CP85338
CP85338
    CUIDEVICES
    PELTIER MOD 30 X 3.8MM 8.5A INP
CP85338 数据手册
a d ivision of CUI INC date 08/2009 page 1 of 3 PART NUMBER: CP85338 DESCRIPTION: PELTIER MODULE FEATURES •solid state device •small and lightweight •precise temperature control •quiet operation •RoHS compliant RoHS INPUT parameter resistance current voltage conditions/description measured by AC 4-terminal method at 25°C maximum current at ∆Tmax maximum voltage at ∆Tmax min 0.81 nom 0.90 max 0.99 8.5 8.6 units  A V OUTPUT parameter Qmax 1 conditions/description Th = 27°C Th = 50°C Th = 27°C Th = 50°C min nom max 42.0 46.9 68 75 units W W °C °C ∆Tmax2 Notes: 1. Maximum cooling capacity at Imax, Vmax, and ∆T = 0°C 2. Maximum temperature difference at Imax, Vmax, Q = 0 W (maximum parameters are measured in a vacuum) GENERAL parameter solder melting temperature assembly compression hot side plate MTBF *for further information and product selection refer to peltier application notes.pdf conditions/description connection between thermoelectric pairs min nom max 138 98.07 10 90 200,000 units °C N/cm2 kgf/cm2 °C hours 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 www.v-infinity.com a d ivision of CUI INC date 08/2009 page 2 of 3 PART NUMBER: CP85338 DESCRIPTION: PELTIER MODULE PERFORMANCE (Th=27°C) 8.5 A Input Voltage (V) 8.0 6.8 A 5.1 A 4.0 1.7 A 3.4 A 0 40.0 8.5 A Heat Pumped (W) 30.0 6.8 A 5.1 A 20.0 3.4 A 10.0 1.7 A 0 70 60 50 40 30 20 10 0 ΔT=Th−Tc(℃) PERFORMANCE (Th=50°C) 8.5 A 6.8 A 5.1 A 3.4 A Input Voltage (V) 8.0 4.0 1.7 A 0 40.0 8.5 A 6.8 A Heat Pumped (W) 30.0 5.1 A 3.4 A 20.0 10.0 1.7 A 0 70 60 50 40 30 20 10 0 ΔT=Th−Tc(℃) 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 www.v-infinity.com REV. A DESCRIPTION NEW DRAWING DATE 10/3/2007 0.80 (TYP) Cold Side 3.8 0.01 Hot Side 100.0 5.0 7.0 3.0 Red (+) 30.0 0.3 30.0 0.3 HOT SIDE SCALE 1:1 Black (-) TOLERANCE: ±0.1mm UNLESS OTHERWISE NOTED RoHS 20050 SW 112th Ave. Tualatin, OR 97062 Phone: 503-612-2300 800-275-4899 Fax: 503-612-2383 Website: www.cui.com MATERIAL PLATING TITLE: PELTIER MODULE CERAMIC PLATE SEALER LEAD WIRE JOINT COVER PART NO. REV: UNITS: A CP85338 DRAWN BY: APPROVED BY: MM [INCHES] SCALE: PC FILE NAME: CP85338 COPYRIGHT 2009 BY CUI INC. Al203 (Alumina) Silicon Rubber RTV UL1332 Silicon Rubber RTV White Color White Color Tin White Color ZRJ 2:1
CP85338 价格&库存
很抱歉,暂时无法提供与“CP85338”相匹配的价格&库存,您可以联系我们找货
