VBO55-14NO7
VBO55-14NO7
    IXYSCORPORATION
    FO-T-A
    DIODE BRIDGE 1400V 55A FO-T-A
VBO55-14NO7 数据手册
VBO 55 Single Phase Rectifier Bridge Preliminary data VRSM V 900 1300 1500 1700 1900 Symbol V 800 1200 1400 1600 1800 VBO 55-08NO7 VBO 55-12NO7 VBO 55-14NO7 VBO 55-16NO7 VBO 55-18NO7 Maximum Ratings 55 t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine 750 820 600 700 2800 2820 2200 2250 -40...+150 150 -40...+125 50/60 Hz, RMS IISOL £ 1 mA t = 1 min t=1s 2500 3000 5 ± 15 % 44 ± 15 % 110 A A A A A A2s A2s A2s A2s °C °C °C V~ V~ Nm lb.in. g VRRM Types IdAV = 55 A VRRM = 800-1600 V Test Conditions Features • • • • • Package with copper base plate Isolation voltage 3000 V~ Planar passivated chips Low forward voltage drop 1/4" fast-on power terminals IdAV xTC = 100°C, module IFSM TVJ = 45°C; VR = 0 TVJ = TVJM VR = 0 I2t TVJ = 45°C VR = 0 TVJ = TVJM VR = 0 TVJ TVJM Tstg VISOL Md Weight Applications • • • • Supplies for DC power equipment Input rectifiers for PWM inverter Battery DC power supplies Field supply for DC motors Advantages • Easy to mount with two screws • Space and weight savings • Improved temperature and power cycling capability • Small and light weight Mounting torque (M5) (10-32 UNF) typ. Symbol IR VF VT0 rT RthJC RthJK dS dA a Test Conditions VR = VRRM; VR = VRRM; IF = 150 A; TVJ = 25°C TVJ = TVJM TVJ = 25°C Characteristic Values £ £ £ 0.5 10 1.6 0.8 6 1.3 0.325 1.6 0.4 16.1 7.5 50 mA mA V V mW K/W K/W K/W K/W mm mm m/s2 Dimensions in mm (1 mm = 0.0394") For power-loss calculations only TVJ = TVJM per diode; DC current per module per diode, DC current per module Creeping distance on surface Creepage distance in air Max. allowable acceleration © 2000 IXYS All rights reserved 1-1 024 Data according to IEC 60747 refer to a single diode unless otherwise stated x for resistive load at bridge output. IXYS reserves the right to change limits, test conditions and dimensions.
VBO55-14NO7 价格&库存
很抱歉,暂时无法提供与“VBO55-14NO7”相匹配的价格&库存,您可以联系我们找货
