CEP-1123
CEP-1123
    CUIDEVICES
    AUDIO PIEZO TRANSDUCER 3-28V TH
CEP-1123 数据手册
Part No: CEP-1123 Description: piezo audio transducer Date: 6/25/2007 Unit: mm Page No: 1 of 5 Specifications Resonant frequency Operating voltage Current consumption Sound pressure level Rated voltage Operating temperature Storage temperature Dimensions Weight Material Terminal RoHS 3.2 ±0.5 KHz 3~28 V dc max. 7 mA max. at 12 V dc 74 db min. at 30 cm / 12 V dc 12 V dc -30 ~ +85° C -40 ~ +95° C ø23.5 x H10.0 mm 3.0 g max. ABS UL-94 1/16” HB High Heat (Black) Pin type (Sn Plating) yes Appearance Drawing Tolerance: ±0.5 red wire ---M blue wire ---F black wire ---G Phone: 800.275.4899 Fax: 503.612.2381 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Part No: CEP-1123 Description: piezo audio transducer Date: 6/25/2007 Unit: mm Page No: 2 of 5 Measurement Method 1) S.P.L. Measuring Circuit Mic: RION UC 30 or equivalent 2) The current consumption and the S.P.L. are measured by using the recommended driving circuit as shown below. Phone: 800.275.4899 Fax: 503.612.2381 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Part No: CEP-1123 Description: piezo audio transducer Date: 6/25/2007 Unit: mm Page No: 3 of 5 Mechanical Characteristics Item Solderability Evaluation Standard Test Condition 90% min. of the lead terminals Lead terminals are immersed in rosin for will be wet with solder. (Except 5 seconds and then immersed in solder bath the edge of the terminal) of 270 ±5°C for 3 ±1 seconds. Lead terminals are immersed up to 1.5mm from No interference in operation. buzzer’s body in solder bath of 300 ±5°C for 3 ±0.5 or 260 ±5°C for 10 ±1 seconds. No damage or cutting off. For 10 seconds, the force of 9.8N (1.0kg) is applied to each terminal in axial direction. The buzzer should be measured after applying The value of oscillation frequency/current consumption a vibration amplitude of 1.5 mm with 10 to should be ±10% of the initial 55 Hz band of vibration frequency to each of measurements. The SPL should the 3 perpendicular directions for 2 hours. be within ±10dB compared with The part will be dropped from a height of the initial measurement. 75 cm onto a 40 mm thick wooden board 3 times in 3 axes (X, Y, Z) for a total of 9 drops. Soldering Heat Resistance Terminal Mechanical Strength Vibration Drop Test Environment Test Item High temp. test Low temp. test Humidity test Temp. cycle test Test Condition After being placed in a chamber at +95°C for 240 hours. After being placed in a chamber at -40°C for 240 hours. After being placed in a chamber at +40°C and 90±5% relative humidity for 240 hours. The part shall be subjected to 5 cycles. One cycle will consist of: Evaluation Standard The buzzer will be measured after being placed at +25°C for 4 hours. The value of the oscillation frequency/current consumption should be ±10% compared to the initial measurements. The SPL should be within ±10dB compared to the initial measurements. Phone: 800.275.4899 Fax: 503.612.2381 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Part No: CEP-1123 Description: piezo audio transducer Date: 6/25/2007 Unit: mm Page No: 4 of 5 Reliability Test Item Operating (Life Test) Test Condition 1. Continuous life test: The part will be subjected to 48 hours of continuous operation at +70°C with rated voltage applied. 2. Intermittent life test: A duty cycle of 1 minute on, 1 minute off, a minimum of 5,000 times at room temp (+25 ±2°C) with rated voltage applied. Evaluation Standard The buzzer will be measured after being placed at +25°C for 4 hours. The value of the oscillation frequency/current consumption should be ±10% compared to the initial measurements. The SPL should be within ±10dB compared to the initial measurements. Test Conditions Standard Test Condition Judgement Test Condition a) Tempurature: +5 ~ +35°C a) Tempurature: +25 ±2°C b) Humidity: 45 - 85% b) Humidity: 60 - 70% c) Pressure: 860-1060 mbar c) Pressure: 860-1060 mbar Phone: 800.275.4899 Fax: 503.612.2381 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062 Part No: CEP-1123 Description: piezo audio transducer Date: 6/25/2007 Unit: mm Page No: 5 of 5 Packaging Phone: 800.275.4899 Fax: 503.612.2381 www.cui.com 20050 SW 112th Ave. Tualatin, OR 97062
CEP-1123 价格&库存
很抱歉,暂时无法提供与“CEP-1123”相匹配的价格&库存,您可以联系我们找货
