MM3Z33VBW
MM3Z33VBW
    TC(德昌)
    SOD-323
    德昌 SOD-323 Zzk: 306Ω Pd:200 mW Vr: 23V
MM3Z33VBW 数据手册
TAK CHEONG ® SEMICONDUCTOR 200mW SOD-323 SURFACE MOUNT Small Outline Flat Lead Plastic Package Zener Voltage Regulators Absolute Maximum Ratings Symbol PD TSTG TOPR Power Dissipation Storage Temperature Range Operating Temperature Range TA = 25°C unless otherwise noted Value 200 -65 to +150 -65 to +150 Units mW °C °C Green Product Parameter These ratings are limiting values above which the serviceability of the diode may be impaired. SOD-323 Flat Lead Specification Features: Wide Zener Voltage Range Selection, 2.4V to 75V VZ Tolerance Selection of ±2% (B Series) Flat Lead SOD-323 Small Outline Plastic Package Surface Device Type Mounting RoHS Compliant Green EMC Matte Tin(Sn) Lead Finish Band Indicates Cathode ELECTRICAL SYMBOL Cathode Anode Electrical Characteristics Device Type MM3Z2V4BW MM3Z2V7BW MM3Z3V0BW MM3Z3V3BW MM3Z3V6BW MM3Z3V9BW MM3Z4V3BW MM3Z4V7BW MM3Z5V1BW MM3Z5V6BW MM3Z6V2BW MM3Z6V8BW MM3Z7V5BW MM3Z8V2BW MM3Z9V1BW MM3Z10VBW MM3Z11VBW MM3Z12VBW MM3Z13VBW MM3Z15VBW MM3Z16VBW MM3Z18VBW Device Marking 0Z 1Z 2Z 3Z 4Z 5Z 6Z 7Z 8Z 9Z AZ BZ CZ DZ EZ FZ GZ HZ JZ KZ LZ MZ TA = 25°C unless otherwise noted VZ @ IZT (Volts) Min 2.35 2.65 2.94 3.23 3.53 3.82 4.21 4.61 5.00 5.49 6.08 6.66 7.35 8.04 8.92 9.80 10.78 11.76 12.74 14.70 15.68 17.64 Nom 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 Max 2.45 2.75 3.06 3.37 3.67 3.98 4.39 4.79 5.20 5.71 6.32 6.94 7.65 8.36 9.28 10.20 11.22 12.24 13.26 15.30 16.32 18.36 IZT (mA) 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 ZZT @ IZT (Ω) Max 100 100 100 95 90 90 90 80 60 40 10 15 15 15 15 20 20 25 30 30 40 45 IZK (mA) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ZZK @ IZK (Ω) Max 564 564 564 564 564 564 564 470 451 376 141 75 75 75 94 141 141 141 160 188 188 212 IR @ VR (μA) Max 45 18 9 4.5 4.5 2.7 2.7 2.7 1.8 0.9 2.7 1.8 0.9 0.63 0.45 0.18 0.09 0.09 0.09 0.045 0.045 0.045 VR (Volts) 1 1 1 1 1 1 1 2 2 2 4 4 5 5 6 7 8 8 8 10.5 11.2 12.6 Oct 2008 Release, Revision C Page 1 MM3Z2V4BW through MM3Z75VBW TAK CHEONG Electrical Characteristics Device Type MM3Z20VBW MM3Z22VBW MM3Z24VBW MM3Z27VBW MM3Z30VBW MM3Z33VBW MM3Z36VBW MM3Z39VBW MM3Z43VBW MM3Z47VBW MM3Z51VBW MM3Z56VBW MM3Z62VBW MM3Z68VBW MM3Z75VBW Device Marking NZ PZ RZ SZ TZ UZ VZ WZ XZ YZ −Z =Z ≡Z >Z
MM3Z33VBW 价格&库存
很抱歉,暂时无法提供与“MM3Z33VBW”相匹配的价格&库存,您可以联系我们找货
