MM5Z3V6B
MM5Z3V6B
    TC(德昌)
    SOD-323
    德昌 SOD-323 Zzk: 564Ω Pd:200 mW Vr: 1V
MM5Z3V6B 数据手册
TAK CHEONG ® SEMICOND UC TOR 200mW SOD-523 SURFACE MOUNT Very Small Outline Flat Lead Plastic Package Zener Voltage Regulators Absolute Maximum Ratings Symbol PD TSTG TOPR Power Dissipation Storage Temperature Range Operating Temperature Range TA = 25°C unless otherwise noted Value 200 -55 to +150 -55 to +150 Units mW °C °C Green Product Parameter These ratings are limiting values above which the serviceability of the diode may be impaired. SOD-523 Flat Lead Specification Features: Wide Zener Voltage Range Selection, 2.4V to 75V Flat Lead SOD-523 Small Outline Plastic Package Extremely Small SOD-523 Package Surface Device Type Mounting RoHS Compliant Green EMC Matte Tin(Sn) Terminal Finish Band Indicates Cathode Cathode ELECTRICAL SYMBOL Anode Electrical Characteristics Device Type MM5Z2V4B MM5Z2V7B MM5Z3V0B MM5Z3V3B MM5Z3V6B MM5Z3V9B MM5Z4V3B MM5Z4V7B MM5Z5V1B MM5Z5V6B MM5Z6V2B MM5Z6V8B MM5Z7V5B MM5Z8V2B MM5Z9V1B MM5Z10VB MM5Z11VB MM5Z12VB MM5Z13VB MM5Z15VB MM5Z16VB MM5Z18VB Device Marking 05 15 25 35 45 +5 65 75 85 95 A5 B5 C5 D5 E5 F5 G5 H5 J5 K5 L5 M5 TA = 25°C unless otherwise noted VZ @ IZT (Volts) Min 2.35 2.65 2.94 3.23 3.53 3.82 4.21 4.61 5.00 5.49 6.08 6.66 7.35 8.04 8.92 9.80 10.78 11.76 12.74 14.70 15.68 17.64 Nom 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 Max 2.45 2.75 3.06 3.37 3.67 3.98 4.39 4.79 5.20 5.71 6.32 6.94 7.65 8.36 9.28 10.20 11.22 12.24 13.26 15.30 16.32 18.36 IZT (mA) 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 ZZT @ IZT (Ω) Max 100 100 100 95 90 90 90 80 60 40 10 15 15 15 15 20 20 25 30 30 40 45 IZK (mA) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ZZK @ IZK (Ω) Max 564 564 564 564 564 564 564 470 451 376 141 75 75 75 94 141 141 141 160 188 188 212 IR @ VR (μA) Max 45 18 9 4.5 4.5 2.7 2.7 2.7 1.8 0.9 2.7 1.8 0.9 0.63 0.45 0.18 0.09 0.09 0.09 0.045 0.045 0.045 VR (Volts) 1 1 1 1 1 1 1 2 2 2 4 4 5 5 6 7 8 8 8 10.5 11.2 12.6 DB-146 April 2009, Revision A Page 1 MM5Z2V4B through MM5Z75VB TAK CHEONG Electrical Characteristics Device Type MM5Z20VB MM5Z22VB MM5Z24VB MM5Z27VB MM5Z30VB MM5Z33VB MM5Z36VB MM5Z39VB MM5Z43VB MM5Z47VB MM5Z51VB MM5Z56VB MM5Z62VB MM5Z68VB MM5Z75VB Device Marking N5 P5 R5 S5 T5 U5 V5 X5 Y5 Z5 −5 =5 ≡5 >5
MM5Z3V6B
1. 物料型号: - 型号为MM5Z2V4B至MM5Z75VB,是一系列稳压二极管。
2. 器件简介: - 这些器件是200mW SOD-523表面贴装小型塑料封装的齐纳电压调节器,具有宽齐纳电压范围选择。
3. 引脚分配: - SOD-523封装具有两个引脚,带状标识表示阴极。
4. 参数特性: - 绝对最大额定值:功率耗散200mW,存储温度范围-55至+150°C,工作温度范围-55至+150°C。 - 电气特性:包括齐纳电压(Vz@lzr)、齐纳电流(Izr)、齐纳阻抗(Zzr@lzr Max)、反向漏电流(IzK)、反向阻抗(ZzK@lzK Max)和反向恢复电流(IR@VR Max)等参数。
5. 功能详解: - 这些稳压二极管用于稳定电压,防止电压过高而损坏电路。
6. 应用信息: - 适用于普通电子设备,不适用于高可靠性要求的设备,如医疗仪器、交通设备等。
7. 封装信息: - 封装为SOD-523表面贴装型,非常小的SOD-523封装,符合RoHS标准,采用绿色EMC Matte锡(Sn)终端表面处理。
MM5Z3V6B 价格&库存
很抱歉,暂时无法提供与“MM5Z3V6B”相匹配的价格&库存,您可以联系我们找货
