环氧粉末包封型金属化聚丙烯膜电容器---CBB21(MPP)系列
Metallized Polypropylene Film Capacitors(Dipped )---CBB21(MPP)series
■ 引用标准 Reference standards
GB10190(IEC384-16)
■ 结构 Structure
介质:聚丙烯膜
电极:金属真空蒸发层
封装:阻燃粉末环氧树脂,符合 UL94 V-0
Dielectric: Polypropylene film
Electrode: metal vacuum evaporation layer
Encapsulation: Flame retardant power epoxy resin, conforming to UL94 V-0
典型应用 Typical
Application
用于开关电源,电子镇流器和变频器等中间电路直流滤波(如 DC filter,DC-link,PFC 等)
As intermediate circuit capacitor for SMPS, LED driver, inverter (i.e. DC filter,DC-link, DC filter and P.F.C)
特点 Features
有良好自愈性能 ,缩小产品尺寸,高频损耗小,温升低
Reduced size depended on good self-healing property, low dissipation at high frequency, low temperature rise
符合 RoHS 及 REACH 环保标准 Compliance with RoHs &
电性能规范 Performance Specifications
REACH requirements.
气候类别 Climate category
40/105/56
额定温度 Rated Temperature
85℃
工作温度范围
-40℃--+105℃.
Operating Temperature range
(+85℃~+105℃): decreasing factor 1.5% per ℃ for R.V(DC)
(+85℃~+105℃): 额定电压降额使用系数 1.5% per ℃ for R.V(DC)
额定电压 Rated Voltage
400(450)VDC, 630VDC
容量误差 Capacitance Tolerance
J: ±5%
容量范围
0.001μF~22μF
Capacitance Range
测试条件 Test Condition:
耐电压
损耗角 Dissipation factor
≤0.001
绝缘电阻或时间常数
CR≤0.33μF IR≥30000MΩ
Insulation Resistance
CR>0.33μF IR≥10000S
Max. Pulse Rise Time
(dV / dt)
无击穿或飞弧
1.6UR,5S
Withstand Voltage
最大脉冲爬升速率
20℃, 1KHz, 1Vrms
No breakdown or electric arcing
测试条件 Test Condition :
(1KHZ )
20℃
1Vrms
20℃
100V
1 min
UR(V)
P7.5
P10
P15
P20
P25
P31
400(450)V
120
80
65
35
630V
150
120
80
60
40
稳态湿热
温度 Temp.:40±2℃
无可见损伤,标志清晰
Steady-state
Damp-heat Test
相对湿度 Humidity:93%RH
no visible damage,clear mark
绝缘电阻 IR:≥ 额定值的 50%
IR:≥ 50% of Rated value
持续时间 Duration Time:56 Days
容量变化(相对初始值):
Capacitance change ( relative to the initial
value):△C/C≤±5%
损耗角增加 Dissipation factor:
Rise ≤0.0020(1KHZ),CR>1uF
耐久性试验
温度 Temp.: +85℃,
绝缘电阻 Insulation Resistance
Endurance Test
电压 Voltage:
IR:≥ 额定值的 50%
IR:≥ 50% of rated value
1.25 Times Rated Voltage
持续时间 Duration Time: 1000H
损耗角增加:≤0.0040
dissipation factor rise:≤0.0040
容量变化(相对初始值):△C/C≤±10%
Capacitance change
(relative to the initial value):△C/C≤±10%
产品编码说明 Part No. Description:
18 位产品编码如下:
The Part No. Is total 18 digits, details as follow:
1
2
3
4
5
6
7
8
9
10
M
P
P
1
J
2
G
1
11
12
13
14
15
16
17
18
9
1
4
8
Digit 1-3
型号代码 Product series Code
MPP= CBB21 series
Digit 4-6
Digit 7
Digit 8-9
Digit 10-15
Digit 16
Digit 17-18
标称容量 Rated Capacitance Value
For example : 105 = 10×105pF = 1.0F
J=±5%
2G=400VDC 2W=450VDC 2J=630VDC
容量偏差 Capacitance Tolerance
额定电压 Rated Voltage Code
外形尺寸 Dimensions Code
线径代码 Line diameter code
6=0.6 8=0.8
成型或内部识别码 Forming Type or Internal Use
1=1.0
料号明细及尺寸 Part No. List and Dimensions
UR :400(450)Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP823J##1004075**
CBB21
0.082
10
5.0
8.0
7.5
0.5
MPP104J##1004075**
CBB21
0.1
10
5.5
8.5
7.5
0.5
MPP124J##1004085**
CBB21
0.12
10
5.5
9.0
7.5
0.5
MPP154J##1005085**
CBB21
