page date
1 of 5
11/12/2007
PART NUMBER: CPE-120
DESCRIPTION: piezo audio transducer
SPECIFICATONS
operating voltage current consumption sound pressure level electrostatic capacity operating tempurature storage tempurature dimensions weight material terminal RoHS 30 Vp-p max. 8 mA max. at 10 Vp-p, sqaure wave, 6.0 Khz 88 db min. at 10 cm/10 Vp-p, sqaure wave, 6.0 Khz 12,000 ± 30% at 1 Khz/1 V -30 ~ +85° C -40 ~ +95° C Ø24.0 x H4.0 mm 2.4 g max. ABS UL-94 1/16” HB high heat (black) wire type yes
APPEARANCE DRAWING
tolerance: ±0.5 units: mm
1.50
2.1 (2 PLCS)
UL1095 LF 28AWG 5.0 2.0 red
34.0
24.0 100.0 5.0 black
29.0
4.0
20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 phone fax
page date
2 of 5
11/12/2007
FREQUENCY RESPONSE CURVE
MEASUREMENT METHOD
S.P.L. Measuring Circuit Input Signal: 10 Vp-p, 6.0 KHz, square wave Mic: RION S.P.L. meter UC30 or equivalent S.G.: Hewlett Packard 33120A function generator or equivalent
page date
3 of 5
11/12/2007
MECHANICAL CHARACTERISTICS
item solderability test condition Stripped wires are immersed in rosin for 5 seconds and then immersed in solder bath of 270 ±5°C for 3 ±1 seconds. Stripped wires are immersed up to 1.5mm from buzzer’s body in solder bath of 300 ±5°C for 3 ±0.5 seconds or 260 ±5°C for 10 ±1 seconds. The pull force shall be applied to lead wire: Horizontal 3.0N for 30 seconds Vertical 2.0N for 30 seconds The buzzer shall be measured after applying a vibration amplitude of 1.5 mm with 10 to 55 Hz band of vibration frequency to each of the 3 perpendicular directions for 2 hours. The part will be dropped from a height of 75 cm onto a 40 mm thick wooden board 3 times in 3 axes (X, Y, Z) for a total of 9 drops. evaluation standard 90% min. of the lead terminals will be wet with solder (except the edge of the terminal). No interference in operation.
soldering heat resistance
lead wire pull strength
No damage or cutting off. The value of oscillation frequency/current consumption should be ±10% of the initial measurements. The SPL should be within ±10dB compared with the initial measurement.
vibration
drop test
ENVIRONMENT TEST
item high temp. test low temp. test humidity test temp. cycle test test condition After being placed in a chamber at +95°C for 240 hours. After being placed in a chamber at -40°C for 240 hours. After being placed in a chamber at +40°C and 90±5% relative humidity for 240 hours. The part shall be subjected to 5 cycles. One cycle will consist of:
+95
evaluation standard
+ -40
The buzzer will be measured after being placed at +25°C for 4 hours. The value of the oscillation frequency/current consumption should be ±10% compared to the initial measurements. The SPL should be within ±10dB compared to the initial measurements.
0.5hr 0.5hr 0.25 0.5hr
0.5hr
0.5hr 0.25
3hours
page date
4 of 5
11/12/2007
RELIABILITY TEST
item operating (life test) test condition 1. Continuous life test: The part will be subjected to 48 hours of continuous operation at +70°C with rated voltage applied. 2. Intermittent life test: A duty cycle of 1 minute on, 1 minutes off, a minimum of 5,000 times at room temp (+25 ±2°C) with rated voltage applied. evaluation standard The buzzer will be measured after being placed at +25°C for 4 hours. The value of the oscillation frequency/current consumption should be ±10% compared to the initial measurements. The SPL should be within ±10dB compared to the initial measurements.
TEST CONDITIONS
standard test condition judgement test condition a) tempurature: +5 ~ +35°C a) tempurature: +25 ±2°C b) humidity: 45 - 85% b) humidity: 60 - 70% c) pressure: 860-1060 mbar c) pressure: 860-1060 mbar
page date
5 of 5
11/12/2007
PACKAGING
很抱歉,暂时无法提供与“CPE-120”相匹配的价格&库存,您可以联系我们找货
