TPC112S4-TR
TPC112S4-TR
    3PEAK(思瑞浦)
    TSSOP-16
    16/12位低功耗高性能DAC
TPC112S4-TR 数据手册
TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Features Description • Quad, 16-/12-Bit Pin Compatible DACs • – TPC116S4: 16 Bits – TPC112S4: 12 Bits • Low Power Consumption (800 μA typ) • Differential Nonlinearity: ±1 LSB (Max) • Glitch Energy: 2 nV-s • Power-on Reset to Zero • Supply Range: 2.7 V to 5.5 V • Buffered Rail-to-Rail Output Operation • Safe Power-on Reset (POR) to Zero DAC Output • Fast 30-MHz, 3-Wire SPI/QSPI/MICROWIRE- The TPC116S4/TPC112S4 are pin-compatible 16-bit and 12-bit digital-to-analog converters. The products are fourchannel, low-power, and buffered voltage-out DACs, which are guaranteed monotonic by design. The devices use a precision external reference applied through the highresistance input for rail-to-rail operation and low system power consumption. The TPC116S4/TPC112S4 accept a wide range of 2.7-V to 5.5-V supply voltage. The parts incorporate a power-on reset circuit to ensure that the DAC output powers up to 0 V and remains there until a valid write takes place. The on-chip precision output amplifiers of the TPC116S4/ TPC112S4 allow rail-to-rail output swing to be achieved. For remote sensing applications, the inverting input of the output amplifier is available to users. The TPC116S4/ TPC112S4 use a versatile 3-wire serial interface that operates at clock rates up to 30 MHz and is compatible with standard SPI®, QSPI™, MICROWIRE™, and DSP interface standards. Compatible Serial Interface • • • • Schmitt-Trigger Inputs for Direct Optocoupler Interface SYNC Interrupt Facility High-Performance Drop-in Compatible with TLV5614 Available in TSSOP16 Package The TPC116S4/TPC112S4 are available in the small-sized TSSOP16 package. All packages are specified over the −40°C to +125°C extended industrial temperature range. Applications • • • • • Gain and Offset Adjustment Process Control and Servo Loops Programmable Voltage and Current Sources Programmable Attenuators Automatic Test Equipment Typical Application Circuit www.3peak.com 1 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Table of Contents Features................................................................................................................................................................1 Applications......................................................................................................................................................... 1 Description........................................................................................................................................................... 1 Typical Application Circuit..................................................................................................................................1 Revision History...................................................................................................................................................3 Pin Configuration and Functions....................................................................................................................... 4 Specifications.......................................................................................................................................................6 Absolute Maximum Ratings (1)........................................................................................................................6 ESD, Electrostatic Discharge Protection........................................................................................................ 6 Thermal Information........................................................................................................................................6 Electrical Characteristics................................................................................................................................ 7 Timing Characteristics.................................................................................................................................... 8 Typical Performance Characteristics............................................................................................................ 