MUBW 15-06 A6
Converter - Brake - Inverter Module (CBI1)
Rectifier VRRM = 1200V IFAVM = 11 A IFSM = 250 A
Brake VCES = 600 V IC25 = 11 A VCE(sat) = 2 V
Inverter VCES = 600 V IC25 = 18 A VCE(sat) = 2.1 V
Features
q
Input Rectifier Bridge D8 - D13 Symbol VRRM IF IFAVM IFSM i²t TVJ TVJ = 25°C TVJ = 150°C; TK = 70°C TVJ = 45°C; t = 10 ms sine 50 Hz TVJ = 125°C Conditions Maximum Ratings 1200 36 11 250 310 +150 V A A A A²s °C
q
q q q
q
NPT IGBT technology Square RBSOA, no latchup Free wheeling diodes with Hiperfast and soft recovery behaviour Isolation voltage 2500 V~ Built in temperature sense High level of integration: one module for complete drive system Direct Copper Bonded Al2O3 ceramic base plate
Applications Symbol Conditions Characteristic Values (TVJ = 25°C, unless otherwise specified) min. typ. max. 10 3 1.15 1.4 1.4 µA mA V °C/W
q q
AC motor control AC servo and robot drives
q
IR VF RthJC
VRRM = 1200 V; TVJ = 25°C TVJ = 125°C IF = 36 A per die
Advantages
q q q
No need of external isolation Easy to mount with two screws Package designed for wave soldering High temperature and power cycling capability
© 2000 IXYS All rights reserved
1-8
031
IXYS reserves the right to change limits, test conditions and dimensions.
MUBW 15-06 A6
Output Inverter T1 - T6, D1 - D6 Symbol VCES VCGR VGE IC ICM tSC Ptot TVJ TVJ Symbol Conditions TVJ = 25°C TVJ = 25°C; RGE = 20kW TVJ = 25°C TC = 25°C TC = 90°C tp = 1 ms = 1% duty cycle; TC = 25°C TC = 90°C Maximum Ratings 600 600 ±20 18 10 36 20 10 61 +150 +150 V V V A A A A µs W °C °C
IGBT VCE = 600 V; TVJ = 125°C non-repetitive TC = 25°C Free-Wheeling Diode IGBT
Conditions
Characteristic Values (TVJ = 25°C, unless otherwise specified) min. typ. max. 1 100 4.5 600 2.1 2.4 25 25 2.5 2.8 5.5 6.5 mA nA V V V V ns ns ns ns mJ mJ pF pF pF S 39 2 1.8 0.2 0.3 0.9 250 nC V V µs µC µC µA °C/W °C/W
ICES IGES VGE(th) V(BR)CES VCE(sat) tf tr td(on) td(off) Eoff Eon Ciss Coss Crss gfs Qg VF trr Qr Ir RthJC
VGE = 0 V; VCE = 600 V VCE = 0 V; VGE = 25 V VGE = VCE; IC = 0.35 mA VGE = 0 V; IC = 10 mA; TVJ = -40°C VGE = 15 V; IC = 10 A;TVJ = 25°C TVJ = 125°C
Inductive load, TVJ = 125°C VCC = 300 V; IC = 10 A RG = 100 W; VGE = ±15 V
35 250 0.38 0.58 570 80 55 3
VGE = 0 V VCE = 25 V f = 1 MHz VCE = 20 V; IC = 10 A VCC = 300 V; IC = 10 A pulse; VGE = 15 V IF = 10 A; VGE = 0 V; TVJ = 25°C TVJ = 125°C IF = 10 A; VR = -300 V; VGE = 0 V diF/dt = -350 A/µs; TVJ = 100°C IF = 10 A; VR = -300 V; TVJ = 25°C diF/dt = -350 A/µs; VGE= 0 V; TVJ = 125°C
IGBT Diode
(per die) (per die)
1.7 2.3
2-8
MUBW 15-06 A6
Brake Chopper T7, D7 Symbol VCES VCGR VGE IC ICM tSC Ptot TVJ TVJ Symbol Conditions TVJ = 25°C TVJ = 25°C; RGE = 20kW TVJ = 25°C TC = 25°C TC = 90°C tp = 1 ms = 1% duty cycle; TC = 25°C TC = 90°C Maximum Ratings 600 600 ±20 11 8 22 16 10 45 +150 +150 V V V A A A A µs W °C °C
Conditions
Characteristic Values (TVJ = 25°C, unless otherwise specified) min. typ. max. 20 100 3 600 2 2.3 75 30 2.5 2.8 110 45 80 375 4 5 µA nA V V V V ns ns ns ns mJ mJ 435 50 30 pF pF pF S 32.5 2 1.8 0.2 0.3 0.9 250 nC V V µs µC µC µA °C/W °C/W
