MUBW 20-06 A7
Converter - Brake - Inverter Module (CBI2)
21 D11 1 D12 D13 2 D14 D15 7 3 D16 14 23 24 8 NTC T7 22 D7 T1 16 15 6 T2 11 10 D2 12 D1 T3 18 17 T4 D3 T5 20 19 T6 13 D5
5 D4
4 D6
9
Three Phase Rectifier VRRM = 1600V IDAVM = 36 A IFSM = 300 A
Brake Chopper VCES = 600 V IC25 = 25 A VCE(sat) = 1.9 V
Three Phase Inverter VCES = 600 V IC25 = 35 A VCE(sat) = 1.9 V
Application: AC motor drives with
q
Input Rectifier Bridge D11 - D16 Symbol VRRM IFAV IDAVM IFSM Ptot TC = 80°C; sine 180° TC = 80°C; rectangular; d = 1/3 TVJ = 25°C; t = 10 ms; sine 50 Hz TC = 25°C Conditions Maximum Ratings 1600 25 24 300 100 V A A A W
q
q
Input from single or three phase grid Three phase synchronous or asynchronous motor electric braking operation
Features
q
q
q
Symbol
Conditions
Characteristic Values (TVJ = 25°C, unless otherwise specified) min. typ. max. 1.4 1.3 1.2 1 1.6 0.15 V V mA mA µs 1.3 K/W
q
VF IR trr RthJC
IF = 20 A; TVJ = 25°C TVJ = 125°C VR = VRRM; TVJ = 25°C TVJ = 125°C VR = 100 V; IF = 15 A; di/dt = -15 A/µs (per diode)
q
q
High level of integration - only one power semiconductor module required for the whole drive Fast rectifier diodes for enhanced EMC behaviour NPT IGBT technology with low saturation voltage, low switching losses, high RBSOA and short circuit ruggedness Epitaxial free wheeling diodes with Hiperfast and soft reverse recovery Industry standard package with insulated copper base plate and soldering pins for PCB mounting Temperature sense included
IXYS reserves the right to change limits, test conditions and dimensions.
© 2001 IXYS All rights reserved
1-8
105
MUBW 20-06 A7
Output Inverter T1 - T6 Symbol VCES VGES VGEM IC25 IC80 RBSOA tSC (SCSOA) Ptot Conditions TVJ = 25°C to 150°C Continuous Transient TC = 25°C TC = 80°C VGE = ±15 V; RG = 47 Ω; TVJ = 125°C Clamped inductive load; L = 100 µH VCE = VCES; VGE = ±15 V; RG = 47 Ω; TVJ = 125°C non-repetitive TC = 25°C Maximum Ratings 600 ± 20 ± 30 35 25 ICM = 40 VCEK ≤ VCES 10 125 V V V A A A µs W
Equivalent Circuits for Simulation
Conduction
D11 - D16 Rectifier Diode (typ. at TJ = 125°C) V0 = 1.12V; R0 = 0.11 mΩ T1 - T6 / D1 - D6 IGBT (typ. at VGE = 15 V; TJ = 125°C) V0 = 0.9 V; R0 = 65 mΩ Free Wheeling Diode (typ. at TJ = 125°C) V0 = 1.09 V; R0 = 12 mΩ T7 / D7 IGBT (typ. at VGE = 15 V; TJ = 125°C) V0 = 0.99 V; R0 = 81 mΩ Free Wheeling Diode (typ. at TJ = 125°C) V0 = 1.07 V; R0 = 23 mΩ
Symbol
Conditions
Characteristic Values (TVJ = 25°C, unless otherwise specified) min. typ. max. 1.9 2.2 4.5 0.4 200 50 55 300 30 0.92 0.68 1100 65 2.3 6.5 0.6 V V V mA mA nA ns ns ns ns mJ mJ pF nC 1 K/W
VCE(sat) VGE(th) ICES IGES td(on) tr td(off) tf Eon Eoff Cies QGon RthJC
IC = 20 A; VGE = 15 V; TVJ = 25°C TVJ = 125°C IC = 0.5 mA; VGE = VCE VCE = VCES; VGE = 0 V; TVJ = 25°C TVJ = 125°C VCE = 0 V; VGE = ± 20 V
Thermal Response
Inductive load, TVJ = 125°C VCE = 300 V; IC = 20 A VGE = ±15 V; RG = 47 Ω
D11 - D16 Rectifier Diode (typ.) Cth1 = 0.106 J/K; Rth1 = 1.06 K/W Cth2 = 0.79 J/K; Rth2 = 0.239 K/W T1 - T6 / D1 - D6 IGBT (typ.) Cth1 = 0.108 J/K; Rth1 = 0.79 K/W Cth2 = 0.921 J/K; Rth2 = 0.209 K/W