10 Detailed Description.......................................................................................................................................... 13 Overview.......................................................................................................................................................13 Functional Block Diagram.............................................................................................................................13 Application and Implementation...................................................................................................................... 14 Application Information ................................................................................................................................ 14 Typical Application........................................................................................................................................15 Tape and Reel Information................................................................................................................................ 16 Package Outline Dimensions........................................................................................................................... 17 TSSOP16......................................................................................................................................................17 Order Information.............................................................................................................................................. 18 IMPORTANT NOTICE AND DISCLAIMER......................................................................................................... 19 www.3peak.com 2 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Revision History Date Revision 2022-12-05 Rev.A.4 Updated the Functional Block Diagram. 2024-12-03 Rev.A.5 Updated to a new datasheet format. www.3peak.com Notes 3 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Pin Configuration and Functions TPC11xS4 TSSOP16 Top View NC 1 16 VDD NC 2 15 REFIN LDAC 3 14 OUTA DIN 4 13 OUTB SCLK 5 12 OUTC NC 6 11 OUTD SYNC 7 10 NC GND 8 9 GND Table 1. Pin Functions Pin No. Name I/O 1 NC NC Not connect. 2 NC NC Not connect. Load DAC. DI • • The DAC outputs are only updated when the LDAC is low. DI • • • • • • • Schmitt-Trigger logic input. 3 4 5 LOAD DIN SCLK 6 NC DI NC Description When the LOAD signal is high, no DAC output updates occur when the input digital data is read into the serial interface. Serial data input. Data is clocked into the 16-/24-bit input shift register on each falling edge of the serial clock input. Serial clock input. Data can be transferred at rates up to 30 MHz. Schmitt-Trigger logic input. Not connect. • • • Level-triggered control input (active LOW). This is the frame synchronization signal for the input data. 7 SYNC DI 8 GND P Ground reference point for all circuitry on the part. 9 GND P Ground reference point for all circuitry on the part. 10 NC NC Not connect. 11 OUTD AO DACD output. 12 OUTC AO DACC output. 13 OUTB AO DACB output. 14 OUTA AO DACA output. www.3peak.com When SYNC goes low, it enables the input shift register, and the data is transferred in on the falling edges of the following clocks. 4 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Pin No. Name I/O 15 REFIN AI Reference voltage input. 16 VDD P Power supply input. www.3peak.com Description 5 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Specifications Absolute Maximum Ratings (1) Parameter Supply Voltage, VDD – GND Min Input Voltage Input Current: +IN, −IN (3) Output Short-Circuit Duration Max Unit 7 V GND – 0.3 VDD + 0.3 V −20 20 mA (2) (4) Indefinite TJ Maximum Junction Temperature TA Operating Temperature Range TSTG Storage Temperature Range TL Lead Temperature (Soldering 10 sec) 150 °C −40 125 °C −65 150 °C 260 °C (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. (2) The supplies must be established simultaneously, with, or before, the application of any input signals. (3) The inputs are protected by ESD protection diodes to the negative power supply. If the input extends more than 500 mV beyond the negative power supply, the input current should be limited to