CLM4B-PKW-CWAXBBB3
CLM4B-PKW-CWAXBBB3
    WOLFSPEED
    PLCC
    LED ORANGE CLEAR 4SMD
CLM4B-PKW-CWAXBBB3 数据手册
Cree® PLCC4 1 in 1 SMD LED CLM4B-PKW Data Sheet SMD LEDs is packaged in the industry standard package. These LEDs have high reliability performance and are designed to work under a wide range of environmental conditions. This high reliability feature makes them ideally suited to be used under architectural lighting application conditions. Its wide viewing angle makes these LEDs ideally suited for channel letter, or architectural lighting applications. The flat top emitting surface makes it easy for these LEDs to mate with light pipes. FEATURES • Size (mm): 3.2 x 2.7 • Color and Typical Dominant Wavelength (nm): Orange (615) • Luminous Intensity (mcd) Orange (1120-2800) • Viewing Angle: 120 degree • Lead-Free • RoHS Compliant APPLICATIONS • Light Strip • Channel Letter • Architectural Lighting LD-CT991.001 Data Sheet: C Subject to change without notice. www.cree.com/ledlamps 1 Absolute Maximum Ratings (TA = 25°C) Items Forward Current Peak Forward Current Reverse Voltage Power Dissipation Operation Temperature Storage Temperature Junction Temperature Junction/Ambient Junction/Solder Point Note Symbol IF IFP VR PD Topr Tstg TJ RTHJA RTHJS Absolute Maximum Rating 70 200 5 210 -40 ~ +100 -40 ~ +100 110 300 150 Unit mA mA V mW °C °C °C °C/W °C/W Note: Pulse width ≤0.1 msec, duty cycle ≤1/10. Typical Electrical & Optical Characteristics (TA = 25°C) Characteristics Forward Voltage Reverse Current Dominant Wavelength Luminous Intensity 50% Power Angle Symbol VF IR λD IV 2θ½ Condition IF = 50 mA VR = 5 V IF = 50 mA IF = 50 mA IF = 50 mA Unit V μA nm mcd deg Minimum Typical 2.4 Maximum 3.0 10 610 1120 615 2000 120 622 Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 2 CLD-CT991.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Intensity Bin Limit (IF = 50 mA) Orange Bin Code Wa Wb Xa Xb Min.(mcd) 1120 1400 1800 2240 Max.(mcd) 1400 1800 2240 2800 Tolerance of measurement of luminous intensity is ±10%. Color Bin Limit (IF = 50 mA) Orange Bin Code PB Min.(nm) 610 Max.(nm) 622 Tolerance of measurement of dominant wavelength is ±1 nm Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 3 CLD-CT991.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Order Code Table* Luminous Intensity (mcd) Color Orange Orange Orange Kit Number CLM4B-PKW-CWaXbBB3 CLM4B-PKW-CWbXbBB3 CLM4B-PKW-CXaXbBB3 Viewing Angle 120 120 120 Min. 1120 1400 1800 Max. 2800 2800 2800 Color Bin PB PB PB Dominant Wavelength Min. (nm) 610 610 610 Color Bin PB PB PB Max. (nm) 622 622 622 Notes: 1. The above kit numbers represent order codes which include multiple intensity-bin and color bin codes. Only one intensity-bin code and one color-bin code will be shipped on each reel. Single intensity-bin code and single color-bin codes will not be orderable. 2. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions. 3. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED product safely. Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 4 CLD-CT991.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Graphs                                                                                                    The above data are collected from statistical figures which do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice. Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 5 CLD-CT991.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Mechanical Dimensions All dimensions are in mm.  Notes RoHS Compliance The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye. Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 6 CLD-CT991.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Kit Number System Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 7 CLD-CT991.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Packaging • • • • • The boxes are not water resistant and they must be kept away from water and moisture. The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. Cardboard boxes will be used to protect the LEDs from mechanical shocks during transportation. The reel pack is applied in SMD LED. Max 2000 pcs per reel.         防潮珠。不可食  Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 8 CLD-CT991.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps
CLM4B-PKW-CWAXBBB3 价格&库存
很抱歉,暂时无法提供与“CLM4B-PKW-CWAXBBB3”相匹配的价格&库存,您可以联系我们找货