VCE = 25 V; VGE = 0 V; f = 1 MHz VCE= 300V; VGE = 15 V; IC = 20 A (per IGBT)
Output Inverter D1 - D6 Symbol IF25 IF80 Conditions TC = 25°C TC = 80°C Maximum Ratings 35 24 A A
Free Wheeling Diode (typ.) Cth1 = 0.065 J/K; Rth1 = 1.766 K/W Cth2 = 0.636 J/K; Rth2 = 0.344 K/W T7 / D7
Symbol VF IRM trr RthJC
Conditions IF = 20 A; VGE = 0 V; TVJ = 25°C TVJ = 125°C IF = 15 A; diF/dt = -400 A/µs; TVJ = 125°C VR = 300 V; VGE = 0 V (per diode)
Characteristic Values min. typ. max. 2.1 1.4 13 90 V V A ns 2.1 K/W
IGBT (typ.) Cth1 = 0.077 J/K; Rth1 = 1.111 K/W Cth2 = 0.732 J/K; Rth2 = 0.279 K/W Free Wheeling Diode (typ.) Cth1 = 0.043 J/K; Rth1 = 2.738 K/W Cth2 = 0.54 J/K; Rth2 = 0.462 K/W
2-8
MUBW 20-06 A7
Brake Chopper T7 Symbol VCES VGES VGEM IC25 IC80 RBSOA tSC (SCSOA) Ptot Symbol Conditions TVJ = 25°C to 150°C Continuous Transient TC = 25°C TC = 80°C VGE = ±15 V; RG = 68 Ω; TVJ = 125°C Clamped inductive load; L = 100 µH VCE = VCES; VGE = ±15 V; RG = 68 Ω; TVJ = 125°C non-repetitive TC = 25°C Conditions Maximum Ratings 600 ± 20 ± 30 25 18 ICM = 30 VCEK ≤ VCES 10 90 V V V A A A µs W
Characteristic Values (TVJ = 25°C, unless otherwise specified) min. typ. max. 1.9 2.1 4.5 0.3 200 30 50 270 40 0.7 0.5 800 57 2.3 6.5 0.5 V V V mA mA nA ns ns ns ns mJ mJ pF nC 1.39 K/W
IC = 15 A; VGE = 15 V; TVJ = 25°C TVJ = 125°C IC = 0.4 mA; VGE = VCE VCE = VCES; VGE = 0 V; TVJ = 25°C TVJ = 125°C VCE = 0 V; VGE = ± 20 V
Inductive load, TVJ = 125°C VCE = 300 V; IC = 15 A VGE = ±15 V; RG = 68 Ω
VCE = 25 V; VGE = 0 V; f = 1 MH z VCE= 300 V; VGE = 15 V; IC = 15 A
Brake Chopper D7 Symbol VRRM IF25 IF80 Symbol VF IR IRM trr RthJC © 2001 IXYS All rights reserved Conditions TVJ = 25°C to 150°C TC = 25°C TC = 80°C Conditions IF = 15 A; TVJ = 25°C TVJ = 125°C VR = VRRM; TVJ = 25°C TVJ = 125°C IF = 10 A; diF/dt = -400 A/µs; TVJ = 125°C VR = 300 V Maximum Ratings 600 22 15 V A A
Characteristic Values min. typ. max. 2.2 1.5 0.06 0.07 11 80 V V mA mA A ns 3.2 K/W
3-8
MUBW 20-06 A7
Temperature Sensor NTC Symbol R25 B25/50 Module Symbol TVJ TJM Tstg VISOL Md Symbol Rpin-chip dS dA RthCH Weight Dimensions in mm (1 mm = 0.0394") Creepage distance on surface Strike distance in air with heatsink compound 6 6 0.02 180 Conditions Operating Maximum Ratings -40...+125 150 -40...+125 2500 2.7 - 3.3 °C °C °C V~ Nm Conditions T = 25°C Characteristic Values min. typ. max. 4.75 5.0 3375 5.25 kΩ K
IISOL ≤ 1 mA; 50/60 Hz Mounting torque (M5) Conditions
Characteristic Values min. typ. max. 5 mΩ mm mm K/W g
4-8
MUBW 20-06 A7
60 A 50 IF 40 TVJ= 125°C TVJ= 25°C 160 A 50Hz, 80% VRRM 140 120 IFSM 100 80 60 TVJ= 125°C 40 10 20 0 0.001 102 0.01 0.1 t s 1 1 2 3 4 5 6 7 ms10 89 t TVJ= 125°C TVJ= 45°C 103 A2s I2t TVJ= 45°C
30
0.4
0.8
1.2 VF
1.6 V
2.0
Fig. 1 Forward current versus voltage drop per diode
600 W 500 Ptot 400
Fig. 2 Surge overload current
Fig. 3 I2t versus time per diode
80 A
300
200
RthA: 0.05 K/W 0.15 K/W 0.3 K/W 0.5 K/W 1 K/W 2 K/W 5 K/W
60 Id(AV) 40
20 100
0 0 20 40 60 80 100 120 A Id(AV)M 0 20 40 60 80 100 120 140 °C
