a d ivision of CUI INC
date 08/2009 page 1 of 3
PART NUMBER: CP20351
DESCRIPTION: PELTIER MODULE
FEATURES
•solid state device •small and lightweight •precise temperature control •quiet operation •RoHS compliant
RoHS
INPUT
parameter resistance current voltage conditions/description measured by AC 4-terminal method at 25°C maximum current at ∆Tmax maximum voltage at ∆Tmax min 6.03 nom 6.7 max 7.37 2 3.8 units A V
OUTPUT
parameter Qmax
1
conditions/description Th = 27°C Th = 50°C Th = 27°C Th = 50°C
min
nom
max 15.2 16.9 66 72
units W W °C °C
∆Tmax2
Notes:
1. Maximum cooling capacity at Imax, Vmax, and ∆T = 0°C 2. Maximum temperature difference at Imax, Vmax, Q = 0 W (maximum parameters are measured in a vacuum)
GENERAL
parameter solder melting temperature assembly compression hot side plate MTBF
*for further information and product selection refer to peltier application notes.pdf
conditions/description connection between thermoelectric pairs
min
nom
max 138 98.07 10 90 200,000
units °C N/cm2 kgf/cm2 °C hours
20050 SW 112th Ave. Tualatin, Oregon 97062
phone 503.612.2300
fax 503.612.2383 www.v-infinity.com
date 08/2009 page 2 of 3
PERFORMANCE (Th=27°C)
Voltage Input (V)
16.0 2.0 A 1.6 A 1.2 A 8.0 0.8 A 0.4 A
Heat Pumped (W)
2.0 A 12.0 1.6 A 1.2 A 8.0 0.8 A
4.0
0.4 A
0 70 60 50 40 30 20 10 0
ΔT=Th−Tc(℃)
PERFORMANCE (Th=50°C)
2.0 A
Voltage Input (V)
16.0 1.6 A 1.2 A 0.8 A 0.4 A
8.0
16.0 2.0 A
Heat Pumped (W)
12.0 1.2 A
1.6 A
0.8 A 8.0
4.0
0.4 A
ΔT=Th−Tc(℃)
phone 503.612.2300
REV. A
DESCRIPTION NEW DRAWING
DATE 10/3/2007
0.80 (TYP)
Cold Side
5.1 0.01
Hot Side
100.0 5.0 7.0 3.0 Red (+)
30.0 0.3
30.0 0.3
HOT SIDE SCALE 1:1
Black (-)
TOLERANCE: ±0.1mm UNLESS OTHERWISE NOTED
RoHS
20050 SW 112th Ave. Tualatin, OR 97062 Phone: 503-612-2300 800-275-4899 Fax: 503-612-2383 Website: www.cui.com MATERIAL PLATING
TITLE:
PELTIER MODULE CERAMIC PLATE SEALER LEAD WIRE JOINT COVER
PART NO.
REV: UNITS:
A
CP20351
DRAWN BY: APPROVED BY:
MM [INCHES]
SCALE:
PC FILE NAME:
CP20351
COPYRIGHT 2009 BY CUI INC.
Al203 (Alumina) Silicon Rubber RTV UL1332 Silicon Rubber RTV
White Color White Color Tin White Color
ZRJ
2:1
很抱歉,暂时无法提供与“CP20351”相匹配的价格&库存,您可以联系我们找货
