MUBW35-06A6K
MUBW35-06A6K
    IXYSCORPORATION
    E1
    MODULE IGBT CBI E1
MUBW35-06A6K 数据手册
Advanced Technical Information MUBW 35-06A6K Converter - Brake - Inverter Module (CBI1) NPT IGBT Three Phase Rectifier V RRM = 1600V IDAVM25 = 130 A I FSM = 320 A Brake Chopper VCES = 600 V IC25 = 25 A VCE(sat) = 2.0 V Three Phase Inverter VCES = 600 V IC25 = 42 A VCE(sat) = 2.3 V Application: AC motor drives with Maximum Ratings 1600 V A A A W • Input from single or three phase grid • Three phase synchronous or asynchronous motor • electric braking operation Features • High level of integration - only one power semiconductor module required for the whole drive • Inverter with NPT IGBTs - low saturation voltage - positive temperature coefficient - fast switching - short tail current • Epitaxial free wheeling diodes with hiperfast and soft reverse recovery • Industry standard package with insulated copper base plate and soldering pins for PCB mounting • Temperature sense included Input Rectifier Bridge D8 - D13 Symbol VRRM IFAV IDAVM IFSM Ptot TC = 80°C; sine 180° bridge output current; TC = 80°C; rect.; d = 1/3 TVJ = 25°C; t = 10 ms; sine 50 Hz TC = 25°C Conditions 31 89 320 80 Symbol Conditions Characteristic Values (TVJ = 25°C, unless otherwise specified) min. typ. max. TVJ = 25°C TVJ = 125°C 1.0 1.1 0.4 0.45 1.35 V V VF IR RthJC RthCH IF = 30 A; VR = VRRM; TVJ = 25°C TVJ = 125°C (per diode) 0.02 mA mA 1.4 K/W K/W IXYS reserves the right to change limits, test conditions and dimensions. © 2004 IXYS All rights reserved 1-4 431 Advanced Technical Information MUBW 35-06A6K Output Inverter T1 - T6 Symbol VCES VGES VGEM IC25 IC80 RBSOA tSC (SCSOA) Ptot Conditions TVJ = 25°C to 150°C Continuous Transient TC = 25°C TC = 80°C VGE = ±15 V; RG = 33 Ω; TVJ = 125°C Clamped inductive load; L = 100 µH VCE = 600 V; VGE = ±15 V; RG = 33 Ω; TVJ = 125°C non-repetitive TC = 25°C Maximum Ratings 600 ± 20 ± 30 42 29 ICM = 60 VCEK ≤ VCES 10 130 V V V A A A µs W Equivalent Circuits for Simulation Conduction D8 - D13 Rectifier Diode (typ. at TJ = 125°C) V0 = 0.90V; R0 = 9 mΩ T1 - T6 / D1 - D6 IGBT (typ. at VGE = 15 V; TJ = 125°C) V0 = 1.0 V; R0 = 4.0 mΩ Free Wheeling Diode (typ. at TJ = 125°C) V0 = 1.05 V; R0 = 7 mΩ T7 / D7 IGBT (typ. at VGE = 15 V; TJ = 125°C) V0 = 1.0 V; R0 = 70 mΩ Free Wheeling Diode (typ. at TJ = 125°C) V0 = 1.25 V; R0 = 26 mΩ Symbol Conditions (TVJ Characteristic Values = 25°C, unless otherwise specified) min. typ. max. 2.3 2.6 4.5 1.5 200 50 50 270 40 1.4 1.0 1600 95 0.35 2.7 6.5 0.75 V V V mA mA nA ns ns ns ns mJ mJ pF nC 0.95 K/W K/W VCE(sat) VGE(th) ICES IGES td(on) tr td(off) tf Eon Eoff Cies QGon RthJC RthCH IC = 35 A; VGE = 15 V; TVJ = 25°C TVJ = 125°C IC = 0.7 mA; VGE = VCE VCE = VCES; VGE = 0 V; TVJ = 25°C TVJ = 125°C VCE = 0 V; VGE = ± 20 V Thermal Response Inductive load, TVJ = 125°C VCE = 300 V; IC = 30 A VGE = ±15 V; RG = 33 Ω D8 - D13 Rectifier