VBE 20
Single Phase Rectifier Bridge
with Fast Recovery Epitaxial Diodes (FRED)
IdAV = 20 A VRRM = 2000 V trr = 70 ns
1 VRSM V 2000 VRRM V 2000 Type 10 6 5
1
5
VBE 20-20NO1
10 6
Symbol IdAV IFSM Conditions TC = 65°C, module TVJ = 45°C; VR = 0 TVJ = TVJM VR = 0 I2dt TVJ = 45°C VR = 0 TVJ = TVJM VR = 0 TVJ TVJM Tstg VISOL Md Weight 50/60 Hz, RMS t = 1 min IISOL £ 1 mA t=1s Mounting torque (M5) (10-32UNF) typ. t = 10 ms (50 Hz), sine t = 10 ms (50 Hz), sine t = 10 ms (50 Hz), sine t = 10 ms (50 Hz), sine Maximum Ratings 20 75 65 28 21 -40...+150 150 -40...+125 3000 3600 2 - 2.5 18 - 22 35 A A A A2s A2s °C °C °C V~ V~ Nm lb.in. g
Features Package with DCB ceramic base plate Isolation voltage 3600 V~ Planar passivated chips Leads suitable for PC board soldering Creeping and creepage-distance fulfil UL 508/CSA 22.2NO14 and VDE 0160 requirements Epoxy meets UL94V-O UL listing applied for
q q q q q q q
Applications Supplies for DC power equipment Input rectifiers for PWM inverter Output filter for PWM inverter
q q q
Advantages Reduced EMI/RFI Easy to mount with two screws Space and weight savings Improved temperature and power cycling
q q q q
Dimensions in mm (1 mm = 0.0394")
Symbol IR VF VT0 rT RthJC RthCH IRM trr dS dA a Conditions VR = VRRM VR = 0.8 VRRM IF = 12 A TVJ = 25°C TVJ = 125°C TVJ = 25°C Characteristic Values typ. max 4 0.75 7 5.41 3.3 93 1.7 0.3 IF = 12 A, -diF/dt = 100 A/ms VR = 540 V, L £ 0.05 mH, TVJ = 100°C IF = 1 A; -di/dt = 100 A/ms; VR = 30 V, TVJ = 25°C Creeping distance on surface Creepage distance in air Max. allowable acceleration 9 70 12 90 12.7 9.4 50 mA mA V V mW K/W K/W A ns mm mm m/s2
030
For power-loss calculations only per diode, DC
Data according to IEC 60747 and refer to a single diode unless otherwise stated.
© 2000 IXYS All rights reserved
1-1
很抱歉,暂时无法提供与“VBE20-20NO1”相匹配的价格&库存,您可以联系我们找货
