S-89110ANC-1A1-TFG
S-89110ANC-1A1-TFG
    SIISEMICONDUCTORCORPORATION(精工电子)
    SC-70-5
    ICOPAMPGP180KHZSC88A
S-89110ANC-1A1-TFG 数据手册
Rev.2.2_00 MINI ANALOG SERIES CMOS OPERATIONAL AMPLIFIER S-89110A/89120A The mini-analog series is a group of ICs that incorporate a general purpose analog circuit in a small package. The S-89110A/89120A is a CMOS type single operational amplifier that has a phase compensation circuit, and that can be driven at a lower voltage with lower current consumption than existing bipolar operational amplifiers. These features make this product the ideal solution for small battery-powered portable equipment. The S-89110A/89120A is a single operational amplifier. Features Lower operating voltage than the conventional general-purpose operational amplifiers: Low current consumption: Low input offset voltage: Output full swing Lead-free products VDD = 1.8 to 5.5 V IDD = 50 μA (S-89110A) IDD = 10 μA (S-89120A) 4.0 mV (max.) No external capaciters required for internal phase compensation Application Cellular phones PDAs Notebook PCs Digital cameras Digital video cameras Package Package Name SC-88A Package NP005-B Drawing Code Tape NP005-B Reel NP005-B Product Name List Table 1 Current consumption SC-88A IDD = 50 μA S-89110ANC-1A1-TFG IDD = 10 μA S-89120ANC-1A2-TFG Remark Delivery form : Taping only Seiko Instruments Inc. 1 MINI ANALOG SERIES S-89110A/89120A Pin Configuration SC-88A Top view VDD 5 OUT 4 CMOS OPERATIONAL AMPLIFIER Rev.2.2_00 Table 2 Pin No. 1 2 3 4 5 Symbol IN(+) VSS IN(−) OUT VDD Description Non-inverted input pin GND pin Inverted input pin Output pin Positive power supply pin Internal Equivalent Circuit Figure 3  Figure 3 Figure 2 Figure 4 + − 1 3 2 IN (+) VSS IN (−) Figure 1 Internal Equivalent Circuit Output pin VDD Input pin VDD VSS Figure 2 VDD pin VDD VSS Figure 3 VSS Figure 4 2 Seiko Instruments Inc. MINI ANALOG SERIES Rev.2.2_00 Absolute Maximum Ratings Table 3 Parameter Power supply voltage Input voltage Output voltage Differential input voltage Power dissipation Symbol VDD VIN VOUT VIND PD CMOS OPERATIONAL AMPLIFIER S-89110A/89120A Ratings VSS−0.3 to VSS+10.0 VSS−0.3 to VSS+7.0 (7.0 max.) VSS−0.3 to VDD+0.3 (7.0 max.) ±7.0 200 (When not mounted on board) 350*1 −40 to +85 −55 to +125 Unit V V V V mW mW °C °C Operating temperature range Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size : 114.3 mm × 76.2 mm × t1.6 mm (2) Board name : JEDEC STANDARD51-7 Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 400 Power Dissi pation (PD) [ mW] 350 300 250 200 150 100 50 0 0 100 150 50 Ambient Temperature (Ta) [ °C] Figure 5 Power Dissipation of Package (When Mounted on Board) Recommended Operating Power Supply Voltage Range Table 4 Parameter Operating power supply voltage range Symbol VDD Range 1.8 to 5.5 Unit V Seiko Instruments Inc. 3 MINI ANALOG SERIES S-89110A/89120A CMOS OPERATIONAL AMPLIFIER