1/3
VIBLSD1-SIP Series DC-DC Converter
Rev. 12-2005
Description
Designed to convert fixed voltages into an isolated regulated voltage, the VIBLSD1-SIP series is well suited for providing boardmount local supplies in a wide range of applications, including mixed analog/digital circuits, test & measurement equip., process/machine controls, datacom/telecom fields, etc...
Features
·Isolated 1 W output ·Regulated ·High efficiency to 79% ·Single voltage output ·Small footprint ·SIP package style ·Industry standard pinout ·UL94-V0 package ·No heatsink required ·1K Vdc isolation ·Temperature range: -40°C~+85°C ·No external component required ·Low cost
Model Number VIBLSD1-S5-S5-SIP VIBLSD1-S5-S9-SIP VIBLSD1-S5-S12-SIP VIBLSD1-S5-S15-SIP VIBLSD1-S12-S5-SIP VIBLSD1-S12-S9-SIP VIBLSD1-S12-S12-SIP VIBLSD1-S12-S15-SIP VIBLSD1-S24-S5-SIP VIBLSD1-S24-S9-SIP VIBLSD1-S24-S12-SIP VIBLSD1-S24-S15-SIP
Input Voltage Nominal Range 5 Vdc 4.75~5.25 Vdc 5 Vdc 4.75~5.25 Vdc 5 Vdc 4.75~5.25 Vdc 5 Vdc 4.75~5.25 Vdc 12 Vdc 11.4~12.6 Vdc 12 Vdc 11.4~12.6 Vdc 12 Vdc 11.4~12.6 Vdc 12 Vdc 11.4~12.6 Vdc 24 Vdc 22.8~25.2 Vdc 24 Vdc 22.8~25.2 Vdc 24 Vdc 22.8~25.2 Vdc 24 Vdc 22.8~25.2 Vdc
Output Voltage 5 Vdc 9 Vdc 12 Vdc 15 Vdc 5 Vdc 9 Vdc 12 Vdc 15 Vdc 5 Vdc 9 Vdc 12 Vdc 15 Vdc
Output Current Max. Min. 150 mA 15 mA 111 mA 12 mA 83 mA 9 mA 67 mA 7 mA 150 mA 15 mA 111 mA 12 mA 83 mA 9 mA 67 mA 7 mA 150 mA 15 mA 111 mA 12 mA 83 mA 9 mA 67 mA 7 mA
Efficiency 69% 70% 71% 72% 69% 71% 72% 72% 70% 72% 73% 73%
Package Style SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP
Note: 1. All specifications measured at TA=25°C, humidity
VIBLSD1-S12-S15-SIP 价格&库存
很抱歉,暂时无法提供与“VIBLSD1-S12-S15-SIP”相匹配的价格&库存,您可以联系我们找货
