FSK-S15 Series AC-DC Converter
Features
· UL, C-UL, CB, CE Marking ·Encapsulated compact case ·High efficiency ·Universal input ·Surface mounting technology ·Built in EMI filter ·Inrush current limit ·67kHz fixed frequency ·Fixed output voltage ·Thermal shutdown ·Short circuit protection ·Low output ripple and noise ·Isolated output
Model Number FSK-S15-3R3U FSK-S15-5U FSK-S15-12U FSK-S15-15U FSK-S15-24U
AC AC AC AC AC
Input Voltage 85~264V / DC110~340V 85~264V / DC110~340V 85~264V / DC110~340V 85~264V / DC110~340V 85~264V / DC110~340V
Output Voltage1 3.3V@3.0A 5V@3.0 12V@1.3A 15V@1.0A 24V@0.65A
Power Max. 9.9w 15w 15.6w 15.0w 15.6w
Ripple & Noise Max 80mVp-p 80mVp-p 120mVp-p 150mVp-p 200mVp-p
Efficiency (Typ.) 75 75 78 78 78
Electrical specifications
Input Voltage Current Frequency Efficiency Inrush current (at cold start) Leakage current Output Voltage tolerance Ripple and noise Line regulation Load regulation Dynamic load regulation Temperature drift Rising time Holding time Protection circuit Output short circuit protection Over temperature protection Electrically isolated Input / output Input / FG Output / FG AC85~264 (or DC 110~340V) 0.31A max. @ 110VAC / 0.16A max. @ 220VAC 47~440Hz max. (50~60Hz typ.) 75% min. 30A max. @ 110VAC / 60A max. @ 220VAC 0.5mA max. @ 110VAC / 0.75mA max. @ 220VAC ±2% (single and uncomplimentary dual) ±3% (complementary dual) ±1% typ. ±1% typ. ±1% typ. ±3% typ. ±1% typ. 400ms max. 10ms min. Works at over 105% of rating & recovers automatically 145°C typ. AC 4.8kV, 1 minute, 10mA / DC 500V, 100MOhms min. AC 2kV, 1 minute, 10mA / DC 500V, 100MOhms min. AC 0.5kV, 1 minute, 10mA / DC 500V, 70MOhms min.
V-Infinity, LLC, 9615 SW Allen Blvd Suite 103, Beaverton, OR 97005
www.v-infinity.com
1-866-372-1258
Environmental
Operating temperature range Storage temperature range Humidity Vibration Impact Cooling method MTBF Safety (single output) -10°C~60°C -20°C~70°C 20%~90%RH 10~55Hz @ 10G 3 minute period 50G for 11ms, once on each X, Y and Z axis Natural air 3.0 x 105 hrs UL (UL60950, CSA C22.2 NO.60950) : E227474 / CB/ (IEC 60950)/ CE (EN 60950) - through TUV EMC (single output) EN 61204-3 class B / EN 61000-3-2 / EN 61000-3-3 through TUV Meets FCC class B
Noise
Pin assignments
Derating curve
Dimensions
V-Infinity reserves the right to make changes to its products or to discontinue any product or service without notice, and to advise customers to verify the most up-to-date product information before placing orders. V-Infinity assumes no liability or responsibility for customer’s applications using V-Infinity products other than repair or replacing (at V-I’s option) V-Infinity products not meeting V-I’s published specifications. Nothing will be covered outside of standard product warranty.
www.v-infinity.com
1-866-372-1258
很抱歉,暂时无法提供与“FSK-S15-12U”相匹配的价格&库存,您可以联系我们找货
