TPA1861/TPA1862/TPA1864
40-V, 6-MHz, Zero-Drift Op Amps
Features
Description
The TPA186x is a series of the newest high-supplyvoltage amplifiers with 30-μV low offset, low noise, and
stable high-frequency response. The TPA186x series
incorporates 3PEAK’s proprietary and patented design
techniques to achieve excellent AC performance with 6MHz bandwidth, 5-V/μs slew rate, and low distortion, while
drawing only 1.4-mA quiescent current per amplifier. The
common-mode input voltage range extends to V−, and the
outputs swing rail-to-rail.
Supply Voltage: 4.5 V to 40 V or ±2.25 V to ±20 V
Offset Voltage: ±30 μV Maximum
Differential Input Voltage Range to Supply Rail, can
Work as Comparator
Input Rail to −VS, Rail-to-Rail Output
Drive Any Capacitive Load
Bandwidth: 6 MHz, Slew Rate: 5 V/μs
Excellent EMI Suppress Performance: 85 dB at 1 GHz
The TPA186x series has an over-temperature protection
feature to guarantee chip safety. The output of
the TPA186x enters high impendence when the die
temperature reaches around 170°C, and recovers
the function when the die temperature is down to
around 150°C. The TPA186x series has a very small
power temperature coefficient, which is beneficial for
temperature-sensitive applications.
Over-Temperature Protection
Low Noise: 8 nV/√Hz at 1 kHz
2-kV HBM, 1-kV CDM, 500-mA Latch Up
−40°C to 125°C Operating Temperature Range
Applications
Instrumentation
Active Filters, ASIC Input, or Output Amplifier
Sensor Interface
Iq(mA)
Motor Control
Industrial Control
3.0
2.8
2.6
2.4
2.2
2.0
1.8
1.6
1.4
1.2
1.0
-50
100
Temperature(℃)
150
Typical Application Circuit
www.3peak.com
1 / 26
AA20230101A7
Table of Contents
Features................................................................................................................................................................1
Applications......................................................................................................................................................... 1
Description........................................................................................................................................................... 1
Typical Application Circuit..................................................................................................................................1
Revision History...................................................................................................................................................3
Pin Configuration and Functions....................................................................................................................... 4
Specifications.......................................................................................................................................................7
Absolute Maximum Ratings (1) .......................................................................................................................7
ESD, Electrostatic Discharge Protection........................................................................................................ 7
Recommended Operating Conditions............................................................................................................ 7
Thermal Information........................................................................................................................................8
Electrical Characteristics................................................................................................................................ 9
Typical Performance Characteristics............................................................................................................ 11
Detailed Description.......................................................................................................................................... 14
Overview.......................................................................................................................................................14
Functional Block Diagram.............................................................................................................................14
Application and Implementation...................................................................................................................... 15
Application Information ................................................................................................................................ 15
Tape and Reel Information................................................................................................................................ 16
Package Outline Dimensions........................................................................................................................... 18
SOT23-5....................................................................................................................................................... 18
SOP8............................................................................................................................................................ 19
MSOP8......................................................................................................................................................... 20
DFN3X3-8.....................................................................................................................................................21
SOP14.......................................................................................................................................................... 22
TSSOP14......................................................................................................................................................23
Order Information.............................................................................................................................................. 24
IMPORTANT NOTICE AND DISCLAIMER......................................................................................................... 25
www.3peak.com
2 / 26
AA20230101A7
Revision History
Date
Revision
Notes
2019-09-10
Rev.Pre.0
Initial version.
2019-11-27
Rev.Pre.1
Removed the part number: TPA1862-TSR;
Added new part numbers: TPA1864-SR, TPA1864-TR.
2020-04-26
Rev.A.0
Added the test figures.
2020-08-01
Rev.A.1
Added more test figures.
2020-11-06
Rev.A.2
Updated the test figures: IQ vs. Temperature, VOUT vs. IOUT.
2021-05-04
Rev.A.3
Added the Tape and Reel Information.
2021-07-07
Rev.A.4
Updated the Absolute Maximum Ratings:
Corrected the maximum value of the input voltage: from (+VS) + 0.3 V to 40 V;
Updated the differential input voltage: (−VS) − (+VS) to (+VS) − (−VS).
Updated to a new document format;
2022-08-18
Rev.A.5
Updated the working voltage to 40 V, and the absolute rating voltage to 42 V;
Added a new package: TPA1862-DF7R.