0.15
10
6.0
9.5
7.5
0.5
MPP184J##1005105**
CBB21
0.18
10
6.0
10.5
7.5
0.5
MPP224J##1005105**
CBB21
0.22
10
6.5
11.5
7.5
0.5
MPP274J##1006115**
CBB21
0.27
10
7.0
12.0
7.5
0.5
MPP334J##1006135**
CBB21
0.33
10
7.5
14.0
7.5
0.5
MPP394J##1007145**
CBB21
0.39
10
8.0
14.5
7.5
0.5
MPP474J##1008155**
CBB21
0.47
10
9.0
15.5
7.5
0.5
MPP124J##1304075**
CBB21
0.12
13
5.0
8.5
10
0.5
MPP154J##1304075**
CBB21
0.15
13
5.5
8.5
10
0.5
MPP184J##1304085**
CBB21
0.18
13
6.0
9.0
10
0.5
MPP224J##1305085**
CBB21
0.22
13
6.5
10.5
10
0.5
MPP274J##1305105**
CBB21
0.27
13
6.5
10.5
10
0.5
MPP334J##1305115**
CBB21
0.33
13
7.5
12.5
10
0.5
MPP394J##1306116**
CBB21
0.39
13
8.0
13.0
10
0.6
MPP474J##1306136**
CBB21
0.47
13
7.5
14.5
10
0.6
MPP564J##1307146**
CBB21
0.56
13
8.5
15.5
10
0.6
MPP684J##1308156**
CBB21
0.68
13
9.5
16.0
10
0.6
MPP824J##1308166**
CBB21
0.82
13
9.5
16.5
10
0.6
MPP105J##1309176**
CBB21
1.0
13
10.5
18.5
10
0.6
MPP474J##1905106**
CBB21
0.47
18
6.5
11.5
15
0.6
MPP564J##1905106**
CBB21
0.56
18
6.5
12.0
15
0.6
MPP684J##1906116**
CBB21
0.68
18
7.5
12.5
15
0.6
MPP824J##1907128**
CBB21
0.82
18
8.5
13.0
15
0.8
MPP105J##1907148**
CBB21
1.0
18
8.5
15.0
15
0.8
MPP125J##1908148**
CBB21
1.2
18
9.0
15.5
15
0.8
MPP155J##1908168**
CBB21
1.5
18
9.5
17.5
15
0.8
MPP185J##1909178**
CBB21
1.8
18
10.0
18.0
15
0.8
说明 Note:
1. “##” 表示标称电压
2. “**”表示内部特征码
“##” =Rated voltage 2G=400V, 2W=450V
“**”=Internal use.
UR :400(450)Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP225J##1910198**
CBB21
2.2
18
11.5
20.0
15
0.8
MPP275J##1911218**
CBB21
2.7
18
12.0
22.0
15
0.8
MPP335J##1912228**
CBB21
3.3
18
14.5
24.0
15
0.8
MPP105J##2406116**
CBB21
1.0
23
7.5
12.5
MPP125J##2407128**
CBB21
1.2
23
8.0
13.0
MPP155J##2407148**
CBB21
1.5
23
8.5
15.0
MPP185J##2408158**
CBB21
1.8
23
9.0
15.5
MPP225J##2408178**
CBB21
2.2
23
9.0
17.5
MPP275J##2409188**
CBB21
2.7
23
10.0
18.5
MPP335J##2410198**
CBB21
3.3
23
11.5
20.0
MPP395J##2411218**
CBB21
3.9
23
12.0
22.0
MPP475J##2412228**
CBB21
4.7
23
13.5
23.5
MPP565J##2414248**
CBB21
5.6
23
14.5
25.0
MPP685J##2415258**
CBB21
6.8
23
16.5
26.5
MPP825J##2416298**
CBB21
8.2
23
17.0
30.0
MPP106J##2418318**
CBB21
10.0
23
19.0
32.0
MPP185J##2907138**
CBB21
1.8
28
7.5
14.5
25
0.8
MPP225J##2907148**
CBB21
2.2
28
9.0
17.5
25
0.8
MPP275J##2908158**
CBB21
2.7
28
9.5
18.0
25
0.8
MPP335J##2909178**
CBB21
3.3
28
10.5
18.5
25
0.8
MPP395J##2910188**
CBB21
3.9
28
11.0
19.0
25
0.8
MPP475J##2910208**
CBB21
4.7
28
11.5
21.5
25
0.8
MPP685J##2913238**
CBB21
6.8
28
14.0
24.0
25
0.8
MPP825J##2915258**
CBB21
8.2
28
16.0
25.5
25
0.8
MPP106J##2915288**
CBB21
10.0
28
16.5
29.5
25
0.8
MPP126J##2917308**
CBB21
12.0
28
18.0
31.0
25
0.8
MPP156J##2919328**
CBB21
15.0
28
20.5
33.5
25
0.8
MPP335J##3508168**
CBB21
3.3
35
9.0
17.0
31
0.8
MPP395J##3508178**
CBB21
3.9
35
9.5
18.0
31
0.8
MPP475J##3509188**
CBB21
4.7
35
10.5
19.0
31
0.8
说明 Note:
1. “##” 表示标称电压
2. “**”表示内部特征码
“**”=Internal use.
