CPE-350
CPE-350
    CUIDEVICES
    BUZZER PIEZO 12V 41.8MM CHASSIS
CPE-350 数据手册
page date 1 of 5 11/12/2007 PART NUMBER: CPE-350 DESCRIPTION: piezo audio indicators SPECIFICATONS operating frequency operating voltage range current consumption sound pressure level rated voltage tone operating tempurature storage tempurature dimensions weight material terminal RoHS 2.8 ± 0.5 KHz 3 ~ 28 V DC 7 mA max. at 12 V DC 85 db min. at 30 cm/12 V DC 12 V DC continuous -30 ~ +85° C -40 ~ +95° C Ø41.8 x H16.0 mm 14.6 g max. ABS UL-94 1/16” high heat (black) wire type yes APPEARANCE DRAWING tolerance: ±0.5 units: mm 5.0 3.4 (2 PLCS) UL1007 LF 24AWG 5.0 2.0 black red 140.0 5.0 41.8 50.0 60.0 16.0 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 phone fax page date 2 of 5 11/12/2007 PART NUMBER: CPE-350 DESCRIPTION: piezo audio indicators MEASUREMENT METHOD S.P.L. Measuring Circuit Mic: RION S.P.L. meter UC30 or equivalent S.G.: Hewlett Packard 33120A function gernerator or equivalent CURRENT CONSUMPTION/SOUND PRESSURE LEVEL 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 phone fax page date 3 of 5 11/12/2007 PART NUMBER: CPE-350 DESCRIPTION: piezo audio indicators MECHANICAL CHARACTERISTICS item solderability test condition Stripped wires are immersed in rosin for 5 seconds and then immersed in solder bath of 270 ±5°C for 3 ±1 seconds. The pull force shall be applied to lead wire: Horizontal 3.0N for 30 seconds Vertical 2.0N for 30 seconds The buzzer shall be measured after applying a vibration amplitude of 1.5 mm with 10 to 55 Hz band of vibration frequency to each of the 3 perpendicular directions for 2 hours. The part will be dropped from a height of 75 cm onto a 40 mm thick wooden board 3 times in 3 axes (X, Y, Z) for a total of 9 drops. evaluation standard 90% min. of the lead terminals will be wet with solder (except the edge of the terminal). No damage or cutting off. The value of oscillation frequency/current consumption should be ±10% of the initial measurements. The SPL should be within ±10dB compared with the initial measurement. lead wire pull strength vibration drop test ENVIRONMENT TEST item high temp. test low temp. test humidity test temp. cycle test test condition After being placed in a chamber at +95°C for 240 hours. After being placed in a chamber at -40°C for 240 hours. After being placed in a chamber at +40°C and 90±5% relative humidity for 240 hours. The part shall be subjected to 5 cycles. One cycle will consist of: +95 +25 +25 evaluation standard -40 The buzzer will be measured after being placed at +25°C for 4 hours. The value of the oscillation frequency/current consumption should be ±10% compared to the initial measurements. The SPL should be within ±10dB compared to the initial measurements. 0.5hr 0.5hr 0.25 0.5hr 0.5hr 0.5hr 0.25 3hours 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 phone fax page date 4 of 5 11/12/2007 PART NUMBER: CPE-350 DESCRIPTION: piezo audio indicators RELIABILITY TEST item operating (life test) test condition 1. Continuous life test: The part will be subjected to 48 hours of continuous operation at +70°C with rated voltage applied. 2. Intermittent life test: A duty cycle of 1 minute on, 1 minutes off, a minimum of 5,000 times at room temp (+25 ±2°C) with rated voltage applied. evaluation standard The buzzer will be measured after being placed at +25°C for 4 hours. The value of the oscillation frequency/current consumption should be ±10% compared to the initial measurements. The SPL should be within ±10dB compared to the initial measurements. TEST CONDITIONS standard test condition judgement test condition a) tempurature: +5 ~ +35°C a) tempurature: +25 ±2°C b) humidity: 45 - 85% b) humidity: 60 - 70% c) pressure: 860-1060 mbar c) pressure: 860-1060 mbar 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 phone fax page date 5 of 5 11/12/2007 PART NUMBER: CPE-350 DESCRIPTION: piezo audio indicators PACKAGING 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 phone fax
CPE-350 价格&库存
很抱歉,暂时无法提供与“CPE-350”相匹配的价格&库存,您可以联系我们找货