less than 10 mA. (4) A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. The thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD, Electrostatic Discharge Protection Symbol HBM Parameter Condition Human Body Model ESD CDM Charged Device Model ESD Minimum Level Unit ANSI/ESDA/JEDEC JS-001 (1) 8 kV ANSI/ESDA/JEDEC JS-002 (2) 2 kV (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Thermal Information Package Type TSSOP16 www.3peak.com θJA θJC Unit 180 35 °C/W 6 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Electrical Characteristics All test conditions: VDD = 5 V, VREF = 5 V, CL = 100 pF, RL = 10 kΩ, TA = −40℃ to +105°C, unless otherwise noted. Typical values are at TA = +25℃. Symbol Parameter Conditions Min Typ Max Unit Static Accuracy (1) N Resolution INL Integral Nonlinearity DNL Differential Nonlinearity TPC112S4 12 TPC116S4 16 TPC112S4 (12-bit) (2) −2 ±0.25 2 −16 ±8 16 TPC112S4 (12-bit) (2) −1 ±0.05 1 TPC116S4 (16-bit) (2) −1 ±0.5 1 6.5 30 mV 0 30 mV TPC116S4 (16-bit) (2) Zero Offset Error OE Full-Scale Offset Error −30 Offset-Error Drift GE Bits ±1 Gain Error −0.3 Gain Temperature Coefficient ±0.13 LSB LSB μV/°C 0.3 %FS ppmFS/° ±2 C Reference Input VREF Reference-Input Voltage Range RREF Reference-Input Impedance 0.5 VDD 333 V kΩ DAC Output Output Voltage Range 0 DC Output Impedance CL RL Capacitive Load (3) Resistive Load VREF 0.1 V Ω Series resistance = 0 Ω 0.1 nF Series resistance = 1 kΩ 15 μF (3) 5 kΩ Short-Circuit Current VDD = 5.5 V 35 mA Power-up Time From power-down mode 25 μs Digital Inputs (SCLK, DIN, SYNC) VDD = 5 V 2 V 1.5 V VIH Input High Voltage VIL Input Low Voltage IIN Input Leakage Current CIN Input Capacitance 1 pF VHYS Hysteresis Voltage 0.15 V 1 V/μs VDD = 3.3 V VDD = 5 V 0.6 V VDD = 3.3 V 0.4 V ±10 μA VIN = 0 V or VDD ±5 Dynamic Performance (3) SR Voltage-Output Slew Rate www.3peak.com Positive and negative 7 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Symbol BW Parameter Conditions Min Typ Max Unit Voltage-Output Settling Time 1/4 scale to 3/4 scale, to ≤ 0.5 LSB, 12 bits 14 μs Reference −3-dB Bandwidth Hex code = 800 (TPC112S4), Hex code = 8000 (TPC116S4) 100 kHz Digital Feedthrough Code = 0, all digital inputs from 0 V to VDD, SCLK < 50 MHz 0.5 nV·s DAC Glitch Impulse Major code transition 2 nV·s Output Noise 10 kHz 90 nV/√Hz Integrated Output Noise 0.1 Hz to 10 Hz 25 μVP-P Power Requirements VDD Supply Voltage 2.7 5.5 V 0.8 1.5 mA 0.5 1 mA 500 μA VDD = 5 V, no load; all digital IDD inputs at 0 V or VDD, supply current only; excludes reference input current, midscale Supply Current VDD = 3.3 V, no load; all digital IDD inputs at 0 V or VDD, supply current only; excludes reference input current, midscale Supply Current Power-down Supply Current No load, all digital inputs at 0 V or VDD (1) Linearity is tested within 20 mV of GND and VDD. (2) Gain and offset are tested within 100 mV of GND and VDD. (3) All timing specifications are measured with VIL = VGND, VIH = VDD. Timing Characteristics Figure 1. 16-Bit Serial-Interface Timing Diagram (TPC112S4) Figure 2. 24-Bit Serial-Interface Timing Diagram (TPC116S4) www.3peak.com 8 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Figure 3. LDAC Timing Diagram Table 2. Timing Characteristics (Figures 1, 2 and 3) Symbol Parameter Conditions Min Typ Max Units 30 MHz fSCLK Serial Clock Frequency 0 tCH SCLK Pulse-Width High 8 ns tCL SCLK Pulse-Width Low 8 ns tCSS0 SYNC Fall to SCLK Fall Setup Time 8 ns tCSH0 SYNC Fall to SCLK Fall Hold Time 0 ns tCSH1 SYNC Rise to SCLK Fall Hold Time 0 ns tCSA SYNC Rise to SCLK Fall tCSF SCLK Fall to SYNC Fall tDS 12 ns 100 ns DIN to SCLK Fall Setup Time 5 ns tDH DIN to SCLK Fall Hold Time 4.5 ns tCSPW SYNC Pulse-Width High 20 ns tCLPW SYNC Pulse-Width Low 20 ns tCSC SYNC Rise to SYNC Fall 20 ns tL1 SCLK Falling Edge to LDAC Falling Edge for Asynchronous LDAC Update 50 ns tL2 LDAC Pulse Width LOW Time 50 ns www.3peak.com 9 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Typical Performance Characteristics All test conditions: VS = 5 V, TA = +25℃, unless otherwise noted. Figure 4. INL and DNL vs. Digital Input Code (+25℃ TPC116S4) Figure 5. INL and DNL vs. Digital Input Code (−40°C TPC116S4) Figure 6. INL and DNL vs. Digital