L IT E - O N T E C HN OLOGY C OR P OR A TI ON
Property of Lite-on Only
FEATURES
* Isolation voltage between input and output Viso : 5,000Vrms * 6pin DIP zero-cross optoisolators triac driver output * High repetitive peak off-state voltage VDRM : Min. 800V * High critical rate of rise of off-state voltage ( dv/dt : MIN. 800V / µs ) * Dual-in-line package : MOC3083 * Wide lead spacing package : MOC3083M * Surface mounting package : MOC3083S * Tape and reel packaging : MOC3083S-TA1 * UL approved ( No. E113898 ) * CUL approved ( No. E113898 ) * FIMKO approved ( No. 15469 ) * NEMKO approved ( No. P00102123 ) * DEMKO approved ( No. 309968-01 ) * SEMKO approved ( No. 0032019/01-11 ) * VDE approved (No. 094722 )
APPLICATIONS
* AC Motor Drives * AC Motor Starters * E.M. Contactors * Lighting Controls * Solenoid/Valve Controls * Solid State Relays * Static Power Switches * Temperature Controls
Part No. : MOC3083 SERIES
BNS-OD-C131/A4
Page :
1 of 8
OUTLINE DIMENSIONS
Wide lead spacing package:
*1. *2. *3. *4.
Year date code. 2-digit work week. Factory identification mark shall be marked (Z : Taiwan, Y : Thailand). Model No.: MOC3083 Page : 2 of 8
BNS-OD-C131/A4
OUTLINE DIMENSIONS
*1. *2. *3. *4.
BNS-OD-C131/A4
Page :
3 of 8
TAPING DIMENSIONS
Tape and reel package : MOC3083S-TA1
Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment
Symbol W P0 F P2 P1
Dimensions in mm ( inches ) 16 ± 0.3 ( .63 ) 4 ± 0.1 ( .15 ) 7.5 ± 0.1 ( .295 ) 2 ± 0.1 ( .079 ) 12 ± 0.1 ( .472 )
BNS-OD-C131/A4
Page :
4 of 8
ABSOLUTE MAXIMUM RATING
( Ta = 25°C )
PARAMETER Forward Current INPUT Reverse Voltage Power Dissipation Off-State Output Terminal Voltage OUTPUT Peak Repetitive Surge Current ( PW=100µs, 120pps ) Collector Power Dissipation Total Power Dissipation *1 Isolation Voltage Ambient Operating Temperature Range Storage Temperature Range *2 Soldering Temperature SYMBOL IF VR PD VDRM ITSM PC Ptot Viso TA Tstg TL RATING 50 6 120 800 1 150 250 5,000 -40 ~ +100 -55 ~ +150 260 UNIT mA V mW V A mW mW Vrms °C °C °C
*1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector, emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds
BNS-OD-C131/A4
Page :
5 of 8
ELECTRICAL - OPTICAL CHARACTERISTICS
( Ta = 25°C )
PARAMETER Forward Voltage INPUT Reverse Current *1 Peak Blocking Current, Either Direction OUTPUT Peak On-State Voltage, Either Direction *2 Critical rate of Rise of Off-State Voltage *3 IR IDRM1 VTM dv/dt — — — 800 0.05 — — 1500 10 500 3.0 — µA nA V V/µs VR=6V VDRM = 800V ITM=100 mA Peak SYMBOL MIN. TYP. MAX. UNIT VF — 1.2 1.4 V CONDITIONS IF=20mA
Led Trigger Current, Current Required to Latch Output, Either Direction Holding Current, Either Direction Turn-On Time
IFT
5
mA
Main Terminal Voltage = 3V
COUPLED IH TON — — 400 8 — 20 µA µs VP=9V, IF=20mA RL = 100Ω IF=Rated IFT, MT1-MT2 Voltage above which device will not trigger. IF = Rated IFT, Rated VDRM, Off State
Inhibit Voltage ZERO CROSSING Leakage in Inhibited State
VINH
5
Volts
IDRM2
500
µA
*1 Test voltage must be applied within dv/dt rating. *2 This is static dv/dt. Commutating dv/dt is a function of the load-driving thyristor(s) only. *3 All devices are guaranteed to trigger at an IF value less than or equal to max IFT. Therefore, recommended operating IF lies between max IFT 5mA for MOC3083 and absolute max IF (50mA)
BNS-OD-C131/A4
Page :
6 of 8
CHARACTERISTICS CURVES
Fig.1 Forward Current vs. Ambient Temperature
60
Forward current I F (mA)
Fig.2 On-state Current vs. Ambient Temperature
ITM , on-state current (A)
50 40 30 20 10 0 -40 -20
0.10
0.05
20 40 60 80 100 120
o
0 -40 -20
20 40 60 80 100 120
o
Ambient temperature Ta ( C)
Fig.3 Minimum Trigger Current vs. Ambient Temperature
10
Minimum trigger current I FT (mA)
Fig.4 Forward Current vs. Forward Voltage
VP= 6V RL= 100
100
8 6 4 2 0
80 C o 100 C 10
o
60 C o 40 oC 20 C
o
60
80
o
100
1
0.4
0.8
1.2
1.6
2.0
Ambient temperature ( C)
Forward voltage VF (V)
Fig.5 On-state Voltage vs. Ambient Temperature
3.0
On-state voltage VTM(V)
Fig.6 Holding Current vs. Ambient Temperature
1
Forward current I H (mA)
I TM= 100mA
VP= 6V
2.6 2.2 1.8 1.4 1.0
0.1
60
80
o
100
0.01
60
80
o
100
Ambient Temperature Ta ( C)
BNS-OD-C131/A4
Page :
7 of 8
Fig.7 Turn-on Time vs. Forward Current
10 8 6 4 2 0
Fig.8 Repetitive Peak Off-state Current vs. Temperature
1000
Repetitive Peak Off-state Current Idrm (nA)
VP= 9V RL= 100
Turn-on time Ton ( s)
100
10
10
40
50
1
60
80
O
100
Fig.9 On-state Current vs. On-state Voltage
100
Static dv/dt Test Circuit
+ 400 Vdc
On-state current ITM (mA)
80 60 40 20 0 APPLIED VOLTAGE WAVEFORM 0 VOLTS PULSE INPUT
RTEST CTEST MERCURY WETTED RELAY
R= 10k X100 SCOPE PROBE
D.U.T.
Vmax = 400V 252 V dv/dt= 0.63 Vmax
1.0
1.5
2.0
2.5
3.0
On-state voltage VTM (V)
τRC
τRC
378
τRC
RECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD)
Unit : mm Part No. : MOC3083 SERIES
BNS-OD-C131/A4
Page :
8 of 8
很抱歉,暂时无法提供与“MOC3083”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.585301+0.20550
- 100+1.44100100+0.18680
- 500+1.31040500+0.16990
- 国内价格
- 50+0.80174
- 500+0.78930