Rev.2.2_00 Electrical Characteristics 1. VDD = 5.0 V Table 5 DC Characteristics (VDD = 5.0 V) Parameter Symbol Current consumption Input offset voltage Input offset current Input bias current Common-mode input voltage range Voltage gain (open loop) Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio Source current Sink current IDD VIO IIO IBIAS VCMR GV VOH VOL CMRR PSRR ISOURCE ISINK S-89110A S-89120A VOL = VDD Measurement Conditions S-89110A S-89120A ⎯ ⎯ ⎯ ⎯ ⎯ RL = 1.0 MΩ RL = 1.0 MΩ ⎯ ⎯ VOH = 0 V Min. ⎯ ⎯ −4 ⎯ ⎯ 0 70 4.9 60 60 120 25 20 (Ta = 25°C unless otherwise specified) Typ. Max. Unit Measurement Circuit 50 120 μA Figure 10 10 30 μA ±3 +4 mV Figure 6 1 pA ⎯ ⎯ 1 pA ⎯ ⎯ ⎯ 80 ⎯ 70 70 ⎯ ⎯ ⎯ 4.3 ⎯ ⎯ 0.1 ⎯ ⎯ ⎯ ⎯ ⎯ V dB V dB dB μA mA Figure 7 ⎯ Figure 8 Figure 9 Figure 7 Figure 6 Figure 11 Figure 12 Table 6 AC Characteristics (VDD = 5.0 V) Parameter Symbol Slew rate Gain-bandwidth product SR GBP (Ta = 25°C unless otherwise specified) Measurement Conditions Min. Typ. Max. Unit RL = 1.0 MΩ, CL = 15 pF S-89110A 0.07 ⎯ ⎯ V/μs (Refer to Figure 13.) S-89120A 0.015 ⎯ ⎯ S-89110A 180 ⎯ ⎯ kHz ⎯ 40 S-89120A ⎯ ⎯ 4 Seiko Instruments Inc. MINI ANALOG SERIES Rev.2.2_00 2. VDD = 3.0 V Table 7 DC Characteristics (VDD = 3.0 V) Parameter Symbol Current consumption Input offset voltage Input offset current Input bias current Common-mode input voltage range Voltage gain (open loop) Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio Source current Sink current IDD VIO IIO IBIAS VCMR GV VOH VOL CMRR PSRR ISOURCE ISOURCE ISINK S-89110A S-89120A VOL = VDD Measurement Conditions S-89110A S-89120A ⎯ ⎯ ⎯ ⎯ ⎯ RL = 1.0 MΩ RL = 1.0 MΩ ⎯ ⎯ VOH = 0 V CMOS OPERATIONAL AMPLIFIER S-89110A/89120A Min. ⎯ ⎯ −4 ⎯ ⎯ 0 70 2.9 ⎯ 60 60 120 25 15 (Ta = 25°C unless otherwise specified) Typ. Max. Unit Measurement Circuit 50 120 μA Figure 10 10 30 μA ±3 +4 mV Figure 6 1 pA ⎯ ⎯ 1 pA ⎯ ⎯ ⎯ 80 ⎯ ⎯ 70 70 ⎯ ⎯ ⎯ 2.3 ⎯ ⎯ 0.1 ⎯ ⎯ ⎯ ⎯ ⎯ V dB V V dB dB μA mA Figure 7 ⎯ Figure 8 Figure 9 Figure 7 Figure 6 Figure 11 Figure 12 Table 8 AC Characteristics (VDD = 3.0 V) Parameter Symbol Slew rate Gain-bandwidth product SR GBP (Ta = 25°C unless otherwise specified) Measurement Conditions Min. Typ. Max. Unit RL = 1.0 MΩ, CL = 15 pF S-89110A 0.07 ⎯ ⎯ V/μs (Refer to Figure 13.) S-89120A 0.015 ⎯ ⎯ S-89110A 175 ⎯ ⎯ kHz ⎯ 35 S-89120A ⎯ ⎯ Seiko Instruments Inc. 5 MINI ANALOG SERIES S-89110A/89120A 3. VDD = 1.8 V CMOS OPERATIONAL AMPLIFIER Rev.2.2_00 Table 9 DC Characteristics (VDD = 1.8 V) Parameter Symbol Current consumption Input offset voltage Input offset current Input bias current Common-mode input voltage range Voltage gain (open loop) Maximum output swing voltage Common-mode input signal rejection ratio Power supply voltage rejection ratio Source current Sink current IDD VIO IIO IBIAS VCMR GV VOH VOL CMRR PSRR ISOURCE ISOURCE ISINK S-89110A S-89120A VOL = VDD Measurement Conditions S-89110A S-89120A ⎯ ⎯ ⎯ ⎯ ⎯ RL = 1.0 MΩ RL = 1.0 MΩ ⎯ ⎯ VOH = 0 V Min. ⎯ ⎯ −4 ⎯ ⎯ 0 70 1.7 ⎯ 60 60 100 20 5 (Ta = 25°C unless otherwise specified) Typ. Max. Unit Measurement Circuit 50 120 μA Figure 10 10 30 μA ±3 +4 mV Figure 6 1 pA ⎯ ⎯ 1 pA ⎯ ⎯ ⎯ 80 ⎯ ⎯ 70 70 ⎯ ⎯ ⎯ 1.1 ⎯ ⎯ 0.1 ⎯ ⎯ ⎯ ⎯ ⎯ V dB V V dB dB μA mA Figure 7 ⎯ Figure 8 Figure 9 Figure 7 Figure 6 Figure 11 Figure 12 Table 10 AC Characteristics (VDD = 1.8 V) Parameter Symbol Slew rate Gain-bandwidth product SR GBP (Ta = 25°C unless otherwise specified) Measurement Conditions Min. Typ. Max. Unit RL = 1.0 MΩ, CL = 15 pF S-89110A 0.07 ⎯ ⎯ V/μs (Refer to Figure 13.) S-89120A 0.015 ⎯ ⎯ S-89110A 160 ⎯ ⎯ kHz ⎯ 30 S-89120A ⎯ ⎯ 6 Seiko Instruments Inc. MINI ANALOG SERIES Rev.2.2_00 Measurement Circuit CMOS OPERATIONAL AMPLIFIER S-89110A/89120A 1. Power supply voltage rejection ratio, input offset voltage Power supply voltage rejection ratio (PSRR) VDD The power supply voltage rejection ratio (PSRR) can be calculated by the following expression, with VOUT RF measured at each VDD. RS − + RF VOUT Measurement conditions: When VDD = 1.8 V: VDD = VDD1, VOUT = VOUT1 When VDD = 5.0 V: VDD = VDD2, VOUT = VOUT2 PSRR = 20 log VDD1 − VDD2 V V VOUT1− DD1 − VOUT2− DD2 2 2 × R F + RS RS RS VCMR=VDD / 2 Input offset voltage (VIO) VDD  Rs  VIO =  VOUT − × 2  RF + RS  Figure 6 2. Common-mode input signal rejection ratio, common-mode input voltage range Common-mode input signal rejection ratio (CMRR) VDD The common-mode input signal rejection ratio (CMRR) can be calculated by the following RF expression, with VOUT measured at each VIN. RS − + RF VOUT Measurement conditions: When VIN = VCMR (max.): VIN = VIN1, VOUT = VOUT1 When VIN = VDD/2: VIN = VIN2, VOUT = VOUT2 CMRR = 20 log VIN1 − VIN2 VOUT1 − VOUT2 × R F + RS RS RS VIN VDD / 2 Common-mode input voltage range (VCMR) The common-mode input voltage range is the range of VIN in which VOUT satisfies the common-mode input signal rejection ratio specifications. Figure 7 Seiko Instruments Inc. 7 MINI ANALOG SERIES S-89110A/89120A CMOS OPERATIONAL AMPLIFIER Rev.2.2_00 3.Maximum output swing voltage VDD − + RL VOH Maximum output swing voltage (VOH) Measurement conditions: VIN1 = VDD − 0.5 V 2 VDD VIN2 = + 0.5 V 2 RL = 1 MΩ VIN1 VIN2 Figure 8 VDD RL − + VOL Maximum output swing voltage (VOL) Measurement conditions: VIN1 = VDD + 0.5 V 2 VDD VIN2 = − 0.5 V 2 RL = 1 MΩ VIN1 VIN2 Figure 9 4. Current consumption VDD Current consumption (IDD) A − + VCMR=VDD / 2 Figure 10 8 Seiko Instruments Inc. MINI ANALOG SERIES Rev.2.2_00 CMOS OPERATIONAL AMPLIFIER S-89110A/89120A 5. Source current VDD Source current (ISOURCE) Measurement conditions: VIN1 = VDD − 0.5 V 2 VDD VIN2 = + 0.5 V 2 − + A VIN1 VIN2 Figure 11 6. Sink current VDD Sink current (ISINK) Measurement conditions: A VDD + 0.5 V 2 VDD VIN2 = − 0.5 V 2 VIN1 = − + VIN1 VIN2 Figure 12 7. Slew rate (SR): Measured by the voltage follower