TPV706SL1-SR
TPV706SL1-SR
    3PEAK(思瑞浦)
    SOP-8
    带掉电检测器的低压监控电路
TPV706SL1-SR 数据手册
TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Features Description • The TPV706 is a supervisory circuit to monitor power supply voltage levels and provides a power-on reset signal. • • • • • • • • • • Precision Low-Voltage Monitoring and Power-Fail Detector 200-ms (typical) Reset Timeout A watchdog monitor is provided, which is activated if the watchdog input doesn’t toggle within 1.6 sec. Manual Reset Input Independent Watchdog Timer Reset Output Stage A reset signal can be asserted by an external manual reset input. Push-pull Active-low Output (TPV706) Low Power Consumption: 4-μA In addition, there is a power-fail detector with a 1.25-V threshold, which can be used to monitor an additional power supply. Guaranteed Reset Output Valid to VCC = 1 V Power Supply Glitch Immunity The reset periods are fixed at 200-ms (typical). The TPV706 is available in an 8-pin SOP package and typically consumes only 4-μA, which is suitable for low-power and portable applications. Temperature Range: −40°C to 125°C SOP8 Package Applications • • • • • Microprocessor Systems Computers Controllers Intelligent Instruments Portable Equipment Typical Application Circuit 5V Vx VCC /PFO INT /RESET /RESET PFI TPV706 GND www.3peak.com WDI I/O /WDO I/O /MR I/O 1 / 16 Microprocessor GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Table of Contents Features................................................................................................................................................................1 Applications......................................................................................................................................................... 1 Description........................................................................................................................................................... 1 Typical Application Circuit..................................................................................................................................1 Product Family Table...........................................................................................................................................3 Revision History...................................................................................................................................................3 Pin Configuration and Functions....................................................................................................................... 4 Specifications.......................................................................................................................................................5 Absolute Maximum Ratings ...........................................................................................................................5 ESD, Electrostatic Discharge Protection........................................................................................................ 5 Thermal Information........................................................................................................................................5 Electrical Characteristics................................................................................................................................ 6 Typical Performance Characteristics.............................................................................................................. 8 Detailed Description.......................................................................................................................................... 10 Overview.......................................................................................................................................................10 Functional Block Diagram.............................................................................................................................10 Feature Description...................................................................................................................................... 10 Application and Implementation...................................................................................................................... 12 Application Information ................................................................................................................................ 12 Tape and Reel Information................................................................................................................................ 13 Package Outline Dimensions........................................................................................................................... 