User
T65 Smart Soldering Iron User Manual
Manual
Pocket Size Soldering Iron
User Manual
User
Manual
Download
Pocket size soldering iron
Contents
Cautions ........................................................................................................................ 3
1. Description ............................................................................................................. 3
2. Specifications ......................................................................................................... 3
3. Parts ....................................................................................................................... 4
4. Interface ................................................................................................................. 4
5. Working voltage .................................................................................................... 4
6. Handheld Sensing.................................................................................................. 5
7. Instructions ............................................................................................................ 5
5.1 Installation ........................................................................................................................... 5
5.2 Work flow description......................................................................................................... 5
5.2.1 Work flow ....................................................................................................................... 5
5.4 Operation............................................................................................................................. 7
5.5 Menu item description......................................................................................................... 8
8. Firmware upgrade ................................................................................................ 9
8.1 Applicable before firmware V1.1.5(virtual serial port) ................................................. 9
8.2 Applicable after firmware V2.0.1(HID) ...................................................................... 10
9. ESD SAFE............................................................................................................ 12
10.
Maintenance ................................................................................................. 13
11.
FAQ ............................................................................................................... 14
12.
Serivices ........................................................................................................ 14
Thank you for purchasing this product. We recommend that you spend some time
reading this user manual in order that you fully understand all the operational features
it offers.
Cautions
1, The temperature of the soldering iron can reach 100~420℃ when it is working. Do not touch
the tip of the soldering iron!
2,
3,
4,
5,
Please keep out of reach of children!
Do not get the machine wet or use it in a humid environment!
Please disconnect the power when not in use for a long time!
Please use a power adapter of 20V or below, otherwise the device will not work properly or
cause damage to the device!
6, When working, the handle temperature can reach about 40°C, which is normal, so don't
worry!
1. Description
T65 smart soldering iron is a multi-functional soldering iron, it has the following
characteristics:
Use Type-C interface for power supply, support PD\QC fast charge protocol.
Use OLED display, the effect is good.
Support 9~20V working voltage range.
Fast heating, can melt tin in 8 seconds (@20V).
Fast temperature recovery, no fear of large solder joints.
Temperature control stability is 2%.
Hand-held induction, smart sleep.
Small size, easy to carry.
Ergonomically designed handle, good grip.
2. Specifications
Max power
65W
Temperature Range
80~420°C
Power port
Type-C
Support fast charge protocol
PD/QC
Operating voltage range
DC 9~20V
Screen
0.87’OLED(128*32Pixel)
Handle size
114mm*16mm*15mm
Tip size
L 100mm,Ø5mm
Machine length (including soldering iron tip)
165mm
Overall weight
26g
User Manual
www.alientek.com
3
3. Parts
Figure 3-1 Parts
Part description:
① Soldering iron tip
② Lock nut
③ Button A
④ Button B
⑤ OLED screen
⑥ Type-C power supply interface
4. Interface
5. Working voltage
The host can be set to obtain any working voltage from the fast charging adapter,
9V\12V\15V\20V (the default setting is 20V). The higher the voltage, the higher the heating
power. Under different working voltages, the working current, power and tin time reference table
is as follows:
Voltage
Current
Power
Tin melting time
20V
>=3.25A
65W
8S
15V
>=2.5A
37.5W
12S
12V
>=2A
24W
17S
9V
1.5A
13.5W
30S
Notice:
1. The T65 smart soldering iron defaults to obtain a working voltage of 20V. If the
maximum output voltage of your adapter is less than 20V, the maximum output
voltage is obtained. For example, if your adapter has a maximum output of 12V,
then get 12V.
2. If your adapter outputs 20V, but the output current is less than 3.25A (that is, the
output power is less than the power required by the soldering iron), and heating
User Manual
www.alientek.com
4
after entering the main UI, the adapter may be powered off and restarted, causing
the screen to restart! (The same is true for other working voltages)
If it restarts when heating occurs, it indicates that the output power of your adapter's current
voltage is not enough for normal operation. Please choose a lower working voltage according to
the adapter's output power. For example, your adapter output: 12V/2.5A, 15V/2A, 20/1.5A, and
the total output power is 30W. Then choose to set the working voltage to 12V.
Setting the working voltage method: press the A&B key at the same time to enter the working
voltage setting in the menu. (Note: When the screen keeps restarting, you should press the
A&B key at the same time when the logo is displayed).
6. Handheld Sensing
The machine has a built-in vibration sensor that can detect vibration and movement.
However, if you hold the host against the table without moving, the vibration is very weak and
may not be detected.
