Q65113A2872
Q65113A2872
    AMSOSRAM(艾迈斯半导体)
    SMD,3.8x1mm
    发光二极管/LED SMD,3.8x1mm RGB 120° -40℃~+85℃
Q65113A2872 数据手册
www.osram-os.com KRTB AILMS1 DATASHEET KRTB AILMS1 Datasheet   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All reserved | Version 1.5 | 2024-11-27 1 rights KRTB AILMS1 DATASHEET Micro SIDELED® 3806 KRTB AILMS1 This Micro SIDELED® is a RGB device in an SMT package with side emission. Due to its low package height it is ideal for applications in limited space environments and perfect for coupling into lightguides. Applications - Access Control & Security - Material Processing - Appliances & Tools - Projection & Display - Factory Automation - Robotics - Home & Building Automation Features  - Package: SMT package, silicone resin - Chip technology: Thinfilm / Volume emitter on Sapphire (AlInGaN) - Typ. Radiation: 120° (Lambertian emitter) - Color: λdom = 625 nm (● red); λdom = 520 nm (● true green); λdom = 470 nm (● blue) - Corrosion Robustness Class: 1B - ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) - Binned in white color: Cx = 0.313, Cy = 0.329 acc to CIE 1931  - Typ. Luminous Intensity @20mA: red = 690 mcd; green = 1749 mcd; blue = 488 mcd 2 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Ordering Information  Type KRTB AILMS1-5B5C-B1B12   3 | Version 1.5 | 2024-11-27 Ordering Code Q65113A2872 KRTB AILMS1 DATASHEET Maximum Ratings  Parameter Symbol Values ● red Values ● true green Values ● blue Operating Temperature  Top min. max. -40 °C 85 °C -40 °C 85 °C -40 °C 85 °C Storage Temperature  Tstg min. max. -40 °C 100 °C -40 °C 100 °C -40 °C 100 °C Junction Temperature  Tj max. 100 °C 100 °C 100 °C Forward Current  TS = 25 °C IF min. max. 1 mA 30 mA 1 mA 30 mA 1 mA 30 mA Surge Current  t ≤ 10 µs; D = 0.005 ; TS = 25 °C IFS max. 100 mA 100 mA 100 mA ESD withstand voltage  acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD 2 kV 2 kV 2 kV Notes: 1. The product is not designed for reverse operation.   4 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Characteristics  I F = 20 mA; TS = 25 °C  Parameter Symbol Values ● red Values ● true green Values ● blue Dominant Wavelength 1) λdom typ. 625 nm 520 nm 470 nm Spectral bandwidth at 50% Irel,max  ∆λ typ. 15 nm 26 nm 20 nm Viewing angle at 50% IV  2φ typ. 120 ° 120 ° 120 ° Forward Voltage 2) IF = 20 mA VF min. typ. max. 1.9 V 2.2 V 2.5 V 2.8 V 3.0 V 3.4 V 2.9 V 3.1 V 3.5 V Real thermal resistance junction/solderpoint 3) RthJS real typ. max. 160 K / W 200 K / W 190 K / W 220 K / W 210 K / W 250 K / W Electrical thermal resistance junction/ solderpoint 3) with optical efficiency of each color RthJS elec. typ. max. 120 K / W 150 K / W 150 K / W 170 K / W 130 K / W 160 K / W Notes: 1. Efficiency of each color: Red 24%; Green 22%; Blue 39%   5 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Brightness Groups  IF(● red) = 20 mA; IF(● green) = 15 mA; IF(● blue) = 7 mA Group Luminous Intensity 4) IF = f(T); all chips on  min. Iv Luminous Intensity 4) IF = f(T); all chips on  max. Iv 5B 1800 mcd 2010 mcd 6B 2010 mcd 2240 mcd 7B 2240 mcd 2500 mcd 8B 2500 mcd 2800 mcd 5C 2800 mcd 3150 mcd   6 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Chromaticity Coordinate Groups IF(● red) = 20 mA; IF(● true