Tamb
0 0 20 40 60 80 100 120 140 °C TC
Fig. 4 1
1.4 K/W 1.2 1.0 ZthJC 0.8 0.6 0.4 0.2
Power dissipation versus direct output current and ambient temperature, sin 8 0 °
Fig. 5 Max. forward current versus case temperature
DWFN17-16
0.0 0.001
0.01
0.1
1 t
s
10
Fig. 6 Transient thermal impedance junction to case © 2001 IXYS All rights reserved
5-8
MUBW 20-06 A7
Output Inverter T1 - T6 / D1 - D6
60 50 A
IC
VGE= 17V 15V 13V
60 50 A IC 40
11V VGE= 17V 15V 13V 11V
40 30 20 10 0 0 1 2 3 4 VCE 5
V
9V TVJ = 25°C
30 20 10 0
9V TVJ = 125°C
6
2
3
4 VCE
5V
6
Fig. 7 Typ. output characteristics
Fig. 8 Typ. output characteristics
60 50 A
IC IF
50 A 40 30
40 30
TVJ = 125°C TVJ = 25°C
TVJ = 125°C
TVJ = 25°C
10 0 4 6 8 10 12 VGE
VCE = 20V
10 0 0.0
14 V 16
0.5
1.0
1.5 VF
2.0
V
2.5
Fig. 9 Typ. transfer characteristics
Fig. 10 Typ. forward characteristics of free wheeling diode
# ns ' $
TVJ = 125°C VR = 300V IF = 30A IRM
MUBW2006A7
V
50 40 A
IRM
15
VGE
trr
trr
30 10 20 5
VCE = 300V IC = 50A
10 0
0 0 20 40 60 QG
nC
80
400
600 800 s A/µ -di/dt
1000
Fig. 11 Typ. turn on gate charge
Fig. 12 Typ. turn off characteristics of free wheeling diode
6-8
MUBW 20-06 A7
4
mJ Eon
VCE = 300V VGE = ±15V RG = 47Ω TVJ = 125°C
80 Jd(on) Jr ns 60 t 40
2.0
mJ Eoff 1.5
400 Jd(off) ns 300 t 200
3
2
1.0
Eoff
1
Eon
Jf
100
0 0 10 20 30 IC 40 A
0 10 20 30 IC 40 A
Fig. 13 Typ. turn on energy and switching times versus collector current
1.6
mJ Eon 1.2
VCE = 300V VGE = ±15V IC = 20A TVJ = 125°C
Fig. 14 Typ. turn off energy and switching times versus collector current
1.00
mJ t 500 ns 375 t
Jd(on) Jr
80 ns 60
0.75 Eoff 0.50
Eoff
0.8
Eon
40
Jd(off)
250
0.4
Jf
125
0.0 0 20 40 60 80 RG
0 100 Ω 120
0.00 0 20 40 60 80 RG
0 100 Ω 120
Fig. 15 Typ. turn on energy and switching times versus gate resistor
50
A 10 K/W ZthJC 1
Fig.16 Typ. turn off energy and switching times versus gate resistor
diode IGBT
40
ICM
30 20 10 0 0 100 200 300 400 500 600 VCE 700 V
0.1 0.01
single pulse RG = 47 Ω TVJ = 125°C
0.001 0.0001 0.00001 0.0001 0.001
MUBW2006A7
0.01
0.1 t
1
s 10
Fig. 17 Reverse biased safe operating area RBSOA
Fig. 18 Typ. transient thermal impedance
7-8
MUBW 20-06 A7
Brake Chopper T7 / D7
50 40 A
IC 20 16 A 12
TVJ = 25°C TVJ = 125°C TVJ = 125°C TVJ = 25°C
IF
30 20 10
VGE = 15V
8 4 0
0 0 1 2 3 4
VCE
5
V6
2 VF
V
3
Fig. 19 Typ. output characteristics
Fig. 20 Typ. forward characteristics of free wheeling diode
300
1.5
mJ Eoff Jd(off)
VCE = 300V VGE = ±15V RG = 68Ω TVJ = 125°C
0.8
mJ t Eoff 0.6
VCE = 300V VGE = ±15V IC = 15A TVJ = 125°C
ns 200
1.0
0.4
100
Eoff
200
0.5
Eoff Jf
0.2
Jf
100
0.0 0 5 10 15 20 25
IC
0 30 A 35
0.0
0 20 40 60 80
0 100 Ω 120 RG
Fig. 21 Typ. turn off energy and switching times versus collector current
10 K/W 1 ZthJC 0.1 R 0.01 0.001
single pulse diode IGBT
Fig. 22 Typ. turn off energy and switching times versus gate resistor
10000 Ω 1000
100 0.01 0.1 t 1 s 10 0 25 50 75 100 T
MUBW2006A7
125 °C 150
Fig. 23 Typ. transient thermal impedance
Fig. 24 Typ. thermistorresistance versus temperature
8-8
很抱歉,暂时无法提供与“MUBW20-06A7”相匹配的价格&库存,您可以联系我们找货