7. Instructions
5.1 Installation
Figure 7-1 Installation
After unpacking, please install it according to the installation diagram.
Note: When inserting the tip of the soldering iron, it is found to be stuck, you can try to
rotate it before inserting it.
5.2.1 Work flow
User Manual
www.alientek.com
5
Figure 7-2 Work flow
After the T65 smart soldering iron is powered on, it displays the logo first, Then it is
prompted to press the A button to enter the main UI (the button heating UI can be set to turn on or
off in the menu. After turning on, the machine will directly enter the main UI). In the button
heating UI, if the A button is not pressed within 10 seconds, it will automatically shut down. In
main UI, which is in a normal working state. The running status can be divided into the following
four types:
Working state (main UI): The soldering iron is heated, and the temperature is constant at
the user's set temperature. If the handle is not used for a period of time (timing 1: sleep time),
it will enter the sleep state.
Sleep state: The soldering iron is heated, and the temperature is constant at the sleep
temperature (the default is 200°). It will exit the dormant state and return to the main UI
when it senses the hand held or presses the button. Otherwise, after a period of time (timing
2: standby time), it will enter the standby state.
Standby state: The soldering iron is not heated. In the same way, it will exit the dormant
state and return to the main UI when it senses a hand held or presses a button. Otherwise, the
temperature of the soldering iron tip will slowly drop, and when it drops to 50°C, it will enter
the shutdown countdown state, and when the countdown ends, it will enter the screen off
state.
Screen off state: The soldering iron is not heating. In this state, the system is running with
low energy consumption, and restarts when it senses a hand held or presses a button.
User Manual
www.alientek.com
6
5.4 Operation
Figure 7-3 Button
Figure 7-4 Temp adjustment
Temperature adjustment: In the main UI, press the A or B to enter the temperature
adjustment UI. After entering, you need to release the button first, and then adjust the target
temperature by clicking or long pressing the button. If you do not operate for a period of time, it
will automatically return to the main UI.
Figure 7-8 Manual shutdown
Manual shutdown: In the main UI, long press B to enter the standby interface, and the
temperature will drop to 50 degrees, and then the machine will shut down. Press any button to
return to the main UI. Note: The handheld sensor will not return to the main interface, which is
different from the standby state of the appeal workflow.
Figure 7-9 Menu operation
Menu operation: In the main UI or other UI, press A and B at the same time to enter the
menu UI. In the menu UI, click A and B to slide the menu up and down. Long press A to exit, long
press B to enter the next menu (parameter setting or parameter selection), and it will exit
automatically when overtime.
Figure 7-5 Parameter setting
Parameter setting: In the parameter setting UI (such as: temperature step, sleep temperature,
sleep time, standby time, etc.), Click A and B to increase or decrease the parameter value, Long
press B or A or timeout will both return, but long press B and timeout will save the parameters,
User Manual
www.alientek.com
7
long press A will not save the parameters! Increase to the maximum value, the right arrow
disappears, decrease to the minimum value, the left arrow disappears.
Figure 7-6 Parameter selection
Parameter selection: In the parameter selection UI (such as: working voltage, temperature
unit, language, etc.), click A and B to slide up and down options, Long press B or A or timeout will
both return, but long press B and timeout will save the parameters, long press A will not save the
parameters!
There are 13 items in the menu. The definition, factory value and adjustable range of each
item are shown in the table below:
Factory
default
Adjustable range
Temperature adjustment step value
10
5-25
3.Sleep Temp
Target temperature after entering sleep
state
200℃
80℃-300℃
4.Sleep Time
The time for the handle to stand still
and enter the sleep state from the
working state
180 秒
0 -1200S
--:(No sleep)
0S:(Sleep immediately)
5.Stdby Time
and enter the standby state from the
sleep state
180 秒
0-1200S
--:(No standby)
0S:(Standby
immediately)
6.Work Vol
Working voltage obtained from the
power adapter
20V
20V
15V
12V
9V
7.Temp Unit
Display temperature unit
Celsius(℃)
Fahrenheit(℉)
Simplified Chinese
English
Traditional
Chinese
Rota 0
Rota 180
Menu item
Definition
1.Vol Info
Display input voltage and current tip
temperature
2.Temp Step
8.Language
Language selection
Simplified
Chinese
9.Rota 180
Rotate the display by 180 degrees, and
the functions of buttons A and B are
Rota 0
User Manual
www.alientek.com
8
reversed. Suitable for left-hand work
mode
10. Po_heat
Turn on and off heat immediately after
power-on
Turn off
11.Temp Trim
Fine tune the error between the actual
temperature and the displayed
temperature
-50~50 ℃
12.Restore
Restore the parameters to the factory
state
13.Ver Info
Show version
Turn on
Turn off
Note:
① Temperature trim method: in working condition, set the target temperature to
350℃, use the soldering iron thermometer to measure the actual temperature after
the temperature is stable, record the error between the target temperature and the
actual temperature (the value can be positive or negative), and then enter the menu
Fill in the error in temp trim value.
