BAT42LS
General-purpose Schottky diode
6 April 2022
Product data sheet
1. General description
General-purpose Schottky diode in an ultra small DFN1006BD-2 (SOD882BD) leadless SurfaceMounted Device (SMD) plastic package with side-wettable flanks.
2. Features and benefits
Forward current: IF ≤ 0.2 A
Reverse voltage: VR ≤ 40 V
Ultra small SMD plastic package
Low forward voltage
Suitable for Automatic Optical Inspection (AOI) of solder joint
3. Applications
Ultra high-speed switching
Voltage clamping
Protection circuits
Low voltage rectification
Blocking diodes
Low power consumption applications
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IF
forward current
200
mA
VR
reverse voltage
40
V
VF
forward voltage
600
mV
IF = 200 mA; tp ≤ 300 µs; δ ≤ 0.02;
pulsed; Tamb = 25 °C
5. Pinning information
Table 2. Pinning information
Pin
Symbol
Description
1
K
cathode[1]
2
A
anode
Simplified outline
1
2
K
Transparent
top view
[1]
The marking bar indicates the cathode.
Graphic symbol
sym001
A
BAT42LS
Nexperia
6. Ordering information
Table 3. Ordering information
Type number
Package
Name
BAT42LS
Description
Version
DFN1006BD-2 Leadless ultra small plastic package with side-wettable
flanks (SWF); 2 terminals; 0.65 mm pitch; 1 mm x 0.6 mm
x 0.47 mm body
SOD882BD
7. Marking
Table 4. Marking codes
Type number
Marking code
BAT42LS
8Y
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VR
IF
IFRM
repetitive peak forward
current
IFSM
Ptot
Conditions
Min
Max
Unit
reverse voltage
40
V
forward current
200
mA
tp ≤ 1 ms; δ ≤ 0.25
1
A
non-repetitive peak
forward current
tp = 8 ms; square wave
3
A
total power dissipation
Tamb ≤ 25 °C
[1]
335
mW
[2]
610
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
[1]
[2]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided 70 µm copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided, 70 µm copper, tin-plated, mounting pad for cathode 1 cm .
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Rth(j-a)
[1]
[2]
[3]
Conditions
thermal resistance from in free air
junction to ambient
Min
Typ
Max
Unit
[1] [2]
375
K/W
[3]
205
K/W
For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a
significant part of the total power losses.
Device mounted on an FR4 PCB, single-sided, 70 µm copper, tin-plated and standard footprint.
2
BAT42LS
Product data sheet
All information provided in this document is subject to legal disclaimers.
6 April 2022
Nexperia B.V. 2022. All rights reserved
2/8
BAT42LS
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
VF
forward voltage
IR
reverse current
Cd
diode capacitance
Conditions
Min
Typ
Max
Unit
IF = 0.1 mA; tp ≤ 300 µs; δ ≤ 0.02;
220
mV
IF = 1 mA; tp ≤ 300 µs; δ ≤ 0.02;
290
mV
IF = 10 mA; tp ≤ 300 µs; δ ≤ 0.02;
360
mV
IF = 100 mA; tp ≤ 300 µs; δ ≤ 0.02;
500
mV
pulsed; Tamb = -40 °C
600
mV
600
mV
650
mV
VR = 25 V; Tamb = 25 °C
0.5
µA
VR = 40 V; Tamb = 25 °C
10
µA
VR = 1 V; f = 1 MHz; Tamb = 25 °C
pF
006aac596
10
IF
(A)
1
10- 1
10- 2
(3)
10- 4
0.0
10- 4
(2)
10- 5
(3)
10- 6
(5)
(4)
(4)
0.2
10- 7
0.4
0.6
0.8
1.0
Product data sheet
VR (V)
40
(1) Tamb = 150 °C
(2) Tamb = 125 °C
(3) Tamb = 85 °C
(4) Tamb = 25 °C
Forward current as a function of forward
voltage; typical values
BAT42LS
10- 8
1.2
1.4
VF (V)
(1) Tamb = 150 °C
(2) Tamb = 125 °C
(3) Tamb = 85 °C
(4) Tamb = 25 °C
(5) Tamb = -40 °C
Fig. 1.
(1)
(1)
(2)
10- 3
006aac597
10- 2
IR
(A)
10- 3
Fig. 2.
Reverse current as a function of reverse
6 April 2022
3/8
BAT42LS
Nexperia
001aaa339
30
Cd
(pF)
VR (V)
40
Fig. 3.
Diode capacitance as a function of reverse voltage; typical values
11. Package outline
0.50
0.44
0.6
2
0.30
0.22
0.65
0.30
0.22
1.0
1
0.55
0.45
cathode marking on top side
Dimensions in mm
Fig. 4.
20-05-01
Package outline DFN1006BD-2 (SOD882BD)
BAT42LS
Product data sheet
6 April 2022
4/8
BAT42LS
Nexperia
12. Soldering
Footprint information for reflow soldering of DFN1006BD-2 package
SOD882BD
1.4
0.2
0.8
(2×)
0.6
(2×)
0.7
(2×)
0.3
0.4
1.0
1.3
solder resist
solder paste
solder lands
Dimensions in mm
Issue date
Fig. 5.
20-05-01
20-12-15
sod882bd_fr
Reflow soldering footprint for DFN1006BD-2 (SOD882BD)
BAT42LS
Product data sheet
6 April 2022
5/8
BAT42LS
Nexperia
13. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
BAT42LS v.2
20220406
Product data sheet
BAT42LS v.1
Modifications:
BAT42LS v.1
20220131
BAT42LS
Product data sheet
Product status changed
Objective data sheet
6 April 2022
6/8
BAT42LS
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
BAT42LS
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
6 April 2022
7/8
BAT42LS
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................1
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 2
9. Thermal characteristics............................................... 2
10. Characteristics............................................................ 3
11. Package outline.......................................................... 4
12. Soldering..................................................................... 5
13. Revision history..........................................................6
14. Legal information........................................................7
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 6 April 2022
BAT42LS
Product data sheet
6 April 2022
8/8
