VBO65-18NO7
VBO65-18NO7
    IXYSCORPORATION
    FO-T-A
    DIODE BRIDGE 1800V 65A FO-T-A
VBO65-18NO7 数据手册
VBO 65 Single Phase Rectifier Bridge Preliminary data VRSM V 900 1300 1500 1700 1900 Symbol IdAV ¬ IFSM VRRM V 800 1200 1400 1600 1800 VBO 65-08NO7 VBO 65-12NO7 VBO 65-14NO7 VBO 65-16NO7 VBO 65-18NO7 Maximum Ratings 65 1000 1100 700 750 5000 5000 2450 2330 -40...+150 150 -40...+125 50/60 Hz, RMS IISOL ≤ 1 mA t = 1 min t=1s 2500 3000 5 ± 15 % 44 ± 15 % 110 A A A A A A2s A2s A2s A2s °C °C °C V~ V~ Nm lb.in. g Types IdAV = 65 A VRRM = 800-1600 V Test Conditions TC = 100°C, module TVJ = 45°C; VR = 0 TVJ = TVJM VR = 0 t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine Features • • • • • Package with copper base plate Isolation voltage 3000 V~ Planar passivated chips Low forward voltage drop 1/4" fast-on power terminals I2t TVJ = 45°C VR = 0 TVJ = TVJM VR = 0 Applications • • • • Supplies for DC power equipment Input rectifiers for PWM inverter Battery DC power supplies Field supply for DC motors TVJ TVJM Tstg VISOL Md Weight Symbol IR VF VT0 rT RthJC RthJK dS dA a Advantages • Easy to mount with two screws • Space and weight savings • Improved temperature and power cycling capability • Small and light weight Dimensions in mm (1 mm = 0.0394") Mounting torque (M5) (10-32 UNF) typ. Test Conditions VR = VRRM; VR = VRRM; IF = 150 A; TVJ = 25°C TVJ = TVJM TVJ = 25°C Characteristic Values ≤ ≤ ≤ 0.5 10 1.4 0.8 5 1.12 0.28 1.5 0.375 16.1 7.5 50 mA mA V V mΩ K/W K/W K/W K/W mm mm m/s2 For power-loss calculations only TVJ = TVJM per diode; DC current per module per diode, DC current per module Creeping distance on surface Creepage distance in air Max. allowable acceleration F4 - 20 © 2000 IXYS All rights reserved 024 Data according to IEC 60747 refer to a single diode unless otherwise stated ¬ for resistive load at bridge output. IXYS reserves the right to change limits, test conditions and dimensions.
VBO65-18NO7 价格&库存
很抱歉,暂时无法提供与“VBO65-18NO7”相匹配的价格&库存,您可以联系我们找货