VGE = 0 V; VCE = 600 V VCE = 0 V; VGE = 25 V VGE = VCE; IC = 0.5 mA VGE = 0 V; IC = 0.5 mA; TVJ = -40°C VGE = 15 V; IC = 6 A; TVJ = 25°C TVJ = 150°C
Inductive load, TVJ = 150°C VCC = 400 V; IC = 6 A RG = 50 W; VGE = ±15 V
50 250 0.21 0.25 350 40 25 4.2
VGE = 0 V VCE = 25 V f = 1 MHz VCE = 20 V; IC = 6 A VCC = 400 V; IC = 6 A pulse; VGE = 15 V IF = 10 A; VGE = 0 V; TVJ = 25°C TVJ = 150°C IF = 10 A; VR = -300 V; VGE = 0 V diF/dt = -350 A/µs; TVJ = 150°C IF = 10 A; VR = -300 V; TVJ = 25°C diF/dt = -350 A/µs; VGE= 0 V; TVJ = 125°C
IGBT Diode
(per die) (per die)
2.3 2.3
3-8
MUBW 15-06 A6
Module Symbol Tstg VISOL Md dS dA Weight IISOL £ 1 mA; 50/60 Hz; t = 1 min Mounting torque (M4) Creepage distance on surface Strike distance in air typ. Conditions Maximum Ratings -40...+125 2500 2.0 - 2.2 18 - 20 12.7 12.7 42 °C V~ Nm lb.in. mm mm g
Temperature Sensor R Symbol R Conditions Tamb = 20°C Maximum Ratings 4.7 kW
For additional data see C620/4.7k 5% S+M NTC thermistor catalog
Dimensions in mm (1 mm = 0.0394")
5.7 ± 0.3 21.1 ± 0.5 17.1 ± 0.3 3.4 ± 0.1
57.3-0.3
2 +0. 5.5
4.3+
0.2
4-8
MUBW 15-06 A6
50 A 40 IF 30 300 1000 800 A2s
typ.
lim.
A 250 IFSM 200
VR = 0 V
50Hz, 80%VRRM TVJ = 45°C TVJ = 180°C
It
2
600
400
TVJ= 180°C TVJ= 25°C
100 10
TVJ=45°C
200
50
TVJ=180°C
0 V 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 VF
0 10-3
100 10-2 10-1 100 s t 101 1 2 3 4 5 6 7 ms10 89 t
Forward characteristics
Surge overload current IFSM: crest value, t: duration
I2t versus time (1-10 ms)
10
(ZthJH is measured using 50 µm thermal grease)
1
D =0 D = 0.005 D = 0.01 D = 0.02 D = 0.05 D = 0.1 D = 0.2 D = 0.5
0.1
ZthJH[K/W]
0.01
0.00001
0.0001
0.001
0.01
0.1
1
10
0.001 100
t (s)
Transient thermal resistance junction to heatsink
5-8
MUBW 15-06 A6
6-8
MUBW 15-06 A6
10
1
IGBT ZthJH [K/W]
D=0 D = 0.005 D = 0.01 D = 0.02 D = 0.05 D = 0.1 D = 0.2 D = 0.5
0.1
0.01
0.00001
0.0001
0.001
0.01
0.1
1
10
0.001 100
t (s)
7-8
MUBW 15-06 A6
Output Inverter D1 - D6
30 A 25 IF 20 15 10 0.4 5 0 0.0 0.2 0.0 100 0 0 200 400 10
TVJ=150°C TVJ=100°C TVJ= 25°C
1.4 T = 100°C nC VJ V = 300V 1.2 R Qr 1.0 0.8 0.6
IF= 20A IF= 10A IF= 5A
40
TVJ= 100°C A VR = 300V
IRM
30
1.0
1.5 VF
2.0 V 2.5
A/ms 1000 -diF/dt
600 A/ms 1000 800 -diF/dt
Forward current IF versus VF
Reverse recovery charge Qr versus -diF/dt
120 ns 110
TVJ= 100°C VR = 300V
Peak reverse current IRM versus -diF/dt
20 V VFR 15
VFR
2.0
1.2
1.5 Kf 1.0
IRM
trr 100
tfr
ms
0.9 tfr
90
10
0.6
0.5
Qr
80
5
TVJ= 100°C IF = 10A
0.3
70 0.0 0 40 80 120 °C 160 TVJ 0 200 400 600 -diF/dt 800 A/ms 1000 0 0
200
400
0.0 600 A/ms 1000 800 diF/dt
8-06A
Dynamic parameters Qr, IRM versus TVJ
Recovery time trr versus -diF/dt
Peak forward voltage VFR and tfr versus diF/dt
10
1
0.00001 0.0001 0.001 0.01 0.1 1 10 100
Fred ZthJH[K/W] 0.1
0.01
0.001 t(s)
Transient thermal resistance junction to heatsink © 2000 IXYS All rights reserved
8-8
很抱歉,暂时无法提供与“MUBW15-06A6”相匹配的价格&库存,您可以联系我们找货
