOP) in CAN/CSA-C22.2 No. 60601-1:14, IEC 60601-1:2005 + AMD1:2012 Basic insulation (WSOP) VIORM= 1414 VIOSM= 6500 (SOP, QSOP) VIORM= 637 VIOSM= 5980 (WSOP)Single protection, 5000Vrms (SOP, QSOP)Single protection, 3750Vrms 6400Vrms reinforced insulation (WSOP), 800Vrms maximum work voltage 4000Vrms basic insulation (SOP, QSOP), 400V rms maximum work voltage Certificate No. 40054570 Report Reference E524241 Customer Certificate No. Master contract: Number:2332359 CQC22001356658 302375 www.3peak.com CB Reinforced insulation (WSOP), Altitude
TPT7487-SOBR 价格&库存
很抱歉,暂时无法提供与“TPT7487-SOBR”相匹配的价格&库存,您可以联系我们找货
TPT7487-SOBR
    • 1+8.06540
    • 10+6.37000
    • 30+5.52720
    • 100+4.68440
    库存:100
    TPT7487-SOBR
    • 1+4.66710
    • 100+3.89160
    • 750+3.53910
    • 1500+3.38400
    库存:1653
    TPT7487-SOBR
    • 1500+14.153571500+1.82596
    库存:781
    TPT7487-SOBR
    • 1+24.786101+3.19766
    • 10+18.4957210+2.38614
    • 25+16.9240925+2.18338
    • 100+15.18928100+1.95957
    • 250+14.36314250+1.85299
    • 500+13.86497500+1.78872
    库存:781
    TPT7487-SOBR
    • 1+14.41150
    • 10+10.66050
    • 100+9.13760
    • 1000+7.61460
