Part No: CEM-1601 Description: magnetic buzzer
Date: 9/08/2006 Unit: mm Page No: 1 of 5
Specifications
Rated voltage Operating voltage Mean current Coil resistance Coil impedance Sound output 1.5 Vo-p 1.0 - 3.0 Vo-p 20 mA max. 30 ±4.5 Ω 105 Ω Min. 80 (Typical 88) dBA Applying rated voltage, 2048 Hz square wave, ½ duty See impedance measurements graph Distance at 10cm (A-weight free air). Applying rated voltage of 2048 Hz, square wave, ½ duty.
Rated frequency Operating temperature Storage temperature Dimensions Weight Material Terminal RoHS
2,048 Hz -20 ~ +60° C -30 ~ +70° C ø16.0 x H14.0 mm 4.6 g PPO (Black) Pin type (Au Plating) yes
See attached drawing
Frequency Response Curve
Phone: 800.275.4899
Fax: 503.612.2381
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
Date: 9/08/2006 Unit: mm Page No: 2 of 5
Appearance Drawing
Tolerance: ±0.5
Measurement Method
Phone: 800.275.4899
Fax: 503.612.2381
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
Date: 9/08/2006 Unit: mm Page No: 3 of 5
Mechanical Characteristics
Item Solderability Test Condition Lead terminals are immersed in rosin for 5 seconds and then immersed in solder bath of 270 ±5°C for 3 ±1 seconds. Lead terminals are immersed up to 1.5 mm from the buzzer’s body in solder bath of 260 ±5°C for 3 ±1 seconds. Apply a force of 9.8 N (1.0 kg) to each terminal in each axial direction. The buzzer will be measured after applying a vibration amplitude of 1.52 mm with 10 to 55 Hz band of vibration frequency to each of the 3 perpendicular directions for 2 hours. The part is to be dropped from a height of 75 cm onto a 40 mm thick wooden board 3 times in 3 axis (X, Y, Z) for a total of 9 drops. Evaluation Standard 90% min. lead terminals should be wet with solder. (Except the edge of the terminal.) No in interference in operation. No damage or cutting off. After the test, the part should meet specifications without any damage to the appearance and the SPL should be within ±10 dBA of the initial measurement.
Soldering Heat Resistance
Terminal Mechanical Strength Vibration
Drop Test
Environment Test
Item High temp. test Low temp. test Thermal shock Test Condition The part will be subjected to +70°C for 96 hours. The part will be subjected to -30°C for 96 hours The part will be subjected to 10 cycles. One cycle will consist of: Evaluation Standard
Temp./Humidity cycle
The part shall be subjected to 10 cycles. One cycle will be 24 hours and consist of:
After the test, the part should meet specifications without any damage to the appearance or performance except SPL. After 4 hours at 25°C, the SPL should be within ±10 dBA of the initial measurement.
Phone: 800.275.4899
Fax: 503.612.2381
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
Date: 9/08/2006 Unit: mm Page No: 4 of 5
Reliability Tests
Item Operating (Life Test) Test Condition 1. Continuous life test: The part will be subjected to 72 hours at 45°C with 1.5 V, 2048 Hz applied. 2. Intermittent life test: A duty cycle of 1 minute on, 1 minute off, a minimum of 10,000 times at room temp. (+25 ±10°C) with 1.5 V, 2048 Hz applied. Evaluation Standard After the test, the part shall meet specifications without any damage to the appearance. After 4 hours at +25°C, the SPL should be within ±10 dBA of the initial SPL.
Test Conditions
Standard Test Condition Judgement Test Condition a) Tempurature: +5 ~ +35°C a) Tempurature: +25±2°C b) Humidity: 45 - 85% b) Humidity: 60 - 70% c) Pressure: 860 - 1060 mbar c) Pressure: 860 - 1060 mbar
Phone: 800.275.4899
Fax: 503.612.2381
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
Date: 9/08/2006 Unit: mm Page No: 5 of 5
Packaging
Phone: 800.275.4899
Fax: 503.612.2381
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
很抱歉,暂时无法提供与“CEM-1601”相匹配的价格&库存,您可以联系我们找货