circuit tR= tF=20 ns (0 V to VCMR Max.) IN (+) = VCMR Max. IN (+) = 0 V VOUT (= IN (−)) tTHL VCMR Max. VCMR Max. × 0.9 VOUT (= IN (−)) tTLH VCMR Max. × 0.1 VCMR Max. × 0.8 tTLH VCMR Max. × 0.8 SR = tTHL SR = Figure 13 Seiko Instruments Inc. 9 MINI ANALOG SERIES S-89110A/89120A Precaution CMOS OPERATIONAL AMPLIFIER Rev.2.2_00 Do not apply an electrostatic discharge to this IC that exceeds performance ratings of the built-in electrostatic protection circuit. SII claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 10 Seiko Instruments Inc. MINI ANALOG SERIES Rev.2.2_00 Characteristics (Reference Data) 1. Current consumption vs. Power supply voltage (a) S-89110A IDD−VDD, VSS = 0 V 100 80 IDD (μA) 60 40 20 0 0 1 Ta=−40°C 25 ° C 85°C CMOS OPERATIONAL AMPLIFIER S-89110A/89120A (b) S-89120A IDD−VDD, VSS = 0 V 20 15 IDD (μ A) 10 5 5 6 25 ° C 85°C Ta=−40°C 2 3 4 VDD (V) 0 0 1 2 3 4 VDD (V) 5 6 2. Voltage gain vs. Frequency (a) S-89110A GV−f, VDD = 3.0 V, VSS = 0 V 100 80 GV (dB) 60 40 20 0 0.001 0.01 0.1 1 10 f (kHz) 100 1000 85°C GV (dB) Ta=−40°C 25 ° C 100 80 60 40 20 0 0.001 0.01 0.1 1 10 f (kHz) 100 1000 85°C Ta=−40°C (b) S-89120A GV−f, VDD = 3.0 V, VSS = 0 V 25°C 3. Output current 3-1. ISOURCE vs. Power supply voltage (a) S-89110A ISOURCE−VDD, VOH = 0 V , VSS = 0 V 500 ISOURCE (μA) 400 300 200 100 0 0 1 2 3 4 VDD (V) 5 6 Ta=−40°C 25°C 85°C (b) S-89120A ISOURCE−VDD, VOH = 0 V , VSS = 0 V 100 ISOURCE (μA) 80 60 40 20 0 0 1 2 3 4 VDD (V) 5 6 Ta=−40°C 25°C 85 ° C Seiko Instruments Inc. 11 MINI ANALOG SERIES S-89110A/89120A CMOS OPERATIONAL AMPLIFIER Rev.2.2_00 3-2. Output voltage (VOH) vs. ISOURCE (a) S-89110A VOH−ISOURCE, VDD = 1.8 V , VSS = 0 V 2.0 Ta=−40°C 1.5 25°C VOH ( V) 1.0 0.5 0.0 0 50 100 150 200 250 300 350 ISOURCE ( μA) 85°C VOH−ISOURCE, VDD = 3.0 V , VSS = 0 V 3.0 2.5 VOH (V) 2.0 1.5 1.0 0.5 0.0 0 50 100 150 200 250 300 350 ISOURCE ( μA) Ta=−40°C 85°C 25°C VOH−ISOURCE, VDD = 5.0 V , VSS = 0 V 5.0 4.0 VOH ( V) 3.0 2.0 1.0 0.0 50 100 150 200 250 300 350 ISOURCE ( μA) (b) S-89120A VOH−ISOURCE, VDD = 1.8 V , VSS = 0 V 2.0 1.5 VOH (V) 1.0 0.5 0.0 0 10 20 40 50 ISOURCE ( μA) 30 60 70 Ta=−40°C 25°C 25°C 85°C Ta=−40°C 0 VOH−ISOURCE, VDD = 3.0 V , VSS = 0 V 3.0 2.5 VOH ( V) 2.0 1.5 1.0 0.5 0.0 0 10 20 30 40 50 ISOURCE ( μA) 60 70 85°C Ta=−40°C 25 ° C 85°C VOH−ISOURCE, VDD = 5.0 V , VSS = 0 V 5.0 4.0 VOH (V) 3.0 2.0 1.0 0.0 0 10 20 30 40 50 ISOURCE ( μA) 60 70 Ta=−40°C 85 ° C 25 ° C 12 Seiko Instruments Inc. MINI ANALOG SERIES Rev.2.2_00 CMOS OPERATIONAL AMPLIFIER S-89110A/89120A 3-3. ISINK vs. Power supply voltage (a) S-89110A ISINK−VDD, VOL = VDD , VSS = 0 V 100 80 ISINK (mA) 60 40 20 0 0 1 2 3 4 VDD (V) 5 6 85°C 25 ° C Ta=−40°C 100 80 ISINK (mA) 60 40 20 0 0 1 2 3 4 VDD (V) 5 6 85 ° C 25 ° C Ta=−40°C (b) S-89120A ISINK−VDD, VOL = VDD , VSS = 0 V Seiko Instruments Inc. 13 MINI ANALOG SERIES S-89110A/89120A CMOS OPERATIONAL AMPLIFIER Rev.2.2_00 