VSBU-120 Single Output Switching Power Supply
Rev 12-2006
Features
·Universal Input Voltage 90-264 VAC, 130-370 VDC, 47-63 Hz ·Internal EMI filter ·Input connector mates with Molex housing 09-50-3051 and Molex 2478 and 2578 series crimp terminal ·Output connector mates with Molex housing 09-50-3131 and Molex 2478 and 2578 series crimp terminal ·Input Surge current, over voltage and over load protection ·Power factor correction ·Power fail detect (optional) ·Class I Insulation ·Size : 3” x 5” x 1.28”(1U) ·Two Year Warranty
M odel Number VSBU-120-3.3 VSBU-120-5 VSBU-120-7.5 VSBU-120-9 VSBU-120-12 VSBU-120-15 VSBU-120-18 VSBU-120-24 VSBU-120-30 VSBU-120-36 VSBU-120-48
Output Voltage 3~5 VDC 5~6 VDC 6~9 VDC 9~11 VDC 11~13 VDC 13~16 VDC 16~21 VDC 21~27 VDC 27~33 VDC 33~40 VDC 40~50 VDC
Preset Voltage 1 3.3 VDC 5 VDC 7.5 VDC 9 VDC 12 VDC 15 VDC 18 VDC 24 30 36 48 VDC VDC VDC VDC
Output Current 2 22.00~20.00 A 22.00~18.33 A 19.16~12.77 A 13.33~10.90 A 10.90~9.23 A 9.23~7.50 A 7.50~5.71 A 5.71~4.44 A 4.44~3.63 A 3.63~3.00 A 3.00~2.40 A
Total Regulation 5% 5% 5% 4% 3% 3% 2% 2% 2% 2% 2%
Max Output Power 100 W 110 W 115 W 120 W 120 W 120 W 120 W 120 120 120 120 W W W W
Notes:
1 Customer must specify output voltage. 2 Output current is limited by output power.
V-Infinity, LLC, 20050 SW 112th Ave., Tualatin, OR 97062
www.v-infinity.com
1-866-372-1258
Rev 12-2006
Electrical Characteristics
Parameter Input Voltage Input Frequency P ower Factor Correction Output Power Range Input Current (low line) Input Current (high line) Low Line Inrush Current High Line Inrush Current Efficiency Line Regulation Load Regulation Over Voltage Protection Over Current Protection Transient Response Hold-Up Time Start up time Ripple & Noise (Peak to Peak) Safety Ground Leakage Current Temperature Coefficient Test Conditions Min. 90 130 47 0.95 0 Typ. Max. 264 370 63 1.0 120 1.7 1.0 15 30 88 1 5 132 150 4 1 0.2 0.4 2 1 0.75 0.04 Unit VAC VDC Hz W A A A A % % % % % mS mS S % mA %/°C
Full load at 90~260VAC at 90 to 264 VAC Full load at 115VAC Full load at 230VAC Full load, 25°C, cool start, at 115VAC Full load, 25°C, cool start, at 230VAC Full load, at 230VAC Full load at 230VAC
0.97
70
12 26 80 0.5 3
112 110 Full load to Half load, at 100VAC Full load, at 110VAC Full load, at 100VAC Full load, at 90VAC Full load, at 240VAC All output 16 0.3
-0.04
Environmental
Parameter Operating Temperature Storage Temperature Relative Humidity Derating Test Conditions Min. Typ. 0 -40 5 Derate linearly from 100% load at 50°C to 50% load at 70°C Max. 70 85 95 Unit °C °C %
Safety Specifications
P arameter Dielectric withstanding voltage Dielectric withstanding voltage Isolation resistance EMI requirements for CISPR-22 EMI requirements for FCC part-15 Test Conditions Primary to secondary Primary to ground Test voltage=500VDC at 220VAC at 110 VAC Min. 4242 2121 50 B B Typ. Max. Unit VDC VDC MΩ Class Class
V-Infinity reserves the right to make changes to its products or to discontinue any product or service without notice, and to advise customers to verify the most up-to-date product information before placing orders. V-Infinity assumes no liability or responsibility for customer’s applications using V-Infinity products other than repair or replacing (at V-I’s option) V-Infinity products not meeting V-I’s published specifications. Nothing will be covered outside of standard product warranty.
www.v-infinity.com
1-866-372-1258
Rev 12-2006
Mechanical Specifications
27.6 1.087 0.5
M3XP0.5(MOUNTING HOLES)X4
40.0 1.575 0.5
20.3 0.799 0.5
127.0 5.000 0.5 5.5 0.217 0.5 115.6 4.551 0.5 5.7 0.224 0.5 33.6 1.323 0.5
76.2 3.000 0.5 65.3 2.571 0.5
14.2 0.560 0.5 DC OUTPUT (OPTIONAL) 76.2 3.000 0.5
L N G
10.9 0.429 0.5
AC INPUT
4.0(MOUNTING HOLES)X4
3.0 MAX
30.8 1.213 0.5
20.3 0.799 0.5
27.6 1.087 0.5
Pin 1 Model
VSBU-120-XX
2
3
4
5
6
7
8
9 10 11 12
13
(optional)
OUT OUT OUT OUT OUT OUT COM COM COMCOM COM COM PFD
www.v-infinity.com
1-866-372-1258
很抱歉,暂时无法提供与“VSBU-120-12”相匹配的价格&库存,您可以联系我们找货
