VUO 25
Three Phase Rectifier Bridge
IdAVM = 25 A VRRM = 1200-1800 V
VRSM V 600 1200 1400 1600 1800
VRRM V 600 1200 1400 1600 1800
Type VUO 25-06NO8 VUO 25-12NO8 VUO 25-14NO8 VUO 25-16NO8 VUO 25-18NO8
Symbol IdAV IdAVM IFSM
Test Conditions TC = 85°C, module TC = 63°C, module TVJ = 45°C; VR = 0 TVJ = TVJM VR = 0 t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine
Maximum Ratings 20 25 380 400 360 400 725 750 650 650 -40...+150 150 -40...+150 A A A A A A A2s A2s A2s A2s °C °C °C V~ V~ Nm lb.in. g
Features
q q q q q q
Package with ¼" fast-on terminals Isolation voltage 3000 V~ Planar passivated chips Blocking voltage up to 1800 V Low forward voltage drop UL registered E 72873
I2t
TVJ = 45°C VR = 0 TVJ = TVJM VR = 0
Applications
q q q q
TVJ TVJM Tstg VISOL Md Weight 50/60 Hz, RMS IISOL £ 1 mA Mounting torque typ. t = 1 min t=1s (M5) (10-32 UNF)
Supplies for DC power equipment Input rectifiers for PWM inverter Battery DC power supplies Field supply for DC motors
2500 3000 2 ± 10 % 18 ± 10 % 22
Advantages
q q q
Easy to mount with one screw Space and weight savings Improved temperature and power cycling
Symbol IR VF VT0 rT RthJC RthJH dS dA a
Test Conditions TVJ = 25°C; TVJ = TVJM; IF = 150 A; VR = VRRM VR = VRRM TVJ = 25°C
Characteristic Values £ £ £ 0.3 5.0 2.2 0.85 12 9.3 1.55 10.2 1.7 12.7 9.4 50 mA mA V V mW K/W K/W K/W K/W mm mm m/s2
Dimensions in mm (1 mm = 0.0394")
For power-loss calculations only per diode; DC current per module per diode; DC current per module Creeping distance on surface Creepage distance in air Max. allowable acceleration
Data according to DIN IEC 60747 and refer to a single diode unless otherwise stated. IXYS reserves the right to change limits, test conditions and dimensions.
© 2000 IXYS All rights reserved
1-2
VUO 25
I 2t
Fig. 1 Forward current versus voltage drop per diode
Fig. 2 Surge overload current per diode IFSM: Crest value. t: duration
Fig. 3 I2t versus time (1-10 ms) per diode
Fig. 4 Power dissipation versus direct output current and ambient temperature
Fig. 5 Maximum forward current at case temperature
Constants for ZthJC calculation: i 1 2 3 4 Rthi (K/W) 0.194 0.556 2.25 6.3 ti (s) 0.024 0.07 5.8 8.5
Constants for ZthJK calculation: i 1 2 3 4 5 Rthi (K/W) 0.194 0.556 2.25 6.3 0.9 ti (s) 0.024 0.07 5.8 8.5 28.0
Fig. 6 Transient thermal impedance per diode © 2000 IXYS All rights reserved
2-2
很抱歉,暂时无法提供与“VUO25-18NO8”相匹配的价格&库存,您可以联系我们找货