UR :400(450)Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP565J##3510208**
CBB21
5.6
34
11.0
21.0
31
0.8
MPP685J##3511218**
CBB21
6.8
34
12.5
22.5
31
0.8
MPP825J##3513238**
CBB21
8.2
34
14.0
24.0
31
0.8
MPP106J##3514248**
CBB21
10.0
34
15.5
25.5
31
0.8
MPP126J##3514288**
CBB21
12.0
34
16.0
29.0
31
0.8
MPP156J##3517308**
CBB21
15.0
34
18.0
31.0
31
0.8
MPP186J##3519328**
CBB21
18.0
34
20.0
33.0
31
0.8
MPP226J##3521348**
CBB21
22.0
34
22.0
35.0
31
0.8
说明 Note:
1. “##” 表示标称电压
2. “**”表示内部特征码
“**”=Internal use.
UR :630Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP102J2J1004075**
CBB21
0.001
10.0
4.5
7.5
7.5
0.5
MPP122J2J1004075**
CBB21
0.0012
10.0
4.5
8.0
7.5
0.5
MPP152J2J1004075**
CBB21
0.0015
10.0
5.0
8.5
7.5
0.5
MPP182J2J1004075**
CBB21
0.0018
10.0
5.5
9.0
7.5
0.5
MPP222J2J1004075**
CBB21
0.0022
10.0
5.5
8.0
7.5
0.5
MPP272J2J1004075**
CBB21
0.0027
10.0
5.5
8.5
7.5
0.5
MPP332J2J1004075**
CBB21
0.0033
10.0
5.5
8.5
7.5
0.5
MPP392J2J1004075**
CBB21
0.0039
10.0
5.5
8.5
7.5
0.5
MPP472J2J1004075**
CBB21
0.0047
10.0
6.5
9.5
7.5
0.5
MPP562J2J1004075**
CBB21
0.0056
10.0
5.0
8.5
7.5
0.5
MPP682J2J1004075**
CBB21
0.0068
10.0
5.5
8.5
7.5
0.5
MPP822J2J1004085**
CBB21
0.0082
10.0
5.5
9.0
7.5
0.5
MPP103J2J1004075**
CBB21
0.01
10.0
5.0
8.5
7.5
0.5
MPP123J2J1004075**
CBB21
0.012
10.0
5.5
9.0
7.5
0.5
MPP153J2J1004075**
CBB21
0.015
10.0
5.5
9.0
7.5
0.5
MPP183J2J1004075**
CBB21
0.018
10.0
5.5
8.5
7.5
0.5
MPP223J2J1004075**
CBB21
0.022
10.0
5.5
9.0
7.5
0.5
MPP273J2J1004075**
CBB21
0.027
10.0
6.0
9.5
7.5
0.5
■料号明细及尺寸 Part No. List and Dimensions
UR :630Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP333J2J1004075**
CBB21
0.033
10.0
5.5
8.5
7.5
0.5
MPP393J2J1004075**
CBB21
0.039
10.0
5.5
9.0
7.5
0.5
MPP473J2J1004075**
CBB21
0.047
10.0
5.5
8.5
7.5
0.5
MPP563J2J1004075**
CBB21
0.056
10.0
6.0
9.0
7.5
0.5
MPP683J2J1005085**
CBB21
0.068
10.0
6.0
9.0
7.5
0.5
MPP823J2J1004105**
CBB21
0.082
10.0
6.5
11.5
7.5
0.5
MPP104J2J1005105**
CBB21
0.1
10.0
6.5
11.5
7.5
0.5
MPP124J2J1005115**
CBB21
0.12
10.0
7.0
12.0
7.5
0.5
MPP154J2J1006125**
CBB21
0.15
10.0
6.5
13.5
7.5
0.5
MPP184J2J1006135**
CBB21
0.18
10.0
7.0
14.0
7.5
0.5
MPP224J2J1007145**
CBB21
0.22
10.0
8.0
15.0
7.5
0.5
MPP102J2J1304075**
CBB21
0.001
13.0
5.0
9.0
10.0
0.5
MPP122J2J1304075**
CBB21
0.0012
13.0
5.5
9.5
10.0
0.5
MPP152J2J1304085**
CBB21
0.0015
13.0
5.5
9.0
10.0
0.5
MPP182J2J1304075**
CBB21
0.0018
13.0
5.0
8.5
10.0
0.5
MPP222J2J1304075**
CBB21
0.0022
13.0
5.5
8.5
10.0
0.5
MPP272J2J1304075**
CBB21
0.0027