green) = 15 mA; IF(● blue) = 7 mA Chromaticity Coordinate Groups  Group Cx Cy Group Cx Cy Group Cx Cy B1 0.2890 0.3635 B2 0.2830 0.3405 B6 0.3050 0.3405 0.2950 0.3865 0.2890 0.3635 0.3110 0.3635 0.3170 0.3865 0.3110 0.3635 0.3330 0.3635 0.3110 0.3635 0.3050 0.3405 0.3270 0.3405 0.3270 0.3405 0.2770 0.3175 0.2990 0.3175 0.3330 0.3635 0.2830 0.3405 0.3050 0.3405 0.3550 0.3635 0.3050 0.3405 0.3270 0.3405 0.3490 0.3405 0.2990 0.3175 0.3210 0.3175 0.3210 0.3175 0.2710 0.2945 0.2930 0.2945 0.3270 0.3405 0.2770 0.3175 0.2990 0.3175 0.3490 0.3405 0.2990 0.3175 0.3210 0.3175 0.3430 0.3175 0.2930 0.2945 0.3150 0.2945 0.3150 0.2945 0.3110 0.3635 0.3330 0.3635 0.3210 0.3175 0.3170 0.3865 0.3390 0.3865 0.3430 0.3175 0.3390 0.3865 0.3610 0.3865 0.3370 0.2945 0.3330 0.3635 0.3550 0.3635 B10 B11  B12  7 | Version 1.5 | 2024-11-27 B3 B4 B5 B7 B8 B9 KRTB AILMS1 DATASHEET Group Name on Label  Example: 5B-B1 Brightness Color Chromaticity 5B B1   8 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Relative Spectral Emission 5) Irel = f (λ); IF = 20 mA; TS = 25 °C Irel KRTB AILMS1 1,0 : Vλ : red : green : blue 0,8 0,6 0,4 0,2 0,0 350 400   9 | Version 1.5 | 2024-11-27 450 500 550 600 650 700 750 800 λ / nm KRTB AILMS1 DATASHEET Radiation Characteristic (horizontal) 5) Irel = f (φ); TS = 25 °C Irel KRTB AILMS1 1,0 :red :green :blue 0,8 0,6 0,4 0,2 0,0 -100 -80 -60 -40 -20 0 20 40 60 80 100 ϕ/° Radiation Characteristic (vertical) 5) Irel = f (φ); TS = 25 °C Irel KRTB AILMS1 1,0 0,8 0,6 : red : green : blue  0,4 0,2 0,0 -100 -80 -60 -40 -20 0 20 40 60 80 100  ϕ/° 10 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Forward current Forward current 5) IF = f(VF); TS = 25 °C IF / mA IF = f(VF); TS = 25 °C KRTB AILMS1 30 IF / mA : red 20 20 15 15 10 10 5 5 2,0 2,2 2,4 VF / V 5) IF = f(VF); TS = 25 °C IF / mA : green 25 1 1,7 1,8 KRTB AILMS1 30 : blue  25 20 15 10 5 2,6 2,8  1 2,4 11 | Version 1.5 | 2024-11-27 3,0 3,2 3,3 VF / V KRTB AILMS1 30 25 Forward current 5) 1 2,2 2,4 2,6 2,8 3,0 3,2 VF / V 5), 6) Iv/Iv(20 mA) = f(IF); TS = 25 °C IV(20mA) 1,4 5), 6) Iv/Iv(15 mA) = f(IF); TS = 25 °C KRTB AILMS1 IV Relative Luminous Intensity 30 Relative Luminous Intensity 25 KRTB AILMS1 DATASHEET KRTB AILMS1 IV IV(15mA) 1,6 : red : green 1,4 1,2 1,2 1,0 1,0 0,8 0,8 0,6 0,6 0,4 5), 6) 30 Relative Luminous Intensity 25 IF / mA Iv/Iv(7 mA) = f(IF); TS = 25 °C IV KRTB AILMS1 3,5 IV(7mA) : blue  3,0 2,5 2,0 1,5 1,0 0,5 20 15 10 5 1 0,0  IF / mA 12 | Version 1.5 | 2024-11-27 20 15 10 1 30 25 15 20 0,0 10 0,0 5 0,2 1 0,2 5 0,4 IF / mA KRTB AILMS1 DATASHEET Dominant Wavelength Dominant Wavelength 5) λdom = f(IF); TS = 25 °C λdom = f(IF); TS = 25 °C KRTB AILMS1  dom / nm  dom / nm : red 4 5) KRTB AILMS1 8 : green 6 4 2 2 0 0 -2 -2 -4 IF / mA Dominant Wavelength 5) λdom = f(IF); TS = 25 °C  dom / nm KRTB AILMS1 6 : blue  4 2 0 -2 -4 30 25 20 15 10 5 1 -6  IF / mA 13 | Version 1.5 | 2024-11-27 30 25 20 15 10 5 1 30 25 20 15 10 -6 5 1 -4 IF / mA KRTB AILMS1 DATASHEET Forward Voltage Forward Voltage 5) ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA ∆VF / V ΔVF = VF - VF(25 °C) = f(Tj); IF = 15 mA KRTB AILMS1 KRTB AILMS1 0,4 5) ∆VF / V : red : green 0,4 0,2 0,2 0,0 0,0 -0,2 -0,2 -40 -20 0 Forward Voltage 5) 20 40 60 80 100 Tj / °C ΔVF = VF - VF(25 °C) = f(Tj); IF = 7 mA KRTB AILMS1 ∆VF / V : blue 0,4  0,2 0,0 -0,2 0 20  -40 -20 14 | Version 1.5 | 2024-11-27 40 60 80 100 Tj / °C -40 -20 0 20 40 60 80 100 Tj / °C KRTB AILMS1 DATASHEET Relative Luminous Intensity 5) Iv/Iv(25 °C) = f(Tj); IF = 20 mA Iv Iv(25°C) 1,6 5) Iv/Iv(25 °C) = f(Tj); IF = 15 mA KRTB AILMS1 1,8 Relative Luminous Intensity Iv Iv(25°C) : red KRTB AILMS1 1,4 : green 1,2 1,4 1,0 1,2 1,0 0,8 0,8 0,6 0,6 0,4 0,4 0,2 0,2 0,0 -40 -20 0 20 40 60 Relative Luminous Intensity 80 100 Tj / °C 5) Iv/Iv(25 °C) = f(Tj); IF = 7 mA Iv KRTB AILMS1 1,2 Iv(25°C) : blue  1,0 0,8 0,6 0,4 0,2 0 20  0,0 -40 -20 15 | Version 1.5 | 2024-11-27 40 60 80 100 Tj / °C 0,0 -40 -20 0 20 40 60 80 100 Tj / °C KRTB AILMS1 DATASHEET Dominant Wavelength Dominant Wavelength 5) λdom = f(Tj); IF = 20 mA λdom = f(Tj); IF = 15 mA KRTB AILMS1 10  dom / nm 5)  dom / nm : red KRTB AILMS1 8 : green 6 5 4 2 0 0 -2 -5 -4 -10 -40 -20 -6 0 20 Dominant Wavelength 40 60 80 100 Tj / °C 5) λdom = f(Tj); IF = 7 mA  dom / nm KRTB AILMS1 8 : blue  6 4 2 0 -2 -4 0 20  -6 -40 -20 16 | Version 1.5 | 2024-11-27 40 60 80 100 Tj / °C -40 -20 0 20 40 60 80 100 Tj / °C KRTB AILMS1 DATASHEET Max. Permissible Forward Current 3) IF = f(T); ● red IF / mA 25 20 20 15 10 15 10 5 5 Don't use below 1 mA 0 20 Don't use below 1 mA 40 60 IF = f(T); ● blue 3) 0 40 60 80 Ts / °C Max. Permissible Forward Current all chips on KRTB AILMS1 IF / mA 30  25 KRTB AILMS1 30 25 20 20 15 15 10 10 5 : red : blue : green 5 Don't use below 1 mA 0 20 40  0 20 IF = f(T); all chips on  one chip on blue 0 80 Ts / °C Max. Permissible Forward Current IF / mA KRTB AILMS1 30 25 green red one chip on KRTB AILMS1 30 0 3) IF = f(T); ● true green one chip on IF / mA Max. Permissible Forward Current 17 | Version 1.5 | 2024-11-27 Don't use below 1 mA 60 80 Ts / °C 0 0 20 40 60 80 Ts / °C 3) KRTB AILMS1 DATASHEET Permissible Pulse Handling Capability Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TS = 25 °C; ● red IF = f(tp); D: Duty cycle; TS = 25 °C; ● true green KRTB AILMS1 KRTB AILMS1 TS = 0°C ... 85°C IF / A 0,12 0,10 0,08 0,08 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 0,06 0,04 10-6 10-5 10-4 10-3 0,01 0,1 1 10 Pulse time / s Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TS = 25 °C; ● blue KRTB AILMS1 TS = 0°C ... 63°C IF / A 0,12 0,10 blue 0,12 0,10 green red IF / A TS = 0°C ... 70°C  0,08 0,06 0,04  10-6 10-5 10-4 10-3 0,01 0,1 18 | Version 1.5 | 2024-11-27 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 1 10 Pulse time / s 0,06 0,04 10-6 10-5 10-4 10-3 0,01 0,1 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 1 10 Pulse time / s KRTB AILMS1 DATASHEET Permissible Pulse Handling Capability Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TS = 85 °C; ● red IF = f(tp); D: Duty cycle; TS = 85 °C; ● true green KRTB AILMS1 KRTB AILMS1 TS = 85°C IF / A TS = 85°C IF / A 0,12 0,12 0,10 0,10 green red 0,08 0,08 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 0,06 0,04 10-6 10-5 10-4 10-3 0,01 0,1 1 10 Pulse time / s Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TS = 85 °C; ● blue KRTB AILMS1 TS = 85°C IF / A 0,12 0,10  blue 0,08 0,06 0,04 0,02  10-6 10-5 10-4 10-3 0,01 0,1 19 | Version 1.5 | 2024-11-27 