2022-12-28
Rev.A.6
Updated to a new document format.
The following updates are all about the new datasheet formats or typos, and the
2024-12-19
www.3peak.com
Rev.A.7
actual product remains unchanged.
Updated the Package Outline Dimensions.
Updated the Tape and Reel Information.
3 / 26
AA20230101A7
TPA1861
SOT23-5 Package
Top View
Out
1
TPA1861
SOP8 Package
Top View
+Vs
5
Part Number
NC
11
88
NC
−IN
22
77
+Vs
+IN
33
66
OUT
−Vs
4
55
NC
2
−Vs
+In
4
3
−In
Table 1. Pin Functions: TPA1861
Pin No.
Name
I/O
6
Out
O
2
4
−VS
3
3
+In
I
Non-inverting input.
4
2
−In
I
Inverting input.
5
7
+VS
Positive power supply.
1
NC
Not connect.
5
NC
Not connect.
8
NC
Not connect.
SOT23-5
SOP8
1
www.3peak.com
Description
Output.
Negative power supply.
4 / 26
AA20230101A7
TPA1862
TPA1862
SOP8 Package
Top View
MSOP8 Package
Top View
Out A
11
88
+Vs
−In A
22
77
Out B
+In A
33
66
−In B
−Vs
4
55
+In B
Out A
1
8
+Vs
−In A
2
7
Out B
+In A
3
6
−In B
−Vs
4
5
+In B
TPA1862
DFN3X3-8 Package
Top View
Out A
1
8
+Vs
−In A
2
7
Out B
+In A
3
6
−In B
−Vs
4
5
+In B
Table 2. Pin Functions: TPA1862
Pin No.
SOP8
Name
I/O
1
Out A
O
Output.
2
−In A
I
Inverting input.
3
+In A
I
4
−VS
5
+In B
I
6
−In B
I
Inverting input.
7
Out B
O
Output.
8
+VS
MSOP8
www.3peak.com
DFN3X3-8
Description
5 / 26
AA20230101A7
TPA1864
SOP14 Package
Top View
TPA1864
TSSOP14 Package
Top View
Out A
1
14
Out D
−In A
2
13
−In D
+In A
+Vs
+In B
3
+In D
12
4
−Vs
11
5
+In C
10
−In B
6
9
−In C
Out B
7
8
Out C
Out A
1
14
Out D
−In A
2
13
−In D
+In A
3
12
+In D
+Vs
4
11
−Vs
+In B
5
10
+In C
−In B
6
9
−In C
Out B
7
8
Out C
Table 3. Pin Functions: TPA1864
Pin No.
Name
I/O
1
Out A
O
Output.
2
−In A
I
Inverting input.
3
+In A
I
4
+VS
5
+In B
I
6
−In B
I
Inverting input.
7
Out B
O
Output.
8
Out C
O
Output.
9
−In C
I
Inverting input.
10
+In C
I
11
−VS
12
+In D
I
13
−In D
I
Inverting input.
14
Out D
O
Output.
SOP14
TSSOP14
www.3peak.com
Description
6 / 26
AA20230101A7
Specifications
All test conditions: over operating ambient temperature, unless otherwise noted.
Parameter
Min
Max
Unit
42
V
(−VS) – 0.3
42
V
(−VS) − (+VS)
(+VS) − (−VS)
V
−10
10
mA
(−VS) − 0.3
(+VS) + 0.3
V
Supply Voltage, (+VS) − (−VS)
Input Voltage
Input Current: +IN, −IN
(2)
Output Voltage
Output Short-Circuit Duration
(3)
TJ
Maximum Junction Temperature
TA
TSTG
Storage Temperature Range
TL
Lead Temperature (Soldering, 10 sec)
Infinite
150
°C
−40
125
°C
−65
150
°C
260
°C
(1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure
to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime.
(2) The inputs are protected by ESD protection diodes to the negative power supply. If the input extends to more than 300
mV beyond the negative power supply, the input current should be limited to less than 10 mA.
(3) A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power
supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal
connected to the package. The specified values are for short traces connected to the leads.
Parameter
HBM
CDM
Condition
Human Body Model ESD
Charged Device Model ESD
Minimum Level
Unit
ANSI/ESDA/JEDEC JS-001
(1)
2
kV
ANSI/ESDA/JEDEC JS-002
(2)
1
kV
(1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process.
