CPE-350A
CPE-350A
    CUIDEVICES
    BUZZER PIEZO 12V 41.8MM CHASSIS
CPE-350A 数据手册
page date 1 of 5 11/12/2007 PART NUMBER: CPE-350A DESCRIPTION: piezo audio indicators SPECIFICATONS operating frequency operating voltage range current consumption sound pressure level rated voltage tone operating tempurature storage tempurature dimensions weight material terminal RoHS 2.8 ± 0.5 KHz 3 ~ 20 V DC 12 mA max. at 12 V DC 92 db min. at 30 cm/12 V DC 12 V DC continuous -30 ~ +85° C -40 ~ +95° C Ø41.8 x H16.0 mm 14.6 g max. ABS UL-94 1/16” high heat (black) wire type yes APPEARANCE DRAWING tolerance: ±0.5 units: mm 5.0 3.4 (2 PLCS) UL1007 LF 24AWG 5.0 2.0 black red 140.0 5.0 41.8 50.0 60.0 16.0 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 phone fax page date 2 of 5 11/12/2007 PART NUMBER: CPE-350A DESCRIPTION: piezo audio indicators MEASUREMENT METHOD S.P.L. Measuring Circuit Mic: RION S.P.L. meter UC30 or equivalent S.G.: Hewlett Packard 33120A function gernerator or equivalent MECHANICAL CHARACTERISTICS item solderability test condition Stripped wires are immersed in rosin for 5 seconds and then immersed in solder bath of 270 ±5°C for 3 ±1 seconds. The pull force shall be applied to lead wire: Horizontal 3.0N for 30 seconds Vertical 2.0N for 30 seconds The buzzer shall be measured after applying a vibration amplitude of 1.5 mm with 10 to 55 Hz band of vibration frequency to each of the 3 perpendicular directions for 2 hours. The part will be dropped from a height of 75 cm onto a 40 mm thick wooden board 3 times in 3 axes (X, Y, Z) for a total of 9 drops. evaluation standard 90% min. of the lead terminals will be wet with solder (except the edge of the terminal). No damage or cutting off. The value of oscillation frequency/current consumption should be ±10% of the initial measurements. The SPL should be within ±10dB compared with the initial measurement. lead wire pull strength vibration drop test 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 phone fax page date 3 of 5 11/12/2007 PART NUMBER: CPE-350A DESCRIPTION: piezo audio indicators ENVIRONMENT TEST item high temp. test low temp. test humidity test temp. cycle test test condition After being placed in a chamber at +95°C for 240 hours. After being placed in a chamber at -40°C for 240 hours. After being placed in a chamber at +40°C and 90±5% relative humidity for 240 hours. The part shall be subjected to 5 cycles. One cycle will consist of: +95 +25 +25 evaluation standard -40 The buzzer will be measured after being placed at +25°C for 4 hours. The value of the oscillation frequency/current consumption should be ±10% compared to the initial measurements. The SPL should be within ±10dB compared to the initial measurements. 0.5hr 0.5hr 0.25 0.5hr 0.5hr 0.5hr 0.25 3hours RELIABILITY TEST item operating (life test) test condition 1. Continuous life test: The part will be subjected to 48 hours of continuous operation at +70°C with rated voltage applied. 2. Intermittent life test: A duty cycle of 1 minute on, 1 minutes off, a minimum of 5,000 times at room temp (+25 ±2°C) with rated voltage applied. evaluation standard The buzzer will be measured after being placed at +25°C for 4 hours. The value of the oscillation frequency/current consumption should be ±10% compared to the initial measurements. The SPL should be within ±10dB compared to the initial measurements. TEST CONDITIONS standard test condition judgement test condition a) tempurature: +5 ~ +35°C a) tempurature: +25 ±2°C b) humidity: 45 - 85% b) humidity: 60 - 70% c) pressure: 860-1060 mbar c) pressure: 860-1060 mbar 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 phone fax page date 4 of 5 11/12/2007 PART NUMBER: CPE-350A DESCRIPTION: piezo audio indicators PACKAGING 20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fax 503.612.2383 phone fax
CPE-350A 价格&库存
很抱歉,暂时无法提供与“CPE-350A”相匹配的价格&库存,您可以联系我们找货
