LP379PBL1-C0G-03
LP379PBL1-C0G-03
    WOLFSPEED
    DIP
    LED BLUE CLEAR 4DIP THRU HOLE
LP379PBL1-C0G-03 数据手册
Cree® P4 LED Model # LP379PBL-C0G-03 Data Sheet 120-degree, 7.6 x 7.6 LED lamp in blue color with water-transparent lens and stopper Applications • • • Advertising Signs Indicators Message Boards Absolute Maximum Ratings (TA = 25°C) Items Forward Current Peak Forward Current Reverse Voltage Power Dissipation Operation Temperature Storage Temperature Lead Soldering Temperature Note Symbol IF IFP VR PD Topr Tstg Tsol Absolute Maximum Rating 30 100 5 132 -40 ~ +95 -40 ~ +100 Unit mA mA V mW °C °C Max. 260°C for 3 sec. max. (3 mm from the base of the epoxy bulb) Note: Pulse width ≤0.1 msec, duty ≤1/10. Typical Electrical & Optical Characteristics (TA = 25°C) Characteristics Forward Voltage Reverse Current Dominant Wavelength Luminous Flux 50% Power Angle Symbol VF IR λD ΦV 2θ½ Condition IF = 30 mA VR = 5 V IF = 30 mA IF = 30 mA IF = 30 mA Unit V μA nm mlm deg 462 400 470 800 120 Minimum Typical 3.6 Maximum 4.4 100 475 LD-CT118.000 Data Sheet: C Subject to change without notice. www.cree.com/ledlamps  Standard Bins for LP379PBL-C0G-03 (IF = 30 mA) Lamps are sorted to luminous flux (ΦV ), VF and dominant wavelength (λD) bins shown. Orders for LP379PBL1-60G-03 may be filled with any or all bins contained as below. All luminous flux (ΦV ), VF and dominant wavelength (λD) values shown and specified are at IF = 30 mA. X3 Luminous Flux (ΦV) X4 X5 E or above D C 460 nm 465 nm 470 nm 475 nm Dominant Wavelength (λD) Rank Luminous Flux Rank Voltage V7 2.8-3.0 V C 400-800 mlm D 600-1200 mlm V8 3.0-3.2 V V9 3.2-3.4 V V10 3.4-3.6 V V11 3.6-3.8 V V12 3.8-4.0 V V13 4.0-4.2 V V14 4.2-4.4 V Important Notes: 1. All ranks will be included per delivery; rank ratio will be based on the dice distribution. 2. No tolerance in the measurement of luminous flux. 3. Tolerance of measurement of dominant wavelength is ±1 nm. 4. Tolerance of measurement of VF is ±0.05 V. 5. Packaging methods are available for selection; please refer to the “Cree LED Lamp Packaging Standard” document. 6. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions. 7. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED product safely. Copyright © 2007 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 2 CLD-CT8.000 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Document No. SPE/LP379PBL1-C0G-03 Rev. No. 02 Graphs Graphs -50 Vr(V) -40 -30 -20 -10 0 0.0 -10.0 -20.0 -30.0 -40.0 Vf(V) 3.4 3.8 4.2 4.6 5.0 REVERSE VOLTAGE. Ir(uA) FIG.2 REVERSE CURRENT VS. -50.0 100.0 80.0 60.0 40.0 20.0 If (mA) 0.0 3.0 FIG.1 FORWARD CURRENT VS. FORWARD VOLTAGE. 2.5 2.0 1.5 1.0 0.5 0.0 0.0 If(mA) 20.0 40.0 60.0 80.0 100.0 100% 75% 50% 25% Half Power WL=28nm Domi WL= 470nm 0% 300 400 500 600 WL(nm) 700 FIG.3 RELATIVE LUMINOUS FLUX VS. FORWARD CURRENT FIG.4 RELATIVE LUMINOUS FLUX VS. WAVELENGTH. 50 40 30 20 10 0 IF(mA) 50% Power Angle : 120 Ie(%) 0 100% 80% 60% 40% Ta( C) 0 20 40 60 80 100 120 -90 -60 -30 0 30 60 90 20% 0% FIG.5 MAXIMUM FORWARD DC CURRENT VS AMBIENT TEMPERATURE (Tjmax=120 C) FIG.6 FAR FIELD PATTERN Items Prepared by Checked by Approved by FCN# Signatures LiuZM Aldosin David Date 2005-07-07 2005-07-07 2005-07-07 Rev. No 02 Date Revision History Change Description 2005-07-07 Release. FCN20050221 Data is subject to change without prior notice; please refer to COTCO Website for the latest version. Copyright@2002 Cotco International Ltd. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Copyright © 2007 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 4/4 Format #: COTCO-D-074 REV.4 3 CLD-CT8.000 Mechanical Dimensions All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus may extend about 1.5 mm down the leads. Burr around bottom of epoxy may sion mm max. g Dimen be 0.5 Drawin Document No. SPE/LP379PBL1-C0G-03 Rev. No. 02 maximum ting 0 00 5 32 +100 +100 Unit mA mA V mW °C °C Notes °C for 3 sec Max. e base of the epoxy bulb) RoHS Compliance The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 25 Ta = 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment ) (RoHS), as amended through April 21, 2006. s( °C Vision Advisory Claim Users at the Condition should be cautioned not to stare Typ. light of this LED product. The bright light can damage the eye. Min. Max. Unit IF = 30mA 4 VR = 5V --CLD-CT8.000 --- 3.6 --- 4.4 100 V A Copyright © 2007 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Kit Number System Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: Standard/Custom 0: Standard C: Custom VF 0: Full forward voltage distribution 1~9, A~Z . . . : special request * Wd/Color aaaaaaaaa-aaa-aa- x x x x x IV 1: Full-color distribution 2~9, A~Z . . . : special request * 0: Full luminous intensity distribution 1~9, A~Z . . . : special request * Packing type Product P/N 0: Standard = tube pack 1~9, A~Z . . . : special request * * Contact your Cree sales representative for ordering information. Standard Available Kits* Kit Number LP379PBL1-C0G-03-00001 Description P4 120 Blue 470nm, FULL RANK, Tube Pack * Please contact your Cree representative about the availability of non-standard kits. Copyright © 2007 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 5 CLD-CT8.000 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps
LP379PBL1-C0G-03 价格&库存
很抱歉,暂时无法提供与“LP379PBL1-C0G-03”相匹配的价格&库存,您可以联系我们找货