(2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
Parameter
Min
Typ
Max
Unit
VS
4.5/
±2.25
40/
±20
V
TA
−40
125
°C
www.3peak.com
7 / 26
AA20230101A7
Thermal Information
Package Type
θJA
θJC
Unit
SOT23-5
250
81
°C/W
SOP8
158
43
°C/W
MSOP8
210
45
°C/W
SOP14
120
36
°C/W
TSSOP14
180
35
°C/W
www.3peak.com
8 / 26
AA20230101A7
All test conditions: VS = 30 V, TA = 25°C, RL = 10 kΩ, unless otherwise noted.
Parameter
Conditions
TA
Min
Typ
Max
Unit
40/
±20
V
Power Supply
VS
IQ
Supply Voltage Range
Quiescent Current per
Amplifier
4.5/
±2.25
VS = 40 V
1.6
2
mA
1.4
1.6
mA
−40°C to 125°C
1.8
mA
1.2
1.5
mA
−40°C to 125°C
1.7
mA
125
140
dB
−40°C to 125°C
120
dB
−30
30
μV
−30
30
μV
−40°C to 125°C
−50
50
μV
−30
30
μV
−40°C to 125°C
−50
50
μV
−40°C to 125°C
0.01
0.2
μV/°C
100
pA
−40°C to 125°C
100
pA
100
pA
10
100
μA
−40°C to 125°C
120
μA
Differential mode
5
pF
Common mode
2.5
pF
VS = 30 V
VS = 5 V
PSRR
Power Supply Rejection
Ratio
VS = 4.5 V to 36 V
Input Characteristics
VS = 40 V, VCM = 20 V
VOS
Input Offset Voltage
VS = 30 V, VCM = 15 V
VS = 5 V, VCM = 2.5 V
VOSTC
Input Offset Voltage Drift
IB
Input Bias Current
IOS
Input Offset Current
IIN
Different Input Current
VS = 36 V, VID = 36 V
CIN
Input Capacitance
Av
Open-Loop Voltage Gain
RLOAD = 10 kΩ,
VOUT = 0.5 V to 29.5 V
130
140
dB
−40°C to 125°C
125
dB
VCMR
Common-Mode Input
Voltage Range
(V−)
(V+) –
1.5
V
CMRR
Common-Mode Rejection
Ratio
VCM = 0 V to 28.5 V
125
140
dB
−40°C to 125°C
120
dB
10
15
mV
−40°C to 125°C
30
mV
75
100
mV
−40°C to 125°C
180
mV
Output Characteristics
Output Swing from Positive
Rail
www.3peak.com
RLOAD = 100 kΩ to VS / 2
RLOAD = 10 kΩ to VS / 2
9 / 26
AA20230101A7
Parameter
Conditions
Min
Typ
Max
Unit
400
500
mV
−40°C to 125°C
750
mV
3
5
mV
−40°C to 125°C
10
mV
25
35
mV
−40°C to 125°C
60
mV
130
150
mV
−40°C to 125°C
300
mV
60
95
mA
−40°C to 85°C
40
mA
−40°C to 125°C
35
mA
130
150
mA
−40°C to 85°C
100
mA
−40°C to 125°C
85
mA
1
nF
6
MHz
3
5
V/μs
−40°C to 125°C
2.2
V/μs
500
ns
7
μs
12
μs
RLOAD = 2 kΩ to VS / 2
Output Swing from Negative
Rail
Source
ISC
Output Short-Circuit Current
Sink
Capacitive Load Drive
TA
AC Specifications
GBW
Gain-Bandwidth Product
SR
Slew Rate
G = 1, 10-V step
tOR
Overload Recovery
tS
Settling Time, 0.1%
Settling Time, 0.01%
G = 1, 10-V step
PM
Phase Margin
RL = 10 K, CL = 100 pF
70
GM
Gain Margin
15
dB
f = 0.1 Hz to 10 Hz
0.1
μVPP
f = 0.1 Hz
8
nV/√Hz
f = 1 kHz
8
nV/√Hz
f = 10 kHz
10
nV/√Hz
f = 100 kHz
nV/√Hz
Noise Performance
EN
eN
Input Voltage Noise
Input Voltage Noise Density
iN
Input Current Noise
f = 10 kHz
200
fA/√Hz
THD+N
Total Harmonic Distortion
and Noise
f = 1 kHz, G =1, RL = 10
kΩ, VOUT = 6 VRMS
0.0005
www.3peak.com
10 / 26
AA20230101A7
All test conditions: VS = ±15 V, VCM = 0 V, RL = 10 kΩ, unless otherwise noted.