Diode (typ.) Cth1 = tbd J/K; Rth1 = tbd K/W Cth2 = tbd J/K; Rth2 = tbd K/W T1 - T6 / D1 - D6 IGBT (typ.) Cth1 = tbd J/K; Rth1 = tbd K/W Cth2 = tbd J/K; Rth2 = tbd K/W VCE = 25 V; VGE = 0 V; f = 1 MHz VCE = 300V; VGE = 15 V; IC = 30 A (per IGBT) Output Inverter D1 - D6 Symbol IF25 IF80 Conditions TC = 25°C TC = 80°C Maximum Ratings 69 46 A A Free Wheeling Diode (typ.) Cth1 = tbd J/K; Rth1 = tbd K/W Cth2 = tbd J/K; Rth2 = tbd K/W T7 / D7 IGBT (typ.) Cth1 = tbd J/K; Rth1 = tbd K/W Cth2 = tbd J/K; Rth2 = tbd K/W Free Wheeling Diode (typ.) Cth1 = tbd J/K; Rth1 = tbd K/W Cth2 = tbd J/K; Rth2 = tbd K/W Symbol VF IRM t rr RthJC RthCH Conditions IF = 35 A; VGE = 0 V; TVJ = 25°C TVJ = 125°C IF = 50 A; diF /dt = -100A/µs; TVJ = 125°C VR = 100 V; VGE = 0 V (per diode) Characteristic Values min. typ. max. 1.7 1.2 5 100 0.3 V V A ns 0.9 K/W K/W © 2004 IXYS All rights reserved 2-4 431 Advanced Technical Information MUBW 35-06A6K Brake Chopper T7 Symbol VCES VGES VGEM IC25 IC80 RBSOA tSC (SCSOA) Ptot Conditions TVJ = 25°C to 150°C Continuous Transient TC = 25°C TC = 80°C VGE = ±15 V; RG = 68 Ω; TVJ = 125°C Clamped inductive load; L = 100 µH Maximum Ratings 600 ± 20 ± 30 25 17 ICM = 30 VCEK ≤ VCES 10 80 V V V A A A µs W VCE = 600 V; VGE = ±15 V; RG = 68 Ω; TVJ = 125°C non-repetitive TC = 25°C Symbol Conditions (TVJ = 25°C, unless otherwise specified) VCE(sat) VGE(th) ICES IGES td(on) tr td(off) tf Eon Eoff Cies QGon RthJC RthCH Brake Chopper D7 Symbol VRRM IF25 IF80 Symbol VF IR IRM t rr RthJC RthCH © 2004 IXYS All rights reserved Conditions TVJ = 25°C to 150°C TC = 25°C TC = 80°C Conditions IF = 15 A; TVJ = 25°C TVJ = 125°C VR = VRRM; TVJ = 25°C TVJ = 125°C IF = 12 A; diF/dt = -100 A/µs; TVJ = 125°C VR = 100 V IC = 15 A; VGE = 15 V; TVJ = 25°C TVJ = 125°C IC = 0.4 mA; VGE = VCE VCE = VCES; VGE = 0 V; TVJ = 25°C TVJ = 125°C VCE = 0 V; VGE = ± 20 V Characteristic Values min. typ. max. 2.0 2.3 4.5 0.8 100 30 50 270 40 0.7 0.5 800 57 0.5 2.4 6.5 0.5 V V V mA mA nA ns ns ns ns mJ mJ pF nC 1.55 K/W K/W Inductive load, TVJ = 125°C VCE = 300 V; IC = 15 A VGE = ±15 V; RG = 68 Ω VCE = 25 V; VGE = 0 V; f = 1 MH z VCE = 300 V; VGE = 15 V; IC = 15 A Maximum Ratings 600 21 14 V A A Characteristic Values min. typ. max. 2.3 1.5 0.06 0.2 3.5 80 0.85 V V mA mA A ns 2.5 K/W K/W 431 3-4 Advanced Technical Information MUBW 35-06A6K Temperature Sensor NTC Symbol R25 B25/85 Module Symbol TVJ TJM Tstg VISOL Md Symbol dS dA Weight Conditions Operating Maximum Ratings -40...+125 150 -40...+125 2500 2.0 - 2.2 °C °C °C V~ Nm Conditions T = 25°C Characteristic Values min. typ. max. 4.45 4.7 3510 5.0 k Ω K IISOL ≤ 1 mA; 50/60 Hz Mounting torque (M4) Conditions Creepage distance (towards heatsink) Strike distance in air (towards heatsink) Characteristic Values min. typ. max. 12.7 12.7 40 mm mm g © 2004 IXYS All rights reserved 4-4 431
MUBW35-06A6K 价格&库存
很抱歉,暂时无法提供与“MUBW35-06A6K”相匹配的价格&库存,您可以联系我们找货
