CLV6A-FKB-CK1P1G1BB7R3R3 数据手册
Cree® PLCC6 3 in 1 SMD LED CLV6A-FKB
Data Sheet
These SMD LEDs are packaged in an industry standard PLCC6 package. These high performance tricolor SMT LEDs are designed to work in a wide range of applications. A wide viewing angle and high brightness make these LEDs suitable for outdoor signage applications. The encapsulation resin contains UV inhibitors to minimize the effects of long-term exposure to direct sunlight, resulting in stable light output over the life of the LED.
FEATURES • Size (mm): 5.5 x 5.5 • Dominant Wavelength (nm): Red (619-624 ) Green (520-540) Blue (460-480) • Luminous Intensity (mcd) Red (560 - 1120) Green (1120 - 2240) Blue (280 - 560) • Water-Resistant (IPX5*) • Moisture Sensitivity Level: 3 • Lead-Free
• RoHS Compliant APPLICATIONS • Outdoor Full-Color Video Screen • Decorative lighting • Amusement
* This part is tested under the condition of assembling it on a PCB with isolating the electrical path by silicone.
2 LD-CT1163.00 Data Sheet: C
Subject to change without notice. www.cree.com/ledlamps
1
Absolute Maximum Ratings (TA = 25°C)
Absolute Maximum Rating R 50 200 5 130 G 35 100 5 140 -40 ~ +100 -40 ~ +100 110 450 650 230 230 110 400 580 230 230 1000 V 110 450 680 200 200 B 35 100 5 140
Items Forward Current
Note 1
Symbol IF
Note 2
Unit mA mA V mW °C °C °C °C/W °C/W °C/W °C/W
Peak Forward Current Reverse Voltage Power Dissipation
IFP VR PD Topr Tstg TJ RTHJA RTHJA RTHJS RTHJS ESD
Operation Temperature Storage Temperature Junction Temperature Junction/ambient 1 chip on Junction/ambient 3 chips on Junction/solder point 1 chip on Junction/solder point 3 chips on Electrostatic Discharge Classification(MIL-STD-883E)
Note:
1. 2.
Single-color light. Pulse width ≤0.1 msec, duty ≤1/10.
Typical Electrical & Optical Characteristics (TA = 25°C)
Characteristics Wavelength at peak emission Dominant Wavelength Spectral bandwidth at 50% IREL max Viewing Angle at 50% IV Forward Voltage Condition IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA VR = 5 V Symbol λPEAK λDOM Δλ 2θ½ VF(avg) VF(max) IV(min) IV(avg) IR Values R 630 619~624 24 120 2.0 2.6 560 700 10 G 527 520~540 38 120 3.2 4.0 1120 1600 10 B 470 460~480 28 120 3.2 4.0 280 400 10 Unit nm nm nm deg V V mcd mcd μA
Luminous Intensity Reverse Current (max)
Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc.
2
CLD-CT1163.002
Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps
Intensity Bin Limit (IF = 20 mA)
Red
Bin Code K M N Min. (mcd) 560 710 900 Max. (mcd) 710 900 1120
Green
Bin Code P Q R Min. (mcd) 1120 1400 1800 Max. (mcd) 1400 1800 2240
Blue
Bin Code G H J Min. (mcd) 280 355 450 Max. (mcd) 355 450 560
• Tolerance of measurement of luminous intensity is ±10%
Color Bin Limit (IF = 20 mA)
Red
Bin Code RB Min.(nm) 619 Max.(nm) 624
Green
Bin Code G7 G8 G9 Ga Min.(nm) 520 525 530 535 Max.(nm) 525 530 535 540
Blue
Bin Code B3 B4 B5 B6 Min.(nm) 460 465 470 475 Max.(nm) 465 470 475 480
• Tolerance of measurement of dominant wavelength is ±1 nm
3
CLD-CT1163.002
Order Code Table*
Luminous Intensity (mcd) Kit Number Color Red CLV6A-FKB-CKNPRGJBB7a363 Green Blue Red CLV6A-FKB-CK1P1G1BB7R3R3 Green Blue Red CLV6A-FKB-CM1Q1H1BB7R3R3 Green Blue Min. 560 1120 280 Max. 1120 2240 560 Dominant Wavelength (nm) Color Bin RB G7 B3 RB Min. (nm) 619 520 460 619 Color Bin RB Ga B6 RB Max. (nm) 624 540 480 624 Package Reel Reel Reel Reel Reel Reel Reel Reel Reel
Any 1 Intensity bin from K(560) - N(1120) Any 1 Intensity bin from P(1120) - R(2240) Any 1 Intensity bin from G(280) - J(560) Any 1 Intensity bin from M(710) - N(1120) Any 1 Intensity bin from Q(1400) - R(2240) Any 1 Intensity bin from H(355) - J(560)
Any 1 hue bin from G7(520) - Ga(540) Any 1 hue bin from B3(460) - B6(480) RB 619 RB 624
Notes: 1. The above kit numbers represent the order codes which include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin code will be shipped on each reel. Single intensity-bin code and single colorbin code will be orderable in certain quantities. 2. For example, any 1 intensity-bin from K - N means only 1 intensity-bin (K or M or N) will be shipped by Cree. 3. For example, any 1 color-bin from G7 - Ga means only 1 color-bin (G7 or G8 or G9 or Ga) will be shipped by Cree. 4. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions. 5. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED product safely.
