TPM44273-S5TR
TPM44273-S5TR
    3PEAK(思瑞浦)
    SOT23-5
    是一款用于 MOSFET、IGBT 和 GaM 功率开关的单通道低侧栅极驱动器。高源极和漏极电流能力为 5A,可通过最小化缓慢时间和开关损耗来提高开关效率。该器件支持最高 25V 电源电压和 -5V,...
TPM44273-S5TR 数据手册
TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Features Description • • • Industry-Standard Pin-Out The TPM44273 is a single-channel low-side gate driver for MOSFET, IGBT, and GaN power switches. • • • • • TTL and CMOS Compatible Threshold • Available in SOT23-5 Package 4.5-V to 23-V Single-Supply Range High sourcing and sinking current capability of 5 A allows for improving switching efficiencies by minimizing slew time and switching loss. The device supports maximum 25-V supply voltage and –5 V, improving system robustness especially in noisy industrial applications. Ultralow propagation delay allows applications with tight timing requirements. Single Channel 5-A Peak Source and Sink-Drive Current Outputs Held Low during VCC-UVLO or Input Floating Low Propagation Delay (13-ns Typical) Fast Rise-and-Fall Times (7-ns and 6-ns Typical) A small SOT23-5 package assists design for high-density power supply. ESD Protection Exceeds JESD 22 – 6-kV HBM, 1.5-kV CDM Applications • • • • Switched-Mode Power Supplies DC-DC Converters Motor Control, Solar Inverters, UPS Gate & IGBT Drive Typical Application Circuit TPM44273 IN VCC COM OUT www.3peak.com OUT 1 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Table of Contents Features................................................................................................................................................................1 Applications......................................................................................................................................................... 1 Description........................................................................................................................................................... 1 Typical Application Circuit..................................................................................................................................1 Revision History...................................................................................................................................................3 Pin Configuration and Functions....................................................................................................................... 4 Specifications.......................................................................................................................................................5 Absolute Maximum Ratings (1) .......................................................................................................................5 ESD, Electrostatic Discharge Protection........................................................................................................ 5 Recommended Operating Conditions............................................................................................................ 5 Thermal Information........................................................................................................................................5 Electrical Characteristics................................................................................................................................ 6 Typical Performance Characteristics.............................................................................................................. 7 Detailed Description.......................................................................................................................................... 10 Overview.......................................................................................................................................................10 Functional Block Diagram.............................................................................................................................10 Feature Description.......................................................................................................................................11 Application and Implementation...................................................................................................................... 12 Typical Application........................................................................................................................................12 Layout................................................................................................................................................................. 13 Layout Example............................................................................................................................................13 Tape and Reel Information................................................................................................................................ 14 Package Outline Dimensions........................................................................................................................... 15 SOT23-5....................................................................................................................................................... 