MM5Z15VB
MM5Z15VB
    TC(德昌)
    SOD-323
    德昌 SOD-323 Zzk: 188Ω Pd:200 mW Vr: 10.5V
MM5Z15VB 数据手册
TAK CHEONG ® SEMICOND UC TOR 200mW SOD-523 SURFACE MOUNT Very Small Outline Flat Lead Plastic Package Zener Voltage Regulators Absolute Maximum Ratings Symbol PD TSTG TOPR Power Dissipation Storage Temperature Range Operating Temperature Range TA = 25°C unless otherwise noted Value 200 -55 to +150 -55 to +150 Units mW °C °C Green Product Parameter These ratings are limiting values above which the serviceability of the diode may be impaired. SOD-523 Flat Lead Specification Features: Wide Zener Voltage Range Selection, 2.4V to 75V Flat Lead SOD-523 Small Outline Plastic Package Extremely Small SOD-523 Package Surface Device Type Mounting RoHS Compliant Green EMC Matte Tin(Sn) Terminal Finish Band Indicates Cathode Cathode ELECTRICAL SYMBOL Anode Electrical Characteristics Device Type MM5Z2V4B MM5Z2V7B MM5Z3V0B MM5Z3V3B MM5Z3V6B MM5Z3V9B MM5Z4V3B MM5Z4V7B MM5Z5V1B MM5Z5V6B MM5Z6V2B MM5Z6V8B MM5Z7V5B MM5Z8V2B MM5Z9V1B MM5Z10VB MM5Z11VB MM5Z12VB MM5Z13VB MM5Z15VB MM5Z16VB MM5Z18VB Device Marking 05 15 25 35 45 +5 65 75 85 95 A5 B5 C5 D5 E5 F5 G5 H5 J5 K5 L5 M5 TA = 25°C unless otherwise noted VZ @ IZT (Volts) Min 2.35 2.65 2.94 3.23 3.53 3.82 4.21 4.61 5.00 5.49 6.08 6.66 7.35 8.04 8.92 9.80 10.78 11.76 12.74 14.70 15.68 17.64 Nom 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 Max 2.45 2.75 3.06 3.37 3.67 3.98 4.39 4.79 5.20 5.71 6.32 6.94 7.65 8.36 9.28 10.20 11.22 12.24 13.26 15.30 16.32 18.36 IZT (mA) 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 ZZT @ IZT (Ω) Max 100 100 100 95 90 90 90 80 60 40 10 15 15 15 15 20 20 25 30 30 40 45 IZK (mA) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ZZK @ IZK (Ω) Max 564 564 564 564 564 564 564 470 451 376 141 75 75 75 94 141 141 141 160 188 188 212 IR @ VR (μA) Max 45 18 9 4.5 4.5 2.7 2.7 2.7 1.8 0.9 2.7 1.8 0.9 0.63 0.45 0.18 0.09 0.09 0.09 0.045 0.045 0.045 VR (Volts) 1 1 1 1 1 1 1 2 2 2 4 4 5 5 6 7 8 8 8 10.5 11.2 12.6 DB-146 April 2009, Revision A Page 1 MM5Z2V4B through MM5Z75VB TAK CHEONG Electrical Characteristics Device Type MM5Z20VB MM5Z22VB MM5Z24VB MM5Z27VB MM5Z30VB MM5Z33VB MM5Z36VB MM5Z39VB MM5Z43VB MM5Z47VB MM5Z51VB MM5Z56VB MM5Z62VB MM5Z68VB MM5Z75VB Device Marking N5 P5 R5 S5 T5 U5 V5 X5 Y5 Z5 −5 =5 ≡5 >5
MM5Z15VB 价格&库存
很抱歉,暂时无法提供与“MM5Z15VB”相匹配的价格&库存,您可以联系我们找货