Input Code (+105°C TPC116S4) Figure 7. Power-Supply Current vs. Temperature (TPC116S4) Figure 8. Power-Supply Current vs. Temperature (TPC116S4) Figure 9. Zero-Scale Error vs. Temperature (TPC116S4) www.3peak.com 10 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Figure 10. Zero-Scale Error vs. Temperature (TPC116S4) Figure 11. Full-Scale Error vs. Temperature (TPC116S4) Figure 12. Full-Scale Error vs. Temperature (TPC116S4) Figure 13. Source and Sink Current Capability (TPC116S4) Figure 14. Source and Sink Current Capability (TPC116S4) Figure 15. Supply Current vs. Logic Input Voltage (TPC116S4) www.3peak.com 11 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Figure 16. Supply Current vs. Logic Input Voltage (TPC116S4) Figure 17. Supply Current vs. Supply Voltage (TPC116S4) Figure 18. Full-Scale Settling Time (2.7-V Falling Edge) Figure 19. Full-Scale Settling Time (5-V Falling Edge) Figure 20. Full-Scale Settling Time (5-V Rising Edge) Figure 21. Full-Scale Settling Time (2.7-V Rising Edge) www.3peak.com 12 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Detailed Description Overview The TPC116S4 and TPC112S4 are pin-compatible and software-compatible 12-bit and 16-bit DACs. The TPC116S4 and TPC112S4 are 4-channel, low-power, high-reference input resistance, and buffered voltage-output DACs. The TPC116S4 and TPC112S4 minimize the digital noise feedthrough from their inputs to outputs by powering down the SCLK and DIN input buffers after the completion of each data frame. The data frames are 16 bits for the TPC112S4 and 24 bits for the TPC116S4. During power up, the TPC116S4 and TPC112S4 reset the DAC output to zero, providing additional safety for applications that drive valves or other transducers which need to be off during power up. The TPC116S4 and TPC112S4 contain a segmented resistor string-type DAC, a serial-in/parallel-out shift register, a DAC register, a power-on-reset (POR) circuit, and control logic. On the falling edge of the clock (SCLK) pulse, the serial input (DIN) data is shifted into the device, MSB first. Functional Block Diagram Figure 22. Functional Block Diagram www.3peak.com 13 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Application and Implementation Note Information in the following application sections is not part of the 3PEAK’s component specification and 3PEAK does not warrant its accuracy or completeness. 3PEAK’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. Application Information DAC Reference (REF) The external reference input features a typical input impedance of 333 kΩ and accepts an input voltage from +2 V to VDD. Connect an external voltage supply between REF and GND to apply an external reference. Serial Interface The 3-wire serial interface of the TPC116S4/TPC112S4 is compatible with MICROWIRE, SPI, QSPI, and DSP. The interface provides three inputs: SCLK, SYNC, and DIN. The chip-select input (SYNC) frames the serial data loading at DIN. Following a chip-select input high-to-low transition, the data is shifted synchronously and latched into the input register on each falling edge of the serial-clock input (SCLK). Each serial word is 16 bits for the TPC112S4 and 24 bits for the TPC116S4. The first 3 bits are the control bits followed by 1 power-down bit as well as 12 data bits (MSB first) for the TPC112S4 and 22 data bits (MSB first) for the TPC116S4 as shown in Table 3 and Table 4. The serial input register transfers its contents to the input registers after loading 16/24 bits of data and updates the DAC output immediately after the data is received on the 16-/24-bit falling edge of the clock. To initiate a new data transfer, SYNC is driven high and kept for a minimum of 20 ns before the next write sequence. The SCLK can be either high or low between SYNC write pulses. Figure 1 and Figure 2 show the timing diagrams for the complete 3-wire serial interface transmission. The DAC code of the TPC116S4 is unipolar binary with VOUT = (code / 65,536) × VREF, while that of the TPC112S4 is unipolar binary with VOUT = (code / 4096) × VREF. Table 3. Operating Mode Truth Table (TPC112S4) 16-Bit Word A2 A1 A0 PD DAC Data Bit D15 D14 D13 D12 D11~D0 1 0 0 0 X Update DAC A Data 1 0 1 0 X Update DAC B Data 