14 SOP8............................................................................................................................................................ 14 Order Information.............................................................................................................................................. 15 IMPORTANT NOTICE AND DISCLAIMER......................................................................................................... 16 www.3peak.com 2 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Product Family Table Order Number Threshold Voltage (VTH) Package Marking Package TPV706VL1-SR (1) 1.58 V6V SOP8 TPV706WL1-SR (1) 1.67 V6W SOP8 TPV706YL1-SR (1) 2.19 V6Y SOP8 (1) 2.32 V6Z SOP8 TPV706RL1-SR 2.63 V6R SOP8 TPV706SL1-SR 2.93 V6S SOP8 TPV706TL1-SR 3.08 V6T SOP8 TPV706ML1-SR 4.38 V6M SOP8 TPV706LL1-SR 4.63 V6L SOP8 TPV706ZL1-SR (1) For future products, contact the 3PEAK factory for more information and samples. Revision History Date Revision 2019-01-01 Rev.A.1 Initial version. 2019-05-28 Rev.A.2 Added WDI pulse interval spec. 2022-06-25 Rev.A.3 2022-08-29 Rev.A.4 Added WDI pulse interval spec. 2023-08-15 Rev.A.5 Added package tape and reel information, and updated datasheet format. 2024-07-09 Rev.A.6 Corrected typo in order information, corrected typo in typical application circuit. www.3peak.com Notes Updated note for MR input pulse width, update to latest datasheet format and add WDI to /WDO time information. 3 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Pin Configuration and Functions TPV706 SOP8 Package Top View MR 11 88 WDO VCC 22 77 RESET GND 33 66 WDI PFI 4 55 PFO Table 1. Pin Functions: TPV706 Pin I/O Description No. Name 1 MR I 2 VCC P Power supply voltage being monitored. 3 GND G Ground. This pin should be connected to ground reference. 4 PFI I 5 PFO O 6 7 8 www.3peak.com WDI RESET WDO Manual Reset Input. MR low asserts RESET pin. It features an internal pull-up current. Power fail input. When PFI is less than 1.25-V, PFO goes low. If unused, connect PFI to GND. Power fail output. It goes low when PFI is less than 1.25-V, otherwise stays high. I Watchdog Input. Generates a reset if the voltage on the pin remains low or high for the duration of the watchdog timeout. The timer is cleared if a logic transition occurs on this pin or if a reset is generated. Floating WDI disables the watchdog function. O Active-Low Reset Push-Pull Output Stage. Asserted whenever VCC is below the reset threshold or by a low signal on the MR input. It remains low for 200-ms after VCC goes above the reset threshold or MR goes from low to high. A watchdog timeout does not trigger RESET. O Watchdog Output. Pulls low if WDI remains low or high for the duration of the watchdog timeout, and does not go high again until the watchdog is cleared. Whenever VCC is below the reset threshold, WDO stays low. As soon as VCC rises above the reset threshold, WDO goes high with no delay. 4 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Specifications Absolute Maximum Ratings Parameter Min Max Unit −0.3 6 V Output Current 20 mA TJ Maximum Junction Temperature 150 °C TA Operating Temperature Range −40 125 °C TSTG Storage Temperature Range −65 150 °C TL Lead Temperature (Soldering 10 sec) 260 °C VCC Power Supply (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. (2) This data was taken with the JEDEC low effective thermal conductivity test board. (3) This data was taken with the JEDEC standard multilayer test boards. ESD, Electrostatic Discharge Protection Parameter Condition Minimum Level Unit (1) 4 kV 2 kV HBM Human Body Model ESD ANSI/ESDA/JEDEC JS-001 CDM Charged Device Model ESD ANSI/ESDA/JEDEC JS-002 (2) (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Thermal Information Package Type θJA θJC Unit SOP8 143 60 °C/W www.3peak.com 5 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Electrical Characteristics All test conditions: VCC = 1.53 V to 5.5 V, TA = −40°C to 125°C, unless otherwise noted. Parameter Conditions Min Typ Max Unit 5.5 V 4 15 μA 6 20 μA Supply Voltage and Current VCC ICC Operating Supply Voltage Supply Current 1 WDI and MR unconnected (VCC = 1.8 V) WDI and MR unconnected (VCC = 5 V) VTH Reset Threshold Voltage TPV706V 1.51 1.58 1.63 V TPV706W 1.62 1.67 1.71 V TPV706Y 2.12 2.19 2.25 V TPV706Z 2.25 2.32 2.38 V TPV706R 2.55 2.63 2.70 V TPV706S 2.82 2.93 3.00 V TPV706T 3.00 3.08 3.15 V TPV706M 4.25 4.38 4.5 V TPV706L 4.5 4.63 4.75 V Reset Threshold Temperature 80 Coefficient 2 VHYS Reset Threshold Hysteresis tRD VCC to Reset Delay tRP Reset Timeout Period VOL Reset Output Voltage Low (Push- VCC ≥ 1 V, ISINK = 50 μA Pull) ISINK = 1.2 mA @ Vcc ≥ 2 V VOH Reset Output Voltage High (Push-Pull) × 140 ISOURCE = 800 μA, @ VCC≥ 5 V ppm/°C VTH 1000 mV 20 μs 200 280 ms 0.3 V 0.4 V 0.7 × VCC V MR Pin 0.3 × VCC VIL_MR MR Input Threshold VIL VIH_MR MR Input Threshold VIH 0.7 × VCC V tPW_MR MR Input Pulse Width (1) 6 μs tGR_MR MR Glitch Rejection 100 td_MR MR to Reset Delay 1 IMR_V0 MR Pull-up Current tWD Watchdog Timeout Period www.3peak.com VCC = 3V ns 6 80 1 6 / 16 1.6 V μs μA 2.4 sec GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Parameter tPW_WD Conditions WDI Pulse Width 50 ns Min Typ Max 50 Parameter Conditions VIL_WDI WDI input threshold VIL VIH_WDI WDI input threshold VIH IWDI WDI input current VOL_WDO WDO VOL ISINK = 1.2 mA @ VCC ≥ 5 V VOH_WDO WDO VOH ISOURCE = 800 μA @ Vcc≥ 5 V Min Unit ns Typ Max Unit 0.3 × VCC V 0.7 × VCC V VWDI = VCC 20 μA VWDI = 0 -15 μA 0.4 0.7 x V V VCC PFI and PFO VTH_PFI Power fail input threshold PFI falling 1.18 VOL_PFO PFO VOL ISINK = 1.6 mA @ VCC ≥ 5 V VOH_PFO PFO VOH ISOURCE = 800 μA @ VCC ≥ 5 V 0.7 x VCC 1.25 1.32 V 0.4 V V (1) MR pulse width given by customer in application should be longer than minimum value of MR input pulse width requirement. www.3peak.com 7 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Typical Performance Characteristics All test conditions: VCC = 5 V, TA = + 25°C, unless otherwise noted. Figure 1. Supply Current vs Temperature Figure 2. Normalized RESET Timeout Period vs. Temperature Figure 3. Normalized RESET Threshold vs Temperature Figure 4. Voltage Output Low vs ISINK Figure 5. Voltage Output Low vs. ISOURCE Figure 6. Reset Output Voltage vs. Supply Voltage www.3peak.com 8 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector 1.5 WDI PFI(V) 5 PFO(V) WDO 0 0 50 100 150 0 0 2 Time(us) 4 6 Time(s) Figure 7. PFI vs. PFO Figure 8. WDI vs. WDO WDI MR RST RST WDO 0 5 10 0 Time(s) 500 1000 1500 Time(ms) Figure 9. WDI vs. RST and WDO Figure 10. MR vs. RST VCC(V) 3 RST WDO 0 0 500 1000 1500 Time(ms) Figure 11. Vcc vs. RST and WDO www.3peak.com 9 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Detailed Description Overview The TPV706 provides supply voltage supervision, watchdog function, manual reset function, as well as a 1.25-V power-fail comparator. Functional Block Diagram Figure 12. Functional Block Diagram Feature Description RESET Output The TPV706 features an active-low push-pull output. The reset signal is guaranteed to be logic low for VCC down to 1-V. The reset output is asserted when VCC is below the reset threshold (VTH), or when MR is driven low. Reset remains asserted for the duration of the reset active timeout period (tRP) after VCC rises above the reset threshold, or after MR transitions from low to high. Figure 13 shows the reset (active low) outputs. www.3peak.com 10 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector VTH VCC VTH 0V RESET tRP tRD 0V Figure 13. Reset Timing Diagram Manual RESET Input The TPV706 features a manual reset input (MR), which, when driven low, asserts the reset output. When MR transitions from low to high, reset remains asserted for the duration of the reset active timeout period before de-asserting. The MR input has an internal pull-up current so that the input is always high when unconnected. Noise immunity is provided on the MR input, and the fast and negative-going transients are ignored. A 0.1-μF capacitor between MR and ground provides additional noise immunity. Watchdog Input The TPV706 features a watchdog timer, which monitors microprocessor activity. A timer circuit is cleared with every low-tohigh or high-to-low logic transition on the watchdog input pin (WDI). If the timer counts through the preset watchdog timeout period (tWD), the watchdog output (WDO) goes low, a low to high or high to low transition on the WDI pin clears the watchdog timer. The delay time from WDI toggling to WDO going high is within 35-ms. The microprocessor is required to toggle the WDI pin to avoid being reset. Whenever VCC is below the reset threshold, WDO stays low. As soon as VCC rises above the reset threshold, WDO goes high with no delay. Figure 14 shows the watchdog timing. VTH VCC WDI (0 or 1, not float) tWD WDO Figure 14. Watchdog Timing Power-Fail Detector The power-fail detector is a 1.25-V comparator, which can monitor an external power supply through a resistive divider. When the voltage on the PFI is lower than 1.25-V, the comparator output goes low, indicating a power fail, which can be used as an early warning of the power fail. www.3peak.com 11 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Application and Implementation Note Information in the following application sections is not part of the 3PEAK’s component specification and 3PEAK does not warrant its accuracy or completeness. 