4
CLD-CT1163.002
Graphs
The above data are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice.
5
CLD-CT1163.002
Graphs
6
CLD-CT1163.002
Mechanical Dimensions
All dimensions are in mm.
Notes
RoHS Compliance The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye.
7
CLD-CT1163.002
Kit Number System
Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
8
CLD-CT1163.002
Reliability
Tests and Results
Test Temperature Cycle Thermal Shock Moisture Resistance High Temperature Storage Temperature Humidity Storage Low Temperature Storage Water Proof Test* High Temperature Life Test Life Test High Humidity Heat Life Test Low Temperature Life Test Resistance to Soldering Heat(Reflow Soldering) Vibration-variable Frequency Applicable Standards JEITA ED-4701 100 105 MIL-STD-202G JEITA ED-4701 200 203 JEITA ED-4701 200 201 JEITA ED-4701 100 103 JEITA ED-4701 200 202 IEC 60529:2001 JEITA ED-4701 300 301 MIL-STE-883 Method 2007 Test Condition -40°C~25°C~100°C~25°C 30 mins, 5 mins, 30 mins, 5 mins -40°C~100°C 30 mins, 30 mins 25°C~65°C~ 90%RH 24hrs/1cycle TA=100°C TA=60°C RH=90% TA=-40°C IP X5 Water flow rate 12.5 l/min TA=85°C IF=15 mA TA=25°C IF: R=30mA G=35mA B=20mA 60°C RH=90% IF=15 mA Ta=-40°C IF: R=30mA G=35mA B=20mA Tsol=260°C,10sec (Pre treatment 30°C,70%,168hrs) 20G min, 20 to 2000Hz, 4cycles, 4mins, Each x,y,z Human body model 1000 V (Forward and reverse current conduct electricity each 1time) Note 100 cycles 100 cycles 10 cycles 500 hrs 500 hrs 500 hrs 15min 1000 hrs 1000 hrs 500 hrs 500 hrs 2 times / Number of Damaged 0/45 0/45 0/45 0/45 0/45 0/45 0/45 0/45 0/45 0/45 0/45 0/45 0/45
Electrostatic Discharge Test
AEC(Q101-001)
0/45
Water proof test*: The test is conducted on component level. It is strongly recommended the customers test the products for their application Failure Criteria
Item Forward Voltage Reverse Current Luminous Flux/Intensity Resistance to Soldering Heat Vibration-variable Frequency Symbol VF IR ФV Test Condition IF = 20 mA VR = 5 V IF = 20 mA IF = 20 mA IF = 20 mA Criteria for Judgment Min. – Initial Data x 0.7 No dead lamps and visual damage No dead lamps and visual damage Max. Initial Data x 1.1 100 μA -
9
CLD-CT1163.002
Reflow Soldering
• • • • The CLV6A-FKB is rated as a MSL 3 product. The recommended floor life out of bag is 24hrs. The best practices suggestion is to use the product as soon as possible when removed from the bag. COTCO-05-0057 Document No.: The temperature (Top surface of SMD LED) profile is as below: Rev . NO. : 13
Melting-point
Temperature
Pre-heat
Soak
Reflow
Cooling
Use all SMD besides LP6-NPP1-01-N1 Solder with CLV6A-FKB Solder Soldering pad: = Lead-free Use only = Sn63-Pb37
Solder = /s max. Average ramp-up rate = 4ºCLow Lead-Free Average ramp-up rate = 4ºC/s max
Time
2.7 Average ramp-up rate = 4ºC/s max
Preheat temperature = 100ºC ~150ºC
Preheat temperature = 150ºC ~200ºC
1.7 1.3 1.7
Preheat temperature = 150ºC ~200ºC Preheat time = 120s max
Preheat tim e = 100s max.
0.475 5.65
Ramp-down rate = 6ºC/s max
Ramp-down rate = 6ºC/s max.
Ramp-down rate = 6ºC/s max. Peak temperature = 250ºC max. max. Tim e within 5ºC of actual Peak Temperature = 10s max. Duration above 217ºC is 80s max.
8.2
Peak temperature = 235ºC max
Peak temperature = 230ºC max.
Tim e wit 5ºC of actual Peak Temperature = 10s max Time withinhin 5ºC of actual Peak Temperature = 10s Duration above 183 C is 80 Duration above 217ºC isº45s maxs Only use LP6-NPP1-01-N1 Solder = Low Lead-free Average ramp-up rate = 3ºC/s max. Preheat temperature = 130ºC ~170ºC Preheat tim e = 120s max. Ramp-down rate = 6ºC/s max. Peak temperature = 213ºC max. max.
[13]
Tim e within 3ºC of actual Peak Temperature = 25s max. Duration above 200ºC is 40s max. Recomm ended solder pad design for heat dissipation (2-pin SMD LED):
7.0 2.6
Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps
7.5
4.5
10
CLD-CT1163.002
Package
• • • • • The boxes are not water resistant and they must be kept away from water and moisture. The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. Cardboard boxes will be used to protect the LEDs from mechanical shocks during transportation. The reel pack is applied in SMD LED. Max 900 pcs per reel.
防潮珠。不可食
11
CLD-CT1163.002