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 1 10 Pulse time / s 0,06 0,04 0,02 10-6 10-5 10-4 10-3 0,01 0,1 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 1 10 Pulse time / s KRTB AILMS1 DATASHEET Dimensional Drawing 7) Further Information: Approximate Weight: 4.7 mg Corrosion test: Class: 1B Test condition: 25°C / 75 % RH / 200ppb SO2, 200ppb NO2, 10ppb H2S, 10ppb Cl2 / 21 days (EN 60068-2-60 (Method 4))   20 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Electrical Internal Circuit Recommended Solder Pad 7)   For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for any kind of wet cleaning or ultrasonic cleaning. 21 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Reflow Soldering Profile Product complies to MSL Level 3 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 22 | Version 1.5 | 2024-11-27 °C 480 s K/s s KRTB AILMS1 DATASHEET Taping 7)   23 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Tape and Reel 8) Reel Dimensions A 180 mm W Nmin 12 + 0.3 / - 0.1 mm   24 | Version 1.5 | 2024-11-27 W1 60 mm W2 max 12.4 + 2 mm 18.4 mm Pieces per PU 3000 KRTB AILMS1 DATASHEET Barcode-Product-Label (BPL) Dry Packing Process and Materials 7) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 25 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit https://ams-osram.com/support/application-notes   26 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on our website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications Our components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. Our products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using our components in product safety devices/ applications or medical devices/applications, buyer and/or customer has to inform our local sales partner immediately and we and buyer and /or customer will analyze and coordinate the customer-specific request between us and buyer and/or customer.   27 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Glossary 1) Wavelength: Wavelengths are tested at a current pulse duration of 25 ms and a tolerance of ±1 nm. 2) Forward Voltage: Forward voltages are tested at a current pulse duration of 1 ms and a tolerance of ±0.1 V. 3) Thermal Resistance: Rth max is based on statistic values (6σ) used for Derating. 4) Brightness: Brightness groups are tested at a current pulse duration of 25 ms and a tolerance of ±11 %. 5) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 6) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 7) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   28 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET Revision History Version Date Change 1.0 2021-06-02 Initial Version 1.1 2021-07-29 Derating (Diagrams) 1.2 2022-01-11 Dimensional Drawing Taping 1.3 2022-07-27 New Layout Applications 1.4 2024-08-15 Maximum Ratings 1.5 2024-11-27 Taping   29 | Version 1.5 | 2024-11-27 KRTB AILMS1 DATASHEET   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All rights reserved 30 | Version 1.5 | 2024-11-27
Q65113A2872 价格&库存
很抱歉,暂时无法提供与“Q65113A2872”相匹配的价格&库存,您可以联系我们找货
Q65113A2872
    Q65113A2872
    • 1+1.86789
    • 30+1.80348
    • 100+1.67466
    • 500+1.54584
    • 1000+1.48143
    • 2000+1.41702
    库存:31
    Q65113A2872
      库存:57000