15 Order Information.............................................................................................................................................. 16 IMPORTANT NOTICE AND DISCLAIMER......................................................................................................... 17 www.3peak.com 2 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Revision History Date Revision 2022-08-12 Rev.A.0 Initial Release 2023-04-09 Rev.A.1 Misc. updates 2024-02-02 Rev.A.2 Updated with new document format www.3peak.com Notes 3 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Pin Configuration and Functions TPM44273 SOT23-5 Top View IN 1 5 VCC 4 OUT Part Number COM 2 OUT 3 Table 1. Pin Functions: TPM44273 Pin No. Name I/O 2 COM Ground 1 IN Input 3,4 OUT Output Channel Output 5 VCC Power Power Supply Input www.3peak.com Description Device Ground Logic Non-inverting Input. 4 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Specifications Absolute Maximum Ratings (1) Parameter Min Max Unit −0.3 25 V −0.3 VCC + 0.3 V −2 VCC + 0.3 (200-ns pulse) V −5 20 V −300 300 mA Pulsed Output Channel Current OUT (500 ns) −5 5 A TJ Operating Junction Temperature Range −40 150 °C TSTG Storage Temperature Range −65 150 °C TL Lead Temperature (Soldering 10 sec) 260 °C VCC Power Supply Voltage Output Voltage Range OUT Input Voltage Range IN Continuous Output Channel Current OUT (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. (2) The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 300 mV beyond the power supply, the input current should be limited to less than 10 mA. (3) Power dissipation and thermal limits must be observed. ESD, Electrostatic Discharge Protection Parameter HBM Condition Human Body Model ESD CDM Charged Device Model ESD Value Unit ANSI/ESDA/JEDEC JS-001 (1) ±6 kV ANSI/ESDA/JEDEC JS-002 (2) ±1.5 kV (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Recommended Operating Conditions Parameter Min Max Unit VCC Power Supply Voltage 4.5 23 V VIN Intput Voltage Range 0 20 V TA Operating Ambient Temperature Range –40 125 °C Thermal Information Package Type SOT23-5 www.3peak.com θJA θJC Unit 89.1 52.0 °C/W 5 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Electrical Characteristics All test conditions: VCC = 12 V, TJ = −40 °C – 150 °C, 1-μF capacitor between VCC and GND, unless otherwise noted. Parameter Conditions Typ Max VCC = 3.4 V, IN = H 40 100 VCC = 3.4 V, IN = L 40 100 IDD(off) Start-up Current VON Supply Under Voltage Lock Out Rising Threshold VOFF Supply Under Voltage Lock Out Falling Threshold VCC_H Supply Under Voltage Lock Out Hysteresis VIN_H IN Signal High Threshold IN high threshold VIN_L IN Signal Low Threshold IN low threshold VIN_HYS IN Hysteresis IOUT Output Peak Current Min Unit μA TJ = 25 °C 3.91 4.2 4.5 TJ = −40 °C – 150 °C 3.7 4.2 4.65 TJ = −40 °C – 150 °C 3.4 3.9 4.4 V 0.2 0.3 0.5 V 1.95 2.3 V 1 CLOAD = 0.22 μF, FSW = 1 kHz V 1.25 V 0.7 V ±5 A VCC – VOH Output High Voltage IOUT = −10 mA 40 mV VOL IOUT = 10 mA 10 mV ROH Output Low Voltage Output Pull-up Resistance, PMOS pull-up only IOUT = −10 mA 1 1.6 3 Ω 0.15 0.5 1 Ω ROL Output Pull-down Resistance IOUT = 10 mA tR Output Rise-time CLOAD = 1.8 nF 7 18 ns tF Output Fall-time CLOAD = 1.8 nF 6 10 ns tPW Minimal Pulse Width 15 25 ns tD1 IN to Output Propagation Delay CLOAD = 1.8 nF, 5-V IN pulse 6 13 23 ns tD2 IN to Output Propagation Delay CLOAD = 1.8 nF, 5-V IN pulse 6 13 23 ns www.3peak.com 6 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Typical Performance Characteristics Figure 1. Start-up Current vs. Temperature Figure 2. Operating Current vs Ambient Temperature f = 500 kHz, CL = 500 pF, VCC = 12 V Figure 3. Supply Current vs Temperature (On/Off) Figure 4. UVLO Threshold vs Temperature Figure 5. Input Threshold vs Temperature Figure 6. Operating Supply Current vs Frequency www.3peak.com 7 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Figure 7. Output Pull-up Resistance vs Temperature Figure 8. Output Pull-down Resistance vs Temperature Figure 9. Rise-time vs Temperature Figure 10. Fall-time vs Temperature Figure 11. Input to Output Propagation Delay vs Temperature Figure 12. Enable to Output Propagation Delay vs Temperature www.3peak.com 8 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Figure 13. Fall-time vs Supply Voltage Figure 14. Rise-time vs Supply Voltage Figure 15. Output Pull-down Current Figure 16. Output Pull-up Current www.3peak.com 9 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Detailed Description Overview The TPM44273 single-channel low-side gate driver is designed for high-performance power supplies, motor controls, and inverters. Designed with industrial standard pin-out and package, the TPM44273 accelerates the design process. With extended voltage ranges on supply voltage and negative input voltage on inputs, the TPM44273 improves system-level reliability. 