1 1 0 0 X Update DAC C Data 1 1 1 0 X Update DAC D Data 100 k to GND X X X 1 X Table 4. Operating Mode Truth Table (TPC116S4) Function Power down 24-Bit Word A2 A1 A0 PD DAC Data Bit D23 D22 D21 D20 D19 D18 D17 D16 D15~ D0 X X X X 1 0 0 0 X www.3peak.com 14 / 20 Function Update DAC A Data BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs X X X X 1 0 1 0 X Update DAC B Data X X X X 1 1 0 0 X Update DAC C Data X X X X 1 1 1 0 X Update DAC D Data X X X X X X X 1 X Power down Typical Application Figure 23 shows the typical application schematic. Figure 23. Typical Application Circuit www.3peak.com 15 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Tape and Reel Information Package D1 (mm) W1 (mm) A0 (mm) B0 (mm) K0 (mm) P0 (mm) W0 (mm) Pin1 Quadrant TPC112S4-TR TSSOP16 330 17.6 6.8 5.4 1.3 8 12 Q1 TPC116S4-TR TSSOP16 330 17.6 6.8 5.4 1.3 8 12 Q1 Order Number www.3peak.com 16 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Package Outline Dimensions TSSOP16 www.3peak.com 17 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs Order Information Operating Temperature Range Package Marking Information MSL Transport Media, Quantity Eco Plan TPC112S4-TR −40 to 125°C TSSOP16 112S4 1 Tape and Reel, 3000 Green TPC116S4-TR −40 to 125°C TSSOP16 116S4 1 Tape and Reel, 3000 Green Order Number Green: 3PEAK defines "Green" to mean RoHS compatible and free of halogen substances. www.3peak.com 18 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs IMPORTANT NOTICE AND DISCLAIMER Copyright© 3PEAK 2012-2024. All rights reserved. Trademarks. Any of the 思瑞浦 or 3PEAK trade names, trademarks, graphic marks, and domain names contained in this document /material are the property of 3PEAK. You may NOT reproduce, modify, publish, transmit or distribute any Trademark without the prior written consent of 3PEAK. Performance Information. Performance tests or performance range contained in this document/material are either results of design simulation or actual tests conducted under designated testing environment. Any variation in testing environment or simulation environment, including but not limited to testing method, testing process or testing temperature, may affect actual performance of the product. Disclaimer. 3PEAK provides technical and reliability data (including data sheets), design resources (including reference designs), application or other design recommendations, networking tools, security information and other resources "As Is". 3PEAK makes no warranty as to the absence of defects, and makes no warranties of any kind, express or implied, including without limitation, implied warranties as to merchantability, fitness for a particular purpose or non-infringement of any thirdparty’s intellectual property rights. Unless otherwise specified in writing, products supplied by 3PEAK are not designed to be used in any life-threatening scenarios, including critical medical applications, automotive safety-critical systems, aviation, aerospace, or any situations where failure could result in bodily harm, loss of life, or significant property damage. 3PEAK disclaims all liability for any such unauthorized use. www.3peak.com 19 / 20 BA20241210A5 TPC116S4/TPC112S4 Quad 16-/12-Bit, Low-Power, High-Performance DACs This page intentionally left blank www.3peak.com 20 / 20 BA20241210A5
TPC112S4-TR 价格&库存
很抱歉,暂时无法提供与“TPC112S4-TR”相匹配的价格&库存,您可以联系我们找货
TPC112S4-TR
  • 3000+17.397523000+2.26216
库存:2522
TPC112S4-TR
    • 1+10.54000
    • 100+9.17600
    • 750+8.33900
    • 1500+8.02900
    • 3000+7.75000
    库存:1513
    TPC112S4-TR
    • 1+29.807051+3.87574
    • 10+22.3910110+2.91145
    • 25+20.5307125+2.66956
    • 100+18.48805100+2.40396
    • 250+17.51375250+2.27727
    • 500+16.92642500+2.20090
    • 1000+16.442961000+2.13804
    库存:2522
    TPC112S4-TR
      • 1+15.59180
      • 10+12.99480
      • 30+11.36800
      • 100+9.70200
      库存:100
      TPC112S4-TR
        • 1+17.18280
        • 10+14.32080
        • 30+12.52800
        • 100+10.69200
        • 500+9.86040
        • 1000+9.50400
        库存:1574
        TPC112S4-TR
        • 1+17.18280
        • 10+14.32080
        • 30+12.52800
        • 100+10.69200
        • 500+9.86040
        • 1000+9.50400
        库存:2367