3.00
2.50
2.00
5
IQ(mA)
Vos(uV)
10
1.50
1.00
-10
0.50
-15
-20
0.00
-15
-10
-5
Vcom(V)
5
10
15
±VCC(V)
15
Figure 2. IQ vs. Supply Voltage
3
3
2.8
2.8
2.6
2.6
2.4
2.4
2.2
2.2
Iq(mA)
Iq(mA)
Figure 1. Offset Voltage vs. Common-Mode Voltage
5
2
1.8
2
1.8
1.6
1.6
1.4
1.4
1.2
1.2
1
1
-50
Temperature(℃)
100
-50
150
Figure 3. IQ vs. Temperature, ±2.5-V Supply, TPA1862
Temperature(℃)
100
150
Figure 4. IQ vs. Temperature, ±15-V Supply, TPA1862
160
140
EMIRR(dB)
120
100
80
60
40
100M
1000M
Frequecy(Hz)
Figure 5. EMIRR vs. Frequency
www.3peak.com
Figure 6. Open-Loop Gain and Phase vs. Frequency, RL
= 10 kΩ, CL = 50 pF
11 / 26
AA20230101A7
120
120
PSRR+
100
PSRR-
100
80
CMRR(dB)
PSRR(dB)
140
80
60
60
40
40
1K
10K
Frequency(Hz)
100K
1M
Figure 7. PSRR vs. Frequency
10K
100K
Frequency(Hz)
Figure 8. CMRR vs. Frequency
Time: 2 μs/div, Measure Time: 260 ns
Time: 2 μs/div, Measure Time: 420 ns
RL = 2 K, CL = 100 pF, G = 10
Figure 9. Positive Overload Recovery
Figure 10. Negative Overload Recovery
Voltage: 50 mV/div, Time: 2 μs/div
Voltage: 2 V/div, Time: 2 μs/div
Figure 11. 100-mV Signal Step Response
www.3peak.com
1M
Figure 12. 10-V Signal Step Response
12 / 26
AA20230101A7
12
0.001
10
0.0008
8
0.0006
6
0.0004
4
0.0002
2
100
1K
Frequency(Hz)
10K
100K
Figure 13. Voltage Noise Density vs. Frequency
16
-4
14
-6
12
-8
10
-40℃ TPA1862
25℃ TPA1862
85℃ TPA1862
125℃ TPA1862
8
6
5K
10K
Frequency(Hz)
15K
20K
Figure 14. THD vs. Frequency, G = 1
Vout(V)
Vout (V)
3.5Vrms_40KHz Filter
3.5Vrms_A Weighting Filter
6Vrms_40KHz Filter
6Vrms_A Weighting Filter
THD+N(%)
Equivalent Input Voltage
Noise(nV/√Hz)
-40℃
TPA1862
25℃ TPA1862
85℃ TPA1862
-10
-12
-14
-16
4
60
Iout (mA)
80
100
Iout(mA)
150
200
Figure 16. VOUT vs. IOUT, Sink
Figure 15. VOUT vs. IOUT, Source
www.3peak.com
50
13 / 26
AA20230101A7
Overview
The TPA186x is a series of the newest high-supply-voltage amplifiers. The TPA186x series can operate on a single-supply
voltage (4.5 V to 40 V), or a split-supply voltage (±2.25 V to ±20 V), making them highly versatile and easy to use.
The power-supply pins should have local bypass ceramic capacitors (typically 0.01 μF to 0.1 μF). Parameters that exhibit
variance with regard to the operating voltage or temperature are presented in the Typical Performance Characteristics.
Figure 17. Functional Block Diagram
www.3peak.com
14 / 26
AA20230101A7
Note
Information in the following application sections is not part of the 3PEAK’s component specification and 3PEAK does not
warrant its accuracy or completeness. 3PEAK’s customers are responsible for determining suitability of components for
their purposes. Customers should validate and test their design implementation to confirm system functionality.
Low-Side Current Sensing Application
Figure 18 shows the device configured in a low-side current sensing application. The low-side current sensing method is
to place a sense resistor between the load and the circuit ground. The voltage dropping across the resistor is amplified by
different amplifier circuits with the device. VREF can be used to add bias voltage to the output voltage. Particular attention
must be paid to the matching and precision of R1, R2, R3, and R4, to maximize the accuracy of the measurement.