3PEAK’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. Application Information Figure 15 shows the typical application circuit of TPV706. Microprocessor activity is monitored using WDI. When the WDI remains low or high for the duration of the watchdog timeout, the WDO will trigger a manual reset to MCU. The MCU can drive the MR from high to low and trigger the RESET. 5V Vx VCC /PFO INT /RESET PFI TPV706 GND /RESET WDI I/O /WDO I/O /MR I/O Microprocessor Figure 15. TPV706 Typical Application Circuit www.3peak.com 12 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Tape and Reel Information Order Number Package TPV706xx-SR SOP8 www.3peak.com D1 (mm) W1 (mm) A0 (mm) B0 (mm) K0 (mm) 330 17.6 6.5 13 / 16 5.4 2 P0 (mm) W0 (mm) 8 12 Pin1 Quadrant Q1 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Package Outline Dimensions SOP8 www.3peak.com 14 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector Order Information Operating Temperature Range Package Marking Information MSL Transport Media, Quantity Eco Plan TPV706VL1-SR (1) −40 to 125°C SOP8 V6V 1 Tape and Reel, 4000 Green TPV706WL1-SR (1) −40 to 125°C SOP8 V6W 1 Tape and Reel, 4000 Green TPV706YL1-SR (1) −40 to 125°C SOP8 V6Y 1 Tape and Reel, 4000 Green (1) −40 to 125°C SOP8 V6Z 1 Tape and Reel, 4000 Green TPV706RL1-SR −40 to 125°C SOP8 V6R 1 Tape and Reel, 4000 Green TPV706SL1-SR −40 to 125°C SOP8 V6S 1 Tape and Reel, 4000 Green TPV706TL1-SR −40 to 125°C SOP8 V6T 1 Tape and Reel, 4000 Green TPV706ML1-SR −40 to 125°C SOP8 V6M 1 Tape and Reel, 4000 Green TPV706LL1-SR −40 to 125°C SOP8 V6L 1 Tape and Reel, 4000 Green Order Number TPV706ZL1-SR (1) For future products, contact the 3PEAK factory for more information and samples. Green: 3PEAK defines "Green" to mean RoHS compatible and free of halogen substances. www.3peak.com 15 / 16 GA20230801A6 TPV706 Low-Voltage Supervisory Circuits with Power-Fail Detector IMPORTANT NOTICE AND DISCLAIMER Copyright© 3PEAK 2012-2024. All rights reserved. Trademarks. Any of the 思瑞浦 or 3PEAK trade names, trademarks, graphic marks, and domain names contained in this document /material are the property of 3PEAK. You may NOT reproduce, modify, publish, transmit or distribute any Trademark without the prior written consent of 3PEAK. Performance Information. Performance tests or performance range contained in this document/material are either results of design simulation or actual tests conducted under designated testing environment. Any variation in testing environment or simulation environment, including but not limited to testing method, testing process or testing temperature, may affect actual performance of the product. Disclaimer. 3PEAK provides technical and reliability data (including data sheets), design resources (including reference designs), application or other design recommendations, networking tools, security information and other resources "As Is". 3PEAK makes no warranty as to the absence of defects, and makes no warranties of any kind, express or implied, including without limitation, implied warranties as to merchantability, fitness for a particular purpose or non-infringement of any thirdparty’s intellectual property rights. Unless otherwise specified in writing, products supplied by 3PEAK are not designed to be used in any life-threatening scenarios, including critical medical applications, automotive safety-critical systems, aviation, aerospace, or any situations where failure could result in bodily harm, loss of life, or significant property damage. 3PEAK disclaims all liability for any such unauthorized use. www.3peak.com 16 / 16 GA20230801A6
TPV706SL1-SR 价格&库存
很抱歉,暂时无法提供与“TPV706SL1-SR”相匹配的价格&库存,您可以联系我们找货
TPV706SL1-SR
    • 1+1.99800
    • 100+1.53720
    • 1000+1.28160
    • 2000+1.16280
    • 4000+1.08000
    库存:1437
    TPV706SL1-SR
    • 5+2.14620
    库存:28
    TPV706SL1-SR
    • 4000+2.841784000+0.36662
    库存:3829
    TPV706SL1-SR
    • 5+3.38040
    • 50+2.68920
    • 150+2.32200
    • 500+1.91160
    • 2500+1.72800
    • 4000+1.62000
    库存:5809
    TPV706SL1-SR
    • 1+2.78390
    • 10+2.05920
    • 100+1.76510
    • 1000+1.47100
    库存:1437
    TPV706SL1-SR
      • 1+1.596501+0.20620
      • 100+1.22650100+0.15840
      • 1000+1.026601000+0.13260
      • 2000+0.933602000+0.12060
      • 4000+0.856504000+0.11060
      库存:4472
      TPV706SL1-SR
      • 1+6.527731+0.84215
      • 10+4.6483410+0.59969
      • 25+4.1739125+0.53848
      • 100+3.65457100+0.47148
      • 250+3.40594250+0.43940
      • 500+3.25636500+0.42011
      • 1000+3.133201000+0.40422
      库存:3829
      SPD9103W-2/TR
        库存:12000
