CP41B-WES-CM0P0244
CP41B-WES-CM0P0244
    WOLFSPEED
    DIP4
    LED COOL WHITE CLEAR 4DIP T/H
CP41B-WES-CM0P0244 数据手册
Cree® P4 LED CP41B-WES/WGS Data Sheet This revolutionary package design allows the lighting designer to reduce the number of LEDs required and provide a more uniform and unique illuminated appearance than with other LED solutions. This is possible through the efficient optical-package design and high-current capabilities. The low-profile package can be easily coupled with reflectors or lenses to efficiently distribute light and provide the desired lit appearance. This product family employs green and blue LED materials, which allows designers to match the color of many lighting applications such as vehicle signal lamps and amusement lighting. FEATURES • • • Size (mm): 7.6 x 7.6 Color Temperatures (K): » Cool White: Min. (4600) / Typical (9000) Luminous Flux (mlm) » CP41B-WES (3850-11000) » CP41B-WGS (3850-11000) Viewing Angle: » CP41B-WES: 60 degrees » CP41B-WGS: 90 degrees Lead-Free RoHS-Compliant APPLICATIONS • • Channel Letter Amusement • • • 1 LD-CT1092.00 Data Sheet: C Subject to change without notice. www.cree.com/ledlamps 1 Absolute Maximum Ratings (TA = 25°C) Items Symbol Absolute Maximum Rating CP41B-WES/WGS Forward Current Peak Forward Current Reverse Voltage Power Dissipation Operation Temperature Storage Temperature Lead Soldering Temperature Note Unit IF IFP VR PD Topr Tstg Tsol 35 100 5 154 -40 ~ +95 -40 ~ +100 mA mA V mW °C °C Max. 260°C for 3 sec. max. (3 mm from the base of the epoxy bulb) Note: Pulse width ≤0.1 msec, duty ≤1/10. Typical Electrical & Optical Characteristics (TA = 25°C) Characteristics Forward Voltage Reverse Current Luminous Flux Luminous Intensity Chromaticity Coordinates 50% Power Angle CP41B-WES/WGS CP41B-WES/WGS CP41B-WES/WGS CP41B-WES CP41B-WGS CP41B-WES/WGS CP41B-WES/WGS CP41B-WES CP41B-WGS Symbol VF IR Φv IV IV x y 2θ½ 2θ½ Condition IF = 30 mA VR = 5 V IF = 30 mA IF = 30 mA IF = 30 mA IF = 30 mA IF = 30 mA IF = 30 mA IF = 30 mA deg deg Unit V μA mlm mcd mcd 3850 7000 5200 3000 0.2895 0.2905 60 90 Minimum Typical 3.6 Maximum 4.4 100 Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 2 CLD-CT1092.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Flux Bin Limit (IF = 30 mA) Cool White (CP41B-WES/WGS) Bin Code K0 L0 M0 N0 P0 Min.(mlm) 3850 4400 5500 6600 8730 Max.(mlm) 4400 5500 6600 8730 11000 VF Bin Limit (IF = 30 mA) Cool White (CP41B-WES/WGS) Bin Code 27 28 29 2a 2b 2c 2d 2e Min.(V) 2.8 3.0 3.2 3.4 3.6 3.8 4.0 4.2 Max.(V) 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 Tolerance of measurement of luminous flux is ±15%. Color Bin Limit (IF = 30 mA) Bin Code Subbin x 0.2545 Wa 0.2633 0.2545 0.2450 0.2633 Wb 0.2720 0.2640 0.2545 0.2545 Wc 0.2640 0.2720 0.2633 0.2633 Wd 0.2720 0.2800 0.2720 0.2640 We 0.2735 0.2808 0.2720 0.2720 Wf 0.2808 0.2880 0.2800 0.2735 Wg 0.2830 0.2895 0.2808 0.2808 Wh 0.2895 0.2960 0.2880 y 0.2480 0.2410 0.2245 0.2290 0.2410 0.2340 0.2200 0.2245 0.2480 0.2670 0.2575 0.2410 0.2410 0.2575 0.2480 0.2340 0.2670 0.2860 0.2740 0.2575 0.2575 0.2740 0.2620 0.2480 0.2860 0.3050 0.2905 0.2740 0.2740 0.2905 0.2760 0.2620 Ws W4 Wq Wp Wn W3 Wk Wj Bin Code Subbin x 0.2830 0.2950 0.2998 0.2895 0.2895 0.2998 0.3045 0.2960 0.2950 Wm 0.3070 0.3100 0.2998 0.2998 0.3100 0.3130 0.3045 0.3070 0.3185 0.3200 0.3100 0.3100 0.3200 0.3215 0.3130 0.3185 Wr 0.3300 0.3300 0.3200 0.3200 0.3300 0.3300 0.3215 y 0.3050 0.3210 0.3028 0.2905 0.2905 0.3028 0.2865 0.2760 0.3210 0.3370 0.3150 0.3028 0.3028 0.3150 0.2970 0.2865 0.3370 0.3485 0.3270 0.3150 0.3150 0.3270 0.3075 0.2970 0.3485 0.3600 0.3390 0.3270 0.3270 0.3390 0.3180 0.3075 W5 Wu Wt Bin Code Tolerance of measurement of VF is ±0.05 V. Subbin x 0.3300 0.3455 0.3443 0.3300 0.3300 0.3443 0.3430 0.3300 0.3455 y 0.3600 0.3725 0.3535 0.3390 0.3390 0.3535 0.3345 0.3180 0.3725 0.3850 0.3680 0.3535 0.3535 0.3680 0.3510 0.3345 W1 Wv 0.3610 0.3585 0.3443 0.3443 Ww 0.3585 0.3560 0.3430 Tolerance of measurement of the color coordinates is ±0.01. W2 Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 3 CLD-CT1092.