Figure 18. Low-Side Current Sensing Application
Power Supply Recommendations
Place 0.1-μF bypass capacitors close to the power supply pins to reduce coupling errors from the noisy or high-impedance
power supplies.
www.3peak.com
15 / 26
AA20230101A7
Order Number
Package
D1
(mm)
W1
(mm)
A0
B0
K0
(mm) (1) (mm) (1) (mm) (1)
P0
(mm)
W0
(mm)
Pin1
Quadrant
TPA1861-SR
SOP8
330
17.6
6.5
5.4
2
8
12
Q1
TPA1861-TR
SOT23-5
180
12
3.3
3.25
1.4
4
8
Q3
TPA1862-DF7R
DFN3X3-8
330
17.6
3.3
3.3
1.1
8
12
Q2
TPA1862-SR
SOP8
330
17.6
6.5
5.4
2
8
12
Q1
TPA1862-VR
MSOP8
330
17.6
5.3
3.4
1.3
8
12
Q1
TPA1864-SR
SOP14
330
21.6
6.5
9.3
2.1
8
16
Q1
www.3peak.com
16 / 26
AA20230101A7
Order Number
TPA1864-TR
Package
TSSOP14
D1
(mm)
W1
(mm)
330
17.6
A0
B0
K0
6.8
5.5
1.5
P0
(mm)
W0
(mm)
Pin1
Quadrant
8
12
Q1
(1) The value is for reference only. Contact the 3PEAK factory for more information.
www.3peak.com
17 / 26
AA20230101A7
SOT23-5
www.3peak.com
18 / 26
AA20230101A7
SOP8
www.3peak.com
19 / 26
AA20230101A7
MSOP8
www.3peak.com
20 / 26
AA20230101A7
DFN3X3-8
www.3peak.com
21 / 26
AA20230101A7
SOP14
www.3peak.com
22 / 26
AA20230101A7
TSSOP14
www.3peak.com
23 / 26
AA20230101A7
Order Information
Range
Package
Marking Information
MSL
Transport Media, Quantity
Eco Plan
TPA1861-SR
−40 to 125°C
SOP8
1861
3
Tape and Reel, 4000
Green
TPA1861-TR
−40 to 125°C
SOT23-5
A86
3
Tape and Reel, 3000
Green
TPA1862-SR
−40 to 125°C
SOP8
1862
3
Tape and Reel, 4000
Green
TPA1862-VR
−40 to 125°C
MSOP8
1862
3
Tape and Reel, 3000
Green
TPA1862-DF7R
−40 to 125°C
DFN3X3-8
A1862
3
Tape and Reel, 4000
Green
TPA1864-SR
−40 to 125°C
SOP14
1864
3
Tape and Reel, 2500
Green
TPA1864-TR
−40 to 125°C
TSSOP14
1864
3
Tape and Reel, 3000
Green
Order Number
Green: 3PEAK defines "Green" to mean RoHS compatible and free of halogen substances.
www.3peak.com
24 / 26
AA20230101A7
Copyright© 3PEAK 2012-2025. All rights reserved.
Trademarks. Any of the 思瑞浦 or 3PEAK trade names, trademarks, graphic marks, and domain names contained in
this document /material are the property of 3PEAK. You may NOT reproduce, modify, publish, transmit or distribute any
Trademark without the prior written consent of 3PEAK.
Performance Information. Performance tests or performance range contained in this document/material are either results
of design simulation or actual tests conducted under designated testing environment. Any variation in testing environment or
simulation environment, including but not limited to testing method, testing process or testing temperature, may affect actual
performance of the product.
Disclaimer. 3PEAK provides technical and reliability data (including data sheets), design resources (including reference
designs), application or other design recommendations, networking tools, security information and other resources "As Is".
3PEAK makes no warranty as to the absence of defects, and makes no warranties of any kind, express or implied, including
without limitation, implied warranties as to merchantability, fitness for a particular purpose or non-infringement of any thirdparty’s intellectual property rights. Unless otherwise specified in writing, products supplied by 3PEAK are not designed to
be used in any life-threatening scenarios, including critical medical applications, automotive safety-critical systems, aviation,
aerospace, or any situations where failure could result in bodily harm, loss of life, or significant property damage. 3PEAK
disclaims all liability for any such unauthorized use.
www.3peak.com
25 / 26
AA20230101A7
This page intentionally left blank
www.3peak.com
26 / 26
AA20230101A7