13.0
5.0
8.5
10.0
0.5
MPP332J2J1304085**
CBB21
0.0033
13.0
5.5
9.0
10.0
0.5
MPP392J2J1304075**
CBB21
0.0039
13.0
5.5
8.5
10.0
0.5
MPP472J2J1304085**
CBB21
0.0047
13.0
5.5
8.5
10.0
0.5
MPP562J2J1304075**
CBB21
0.0056
13.0
5.5
8.5
10.0
0.5
MPP682J2J1304075**
CBB21
0.0068
13.0
5.5
8.5
10.0
0.5
MPP822J2J1304075**
CBB21
0.0082
13.0
5.5
8.5
10.0
0.5
MPP103J2J1304085**
CBB21
0.01
13.0
5.5
8.5
10.0
0.5
MPP123J2J1304095**
CBB21
0.012
13.0
5.5
10.5
10.0
0.5
MPP153J2J1304075**
CBB21
0.015
13.0
5.0
8.5
10.0
0.5
MPP183J2J1304075**
CBB21
0.018
13.0
5.5
9.5
10.0
0.5
MPP223J2J1304075**
CBB21
0.022
13.0
6.0
9.0
10.0
0.5
MPP273J2J1304075**
CBB21
0.027
13.0
5.5
9.5
10.0
0.5
MPP333J2J1304075**
CBB21
0.033
13.0
5.5
9.0
10.0
0.5
说明 Note: “**”表示内部特征码
“**”=Internal use.
UR :630Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP393J2J1304075**
CBB21
0.039
13.0
5.5
9.0
10.0
0.5
MPP473J2J1304075**
CBB21
0.047
13.0
5.5
9.0
10.0
0.5
MPP563J2J1304075**
CBB21
0.056
13.0
5.5
9.0
10.0
0.5
MPP683J2J1304075**
CBB21
0.068
13.0
5.0
8.5
10.0
0.5
MPP823J2J1304075**
CBB21
0.082
13.0
5.5
9.0
10.0
0.5
MPP104J2J1304095**
CBB21
0.1
13.0
5.5
10.5
10.0
0.5
MPP124J2J1304105**
CBB21
0.12
13.0
5.5
10.5
10.0
0.5
MPP154J2J1305105**
CBB21
0.15
13.0
6.5
12.0
10.0
0.5
MPP184J2J1306116**
CBB21
0.18
13.0
7.0
12.0
10.0
0.6
MPP224J2J1306126**
CBB21
0.22
13.0
7.5
14.5
10.0
0.6
MPP274J2J1306136**
CBB21
0.27
13.0
7.5
14.5
10.0
0.6
MPP334J2J1307146**
CBB21
0.33
13.0
8.5
15.5
10.0
0.6
MPP394J2J1307166**
CBB21
0.39
13.0
8.5
16.5
10.0
0.6
MPP474J2J1308176**
CBB21
0.47
13.0
9.5
18.0
10.0
0.6
MPP224J2J1904106**
CBB21
0.22
18.0
6.0
11.0
15.0
0.6
MPP274J2J1905106**
CBB21
0.27
18.0
6.5
11.5
15.0
0.6
MPP334J2J1905126**
CBB21
0.33
18.0
6.5
13.0
15.0
0.6
MPP394J2J1906126**
CBB21
0.39
18.0
7.0
13.5
15.0
0.6
MPP474J2J1906136**
CBB21
0.47
18.0
7.5
14.5
15.0
0.6
MPP564J2J1907148**
CBB21
0.56
18.0
8.0
15.0
15.0
0.8
MPP684J2J1907168**
CBB21
0.68
18.0
8.5
17.0
15.0
0.8
MPP824J2J1908178**
CBB21
0.82
18.0
9.0
17.5
15.0
0.8
MPP105J2J1909198**
CBB21
1.0
18.0
9.5
19.5
15.0
0.8
MPP125J2J1910208**
CBB21
1.2
18.0
11.0
21.0
15.0
0.8
MPP155J2J1911218**
CBB21
1.5
18.0
12.5
22.5
15.0
0.8
MPP474J2J2406116**
CBB21
0.47
23.0
7.0
12.0
20.0
0.6
MPP564J2J2406116**
CBB21
0.56
23.0
7.5
13.5
20.0
0.6
MPP684J2J2406136**
CBB21
0.68
23.0
7.5
14.0
20.0
0.6
MPP824J2J2407148**
CBB21
0.82
23.0
8.0
15.0
20.0
0.8
MPP105J2J2407168**
CBB21
1.0
23.0
9.5
17.5
20.0
0.8
MPP125J2J2408178**
CBB21
1.2
23.0
9.5
18.0
20.0
0.8
说明 Note:“**”表示内部特征码
“**”=Internal use.
