FBS10-06SC
FBS10-06SC
    IXYSCORPORATION
    ISOPLUS i4-PAC
    DIODE SCHOTTKY 600V ISOPLUS-5
FBS10-06SC 数据手册
Advanced Technical Information Silicon Carbide Schottky Rectifier Bridge in ISOPLUS i4-PACTM FBS 10-06SC VRRM = 600 V ID(AV)M = 6.6 A Cjunction = 9 pF 1 5 Rectifier Bridge Symbol VRRM IFAV ID(AV)M IFSM Ptot TC = 90°C; sine 180° (per diode) TC = 90°C TVJ = 25°C; t = 10 ms; sine 50 Hz TC = 25°C (per diode) Conditions Maximum Ratings 600 3 6.6 12 19 V A A A W Features • Silicon Carbide Schottky Diodes - no reverse recovery at turn off - only charge of junction capacity - soft turn off waveform - no forward recovery at turn on - switching behaviour independent of temperature - low leakage current • ISOPLUS i4-PAC(TM) package - isolated back surface - low coupling capacity between pins and heatsink - enlarged creepage towards heatsink - application friendly pinout - high reliability - industry standard outline Symbol Conditions Characteristic Values (TVJ = 25°C, unless otherwise specified) min. typ. max. TVJ = 25°C TVJ = 125°C TVJ = 25°C TVJ = 125°C TVJ = 125°C 1.7 1.9 0.04 9 11.5 2.0 0.2 V V mA mA pF 8 K/W K/W VF IR CJ RthJC RthJS IF = 4 A; VR = VRRM; VR = 400 V; (per diode) Applications • output rectifiers of high end switched mode power supplies • other high frequency rectifiers Data according to IEC 60747 and refer to a single diode unless otherwise stated. IXYS reserves the right to change limits, test conditions and dimensions. © 2002 IXYS All rights reserved 1-2 202 FBS 10-06SC Component Symbol TVJ Tstg VISOL FC Symbol Cp dS,dA dS,dA Weight IISOL ≤ 1 mA; 50/60 Hz mounting force with clip Conditions coupling capacity between shorted pins and mounting tab in the case pin - pin pin - backside metal 1.7 5.5 9 Conditions Maximum Ratings -55...+175 -55...+125 2500 20...120 °C °C V~ N Dimensions in mm (1 mm = 0.0394") Characteristic Values min. typ. max. 40 pF mm mm g © 2002 IXYS All rights reserved 2-2
FBS10-06SC 价格&库存
很抱歉,暂时无法提供与“FBS10-06SC”相匹配的价格&库存,您可以联系我们找货