3-4. Output voltage (VOL) vs. ISINK (a) S-89110A VOL−ISINK, VDD = 1.8 V, VSS = 0 V 2.0 1.5 VOL ( V) 1.0 0.5 0.0 0 5 10 ISINK (mA) 15 20 25 ° C VOL−ISINK, VDD = 3.0 V, VSS = 0 V 3.0 2.5 VOL (V) 2.0 1.5 1.0 0.5 0.0 0 10 20 ISINK (mA) 30 40 85°C Ta=−40°C 25°C 85 ° C Ta=−40°C VOL−ISINK, VDD = 5.0 V, VSS = 0 V 5.0 4.0 VOL ( V) 3.0 2.0 1.0 0.0 0 20 40 ISINK (mA) 60 80 85 ° C Ta=−40°C 25 ° C (b) S-89120A VOL−ISINK, VDD = 1.8 V, VSS = 0 V 2.0 1.5 VOL (V) 1.0 0.5 0.0 0 5 10 ISINK (mA) 15 20 85 ° C Ta=−40°C 25 ° C VOL−ISINK, VDD = 3.0 V, VSS = 0 V 3.0 2.5 VOL (V) 2.0 1.5 1.0 0.5 0.0 0 10 20 ISINK (mA) 30 40 Ta=−40°C 85 ° C 25°C VOL−ISINK, VDD = 5.0 V, VSS = 0 V 5.0 4.0 VOL (V) 3.0 2.0 1.0 0.0 0 20 40 ISINK (mA) 60 80 85 ° C Ta=−40°C 25 ° C 14 Seiko Instruments Inc. 2.0±0.2 1.3±0.1 5 4 1 2 0.65 3 0.65 0.15 -0.05 +0.1 0.2 +0.1 -0.05 No. NP005-B-P-SD-1.1 TITLE No. SCALE UNIT SC88A-B-PKG Dimensions NP005-B-P-SD-1.1 mm Seiko Instruments Inc. 4.0±0.1 2.0±0.1 1.1±0.1 ø1.55±0.05 0.2±0.05 0.3 4.0±0.1 (2.25) ø1.05±0.1 2.05±0.1 321 4 5 Feed direction No. NP005-B-C-SD-2.0 TITLE No. SCALE UNIT SC88A-B-Carrier Tape NP005-B-C-SD-2.0 mm Seiko Instruments Inc. 12.5max. Enlarged drawing in the central part ø13±0.2 9.0±0.3 (60°) (60°) No. NP005-B-R-SD-2.1 TITLE No. SCALE UNIT mm SC88A-B-Reel NP005-B-R-SD-2.1 QTY. 3000 Seiko Instruments Inc. • • • • • • The information described herein is subject to change without notice. Seiko Instruments Inc. is not responsible for any problems caused by circuits or diagrams described herein whose related industrial properties, patents, or other rights belong to third parties. The application circuit examples explain typical applications of the products, and do not guarantee the success of any specific mass-production design. When the products described herein are regulated products subject to the Wassenaar Arrangement or other agreements, they may not be exported without authorization from the appropriate governmental authority. Use of the information described herein for other purposes and/or reproduction or copying without the express permission of Seiko Instruments Inc. is strictly prohibited. The products described herein cannot be used as part of any device or equipment affecting the human body, such as exercise equipment, medical equipment, security systems, gas equipment, or any apparatus installed in airplanes and other vehicles, without prior written permission of Seiko Instruments Inc. Although Seiko Instruments Inc. exerts the greatest possible effort to ensure high quality and reliability, the failure or malfunction of semiconductor products may occur. The user of these products should therefore give thorough consideration to safety design, including redundancy, fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community damage that may ensue.
S-89110ANC-1A1-TFG 价格&库存
很抱歉,暂时无法提供与“S-89110ANC-1A1-TFG”相匹配的价格&库存,您可以联系我们找货