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps CIE Chromaticity Diagram 0 .3 9 0 0 00 K 60 50 70 0 .3 5 0 0 K 00 80 00 W W W p q W rW s 4 t u W K K 00 W y 0 .2 7 0 0 n 3 10 W W c b W g W k W e d h W 2 W f 0 .1 9 0 0 0 .2 3 0 0 0 .2 7 0 0 W 0 .2 3 0 0 W aW 1 0 .3 1 0 0 x W 0 .3 1 0 0 0K 90 W W j W 00 m W W 0 .3 5 0 0 W 5 00 W K v w 0 .3 9 0 0 Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 4 CLD-CT1092.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Order Code Table* 60 degrees Color Cool White Cool White Cool White Cool White Cool White Cool White Kit Number CP41B-WES-CK0P0154 CP41B-WES-CL0P0134 CP41B-WES-CM0P0134 CP41B-WES-CM0P0234 CP41B-WES-CM0P0244 CP41B-WES-CN0P0134 Viewing Angle 60 60 60 60 60 60 Luminous Flux (mlm) Min. 3850 4400 5500 5500 5500 6600 Max. 11000 11000 11000 11000 11000 11000 Color Bin Code W1,W2,W3,W4,W5 W1,W2,W3 W1,W2,W3 W2,W3 W2,W3,W4 W1,W2,W3 90 degrees Color Cool White Cool White Cool White Cool White Cool White Cool White Kit Number CP41B-WGS-CK0P0154 CP41B-WGS-CL0P0134 CP41B-WGS-CM0P0134 CP41B-WGS-CM0P0234 CP41B-WGS-CM0P0244 CP41B-WGS-CN0P0134 Viewing Angle 90 90 90 90 90 90 Luminous Flux (mlm) Min. 3850 4400 5500 5500 5500 6600 Max. 11000 11000 11000 11000 11000 11000 Color Bin Code W1,W2,W3,W4,W5 W1,W2,W3 W1,W2,W3 W2,W3 W2,W3,W4 W1,W2,W3 Notes: • The above kit numbers represent order codes that include multiple flux-bin and color-bin codes. Only one flux-bin code and one color-bin code will be shipped on each tube. And single flux-bin code and single color-bin codes will not be orderable. • Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions. • Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED product safely. Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 5 CLD-CT1092.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Graphs  The above data are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice. Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 6 CLD-CT1092.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Mechanical Dimensions All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus may extend about 1.5 mm down the leads. Document No. SPE/LP377FWH1-90G Burr around bottom of epoxy may be 0.5 mm max. Rev. No. 01 CP41B-WES: Dimension Drawing CP41B-WGS: Unit mA mA V mW °C °C c Max. epoxy bulb)  °C) Notes Min. RoHS Compliance Typ. Max. Unit The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the V --3.6 4.4 threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (--RoHS), as amended through April 21, 2006. µA --100 2130 --------7 Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye. 3800 --- mcd 6500 0.283 0.264 ------- mlm ----Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 90 CLD-CT1092.001 --- deg Kit Number System Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 8 CLD-CT1092.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps Package Features: • • • • • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. The boxes are not water-resistant, and they must be kept away from water and moisture. The Tube Pack type of packaging. Max 60 pcs per tube. R xxx xxx R C OL OR LED LAMP T YPE LXXXXX XXX-XXX LOT QT Y RANK Iv Vf Hu e X XX XX J OWAXXXXX -XX-XXX P CS AX XXX XXX XXX X Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. 9 CLD-CT1092.001 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps
CP41B-WES-CM0P0244 价格&库存
很抱歉,暂时无法提供与“CP41B-WES-CM0P0244”相匹配的价格&库存,您可以联系我们找货
CP41B-WES-CM0P0244
    • 5+2.78118
    库存:60