② The step of sleep temperature adjustment is fixed at 10℃
③ The step of temperature calibration adjustment is fixed at 1℃
8. Firmware upgrade
port)
Step 1: Scan the QR code below to download the latest firmware (T65_APP. atk).
Download
Step 2: Power off the device, press and hold the B button, then use the USB Type-c cable to
connect to the computer, power on the device, about 4 seconds, the screen displays "Upgrade...",
then release the button. The operation is shown in Figure 6-1 below:
Figure 8-1 Connection
Step 3: When entering the upgrade mode, T65 will be virtualized as a USB serial device. The
port number can be found in the computer device management section. The operation is shown in
Figure 12 below:
User Manual
www.alientek.com
9
Figure 8-2 Port number
Step 4: Open the firmware upgrade software, select the port number, open the serial port,
select the local upgrade mode, and load the T65_APP_Vx.x.atk file, click to start the upgrade and
wait for the upgrade to complete. The operation is shown in Figure 6-4 below.
Figure 8-3 Firmware upgrade
User Manual
www.alientek.com
10
Download
connect to the computer, power on the device, the screen displays "Upgrade...", then release the
button. The operation is shown in Figure 6-5 below:
Figure 8-5 Connection
Step 3: Open the upgrade software (V2.0) and wait for the device to connect automatically or
click reconnect. The connection is successful.The operation is shown in Figure 6-6 below:
Figure 8-6 Connection
User Manual
www.alientek.com
11
Step 4: Firmware select local load, open the downloaded firmware, click Start upgrade, wait
for the upgrade to complete. The operation is shown in Figure 6-7 below:
Figure 6-7 Connection
9. ESD SAFE
When using a fast charging adapter to power the soldering iron tip, there may be induced
electricity. There will be no problem with soldering ordinary components, but some sensitive
components may be damaged. When soldering sensitive components, there are two solutions to
ensure ESD SAFE:
1. Use a fast charging power bank to power the device (recommended).
2. Connect the device to the ground through an adapter board.
STEP:
a) Required materials: 1 power cord, 1 adapter board, 2 C2C cables
b) Cut off the L\N of the power cord and solder the ground wire to the ground pad of the
adapter board.
As shown below:
User Manual
www.alientek.com
12
c) Connect to the power strip, as shown below:
10. Maintenance
When the new tip is used for the first time, it is necessary to heat the tin to 250 °C
first to prevent dry burning oxidation!
When the new tip is used for the first time, there will be a temperature jump
problem, which will stabilize after a few hours of use!
After the soldering iron is used, apply proper tin to the tip of the soldering iron to
prevent oxidation before disconnecting the power supply.
The tip of the soldering iron works normally at a temperature of about 300 to 380 °C.
Do not use it for a long time (more than 420 °C) to avoid the effect of dry burning on
the life of the tip.
Do not force the tip when welding.
User Manual
www.alientek.com
13
If the surface of the tip is not oxidized, use a cloth or other tool to carefully wipe the
surface layer, then heat it to 200 °C and immediately apply tin to the surface to prevent
re-oxidation.
Do not use wet sponge with bright water, semi-dry state is best, otherwise the soldering
iron tip is easy to oxidize.
Do not use flux containing chlorine or excessive acid to avoid corrosion of the surface
11. FAQ
The summary of common problems is shown in Table 8.1:
Problems and phenomena
Solution
Restarts when heating occurs
Check if the output power of the adapter is sufficient
Working voltage setting 20V,
screen only displays 12V
Check the maximum output voltage of the adapter
Handheld sensing failure
Contact after-sales service
Table 8.1 Summary of issues
12. Serivices
1. After – sales Service:
T65 host has a one-year free warranty service in the case of non-artificial
damage. Please contact the dealer for warranty service. Soldering tips are
consumables, if there is no quality problem, once used they will not be
returned.
2. Website
Download
Company
Aliexpress
: www.alientek.com/download
: www.alientek.com
: www.aliexpress.com/store/1102909571
3. Contact US
E-mail
: fae-smt@alientek.com
User Manual
www.alientek.com
14