UR :630Vdc
成品编码
系列
Part No.
容量
尺寸 Dimension (mm)
Series
Capacitance
(μF)
Wmax
Tmax
Hmax
P±0.5
d±0.05
MPP155J2J2409188**
CBB21
1.5
23.0
11.0
19.0
20.0
0.8
MPP185J2J2410208**
CBB21
1.8
23.0
11.5
21.0
20.0
0.8
MPP225J2J2411218**
CBB21
2.2
23.0
13.0
23.0
20.0
0.8
MPP275J2J2413238**
CBB21
2.7
23.0
14.5
24.5
20.0
0.8
MPP335J2J2415248**
CBB21
3.3
23.0
16.0
26.0
20.0
0.8
MPP395J2J2415288**
CBB21
3.9
23.0
16.0
29.0
20.0
0.8
MPP475J2J2416308**
CBB21
4.7
23.0
17.5
30.5
20.0
0.8
MPP105J2J2907148**
CBB21
1.0
28.0
8.5
15.0
25.0
0.8
MPP125J2J2908148**
CBB21
1.2
28.0
9.0
15.5
25.0
0.8
MPP155J2J2908168**
CBB21
1.5
28.0
9.0
17.5
25.0
0.8
MPP185J2J2909178**
CBB21
1.8
28.0
10.0
18.5
25.0
0.8
MPP225J2J2910191**
CBB21
2.2
28.0
11.0
19.5
25.0
1.0
MPP275J2J2911211**
CBB21
2.7
28.0
12.5
22.5
25.0
1.0
MPP335J2J2912221**
CBB21
3.3
28.0
12.5
23.5
25.0
1.0
MPP395J2J2914241**
CBB21
3.9
28.0
14.5
24.5
25.0
1.0
MPP475J2J2915251**
CBB21
4.7
28.0
16.5
26.5
25.0
1.0
MPP565J2J2916291**
CBB21
5.6
28.0
16.5
29.5
25.0
1.0
MPP685J2J2917311**
CBB21
6.8
28.0
18.5
32.0
25.0
1.0
MPP185J2J3508168**
CBB21
1.8
34.0
9.0
17.0
31.0
0.8
MPP225J2J3509171**
CBB21
2.2
34.0
9.5
18.0
31.0
1.0
MPP275J2J3509191**
CBB21
2.7
34.0
10.5
20.5
31.0
1.0
MPP335J2J3510201**
CBB21
3.3
34.0
10.5
21.5
31.0
1.0
MPP395J2J3512221**
CBB21
3.9
34.0
13.0
23.0
31.0
1.0
MPP475J2J3513231**
CBB21
4.7
34.0
15.5
25.5
31.0
1.0
MPP565J2J3513261**
CBB21
5.6
34.0
15.0
27.5
31.0
1.0
MPP685J2J3515281**
CBB21
6.8
34.0
16.0
29.0
31.0
1.0
MPP825J2J3517301**
CBB21
8.2
34.0
18.0
31.0
31.0
1.0
MPP106J2J3519321**
CBB21
10.0
34.0
20.5
33.5
31.0
1.0
“**”=Internal use.
Note: We can customize the capacitors according to customers special requirements.
很抱歉,暂时无法提供与“MPP225J2G241120800”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.63550
- 100+0.59450
- 500+0.55350
- 2000+0.49200
- 5000+0.47150
- 10000+0.45920
- 国内价格
- 5+0.93223
- 50+0.74509
- 200+0.65151
- 400+0.58134
- 2400+0.52521
- 5000+0.49710