5-A Strong driving capability improves gate driver efficiency and lowers heat generation, especially in highfrequency switching applications. Functional Block Diagram VCC VCC VCC IN OUT GND VCC GND UVLO GND GND Figure 17. Functional Block Diagram www.3peak.com 10 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Feature Description Low Propagation Delay Driver Output The low-propagation-delay design allows the device to achieve industrial-leading low propagation delay between device input and output. The low delay enhances driver performance in high-frequency switching regulators. Supply and UVLO The device monitors supply voltage with under-voltage lock-out (UVLO). When the supply voltage is below the UVLO threshold, the outputs are held low in UVLO to avoid glitches during power rising and falling. The quiescent current and operating current of the device are measured as shown in Figure 4. The current is related to internal quiescent current consumption as well as output current. The output current can be calculated using external transistor gate charge times switching frequency fsw. Channel Input The input of TPM44273 gate drivers supports TTL and CMOS input with threshold voltage independent of supply voltage. The threshold is also designed as temperature-independent to support a wide range of ambient temperatures. Wide hysteresis enhances system-level noise immunity. The integrated pull-down resistors set the device in a low state when inputs are floating. Inputs can withstand DC −5V, to improve robustness on ground bouncing. Output Stage The TPM44273 output stage can deliver high current sourcing and sink up to 5-A with low propagation delay. www.3peak.com 11 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Application and Implementation Note Information in the following application sections is not part of the 3PEAK’s component specification and 3PEAK does not warrant its accuracy or completeness. 3PEAK’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. Typical Application Figure 18 shows the typical application schematic. Figure 18. Application Circuit www.3peak.com 12 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Layout Layout Example Figures below show the location of external components as they appear on the PCB diagram. Figure 19. Top Layer www.3peak.com Figure 20. Bottom Layer 13 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Tape and Reel Information Order Number TPM44273S5TR www.3peak.com Package SOT23-5 D1 (mm) W1 (mm) A0 (mm) B0 (mm) K0 (mm) P0 (mm) W0 (mm) Pin1 Quadrant 179 12 3.3 3.25 1.4 4 8 Q3 14 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Package Outline Dimensions SOT23-5 www.3peak.com 15 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver Order Information Order Number TPM44273-S5TR Operating Ambient Temperature Range Package Marking Information MSL Transport Media, Quantity Eco Plan −40 °C – 125 °C (1) SOT23-5 M73 MSL3 3000 Green (1) Ambient temperature indicates device operation condition range. Application thermal behavior needs to be taken care of when operating in high-temperature scenarios Green: 3PEAK defines "Green" to mean RoHS compatible and free of halogen substances. www.3peak.com 16 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver IMPORTANT NOTICE AND DISCLAIMER Copyright© 3PEAK 2012-2024. All rights reserved. Trademarks. Any of the 思瑞浦 or 3PEAK trade names, trademarks, graphic marks, and domain names contained in this document /material are the property of 3PEAK. You may NOT reproduce, modify, publish, transmit or distribute any Trademark without the prior written consent of 3PEAK. Performance Information. Performance tests or performance range contained in this document/material are either results of design simulation or actual tests conducted under designated testing environment. Any variation in testing environment or simulation environment, including but not limited to testing method, testing process or testing temperature, may affect actual performance of the product. Disclaimer. 3PEAK provides technical and reliability data (including data sheets), design resources (including reference designs), application or other design recommendations, networking tools, security information and other resources "As Is". 3PEAK makes no warranty as to the absence of defects, and makes no warranties of any kind, express or implied, including without limitation, implied warranties as to merchantability, fitness for a particular purpose or non-infringement of any thirdparty’s intellectual property rights. Unless otherwise specified in writing, products supplied by 3PEAK are not designed to be used in any life-threatening scenarios, including critical medical applications, automotive safety-critical systems, aviation, aerospace, or any situations where failure could result in bodily harm, loss of life, or significant property damage. 3PEAK disclaims all liability for any such unauthorized use. www.3peak.com 17 / 18 EA20240105A2 TPM44273 Single-Channel 5-A High-Speed, Low-Side Gate Driver This page intentionally left blank www.3peak.com 18 / 18 EA20240105A2
TPM44273-S5TR 价格&库存
很抱歉,暂时无法提供与“TPM44273-S5TR”相匹配的价格&库存,您可以联系我们找货
TPM44273-S5TR
  • 3000+2.450643000+0.31616
库存:2611
TPM44273-S5TR
  • 1+5.727421+0.73890
  • 10+4.0677510+0.52478
  • 25+3.6485225+0.47070
  • 100+3.18532100+0.41094
  • 250+2.96485250+0.38250
  • 500+2.83173500+0.36533
  • 1000+2.722121000+0.35119
库存:2611
TPM44273-S5TR
    • 1+3.36540
    • 200+2.58795
    • 1500+2.25070
    • 3000+2.09450
    库存:700
