LS02-1A85-S-500W
LS02-1A85-S-500W
    STANDEX-MEDER(斯丹麦德)
    Liquid Level Sensor Switch (Single Float) SPST-NO Output Free Hanging
LS02-1A85-S-500W 数据手册
Europe: +49 / 7731 8399 0 USA: Asia: +1 / 508 295 0771 +852 / 2955 1682 | Email: info@meder.com | Email: salesusa@meder.com | Email: salesasia@meder.com Item No.: 9523851054 Item: LS02-1A85-S-500W stainless steel Special Product Data Contact rating Switching voltage Carry current Switching current Sensor-resistance Breakdown voltage Insulation Voltage Material of float Housing material LS Sealing compound Conditions not to exceed their individual max.'s Min Typ Max Unit DC or Peak AC DC or Peak AC DC or Peak AC measured with 40% overdrive Case/Contact stainless steel stainless steel Polyurethan Environmental data Operating temperature Operating temperature Storage temperature Safety class Conditions cable not moved cable moved DIN EN 60529 Min Typ Max Unit IP68 Cable specification Cable type Cable material Cross section Conditions Min Typ round cable PVC 0,25 sq-mm Max Unit General data Mounting advice Tightening torque Conditions Min Typ Max Unit over 5m cable, a resistor is recommended. Modifications in the sense of technical progress are reserved Designed at: Last Change at: 26.01.10 05.03.10 Designed by: Last Change by: WKOVACS WKOVACS Approval at: Approval at: 01.02.11 Approval by: Approval by: DKUECHLER Version: 03
LS02-1A85-S-500W 价格&库存
很抱歉,暂时无法提供与“LS02-1A85-S-500W”相匹配的价格&库存,您可以联系我们找货
