VBO88-18NO7
VBO88-18NO7
    IXYSCORPORATION
    ECO-PAC2
    DIODE BRIDGE 1800V 95A ECO-PAC2
VBO88-18NO7 数据手册
VBO 88 Single Phase Rectifier Bridge in ECO-PAC 2 Preliminary data VRSM V 900 1300 1500 1700 1900 VRRM V 800 1200 1400 1600 1800 VBO 88-08NO7 VBO 88-12NO7 VBO 88-14NO7 VBO 88-16NO7 VBO 88-18NO7 Types PS16 IdAV = 92 A VRRM = 800-1800 V ~L 9 ~ K10 EG 1 Pin arangement see outlines B3 Maximum Ratings 92 900 990 770 850 4050 4050 2950 2950 -40...+150 150 -40...+125 A A A A A A2 s A2 s A2 s A2 s °C °C °C V~ V~ Nm lb.in. g Features • Package with DCB ceramic base plate • Isolation voltage 3000 V~ • Planar passivated chips • Low forward voltage drop • Leads suitable for PC board soldering Applications • • • • Supplies for DC power equipment Input rectifiers for PWM inverter Battery DC power supplies Field supply for DC motors Symbol IdAV ① IFSM Conditions TC = 100°C, module TVJ = 45°C; VR = 0 TVJ = TVJM VR = 0 t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine t = 10 ms (50 Hz), sine t = 8.3 ms (60 Hz), sine I2t TVJ = 45°C VR = 0 TVJ = TVJM VR = 0 TVJ TVJM Tstg VISOL Md Weight 50/60 Hz, RMS IISOL ≤ 1 mA t = 1 min t=1s Advantages • Easy to mount with two screws • Space and weight savings • Improved temperature and power cycling capability • Small and light weight Dimensions in mm (1 mm = 0.0394") 2500 3000 1.5 - 2 14 - 18 22 Mounting torque (M4) typ. Symbol IR VF VT0 rT RthJC RthJH dS dA a Conditions VR = VRRM; VR = VRRM; IF = 200 A; TVJ = 25°C TVJ = TVJM TVJ = 25°C Characteristic Values ≤ ≤ ≤ 0.5 5 1.75 0.8 4 0.85 0.212 1.15 0.288 11.2 9.7 50 mA mA V V mΩ K/W K/W K/W K/W mm mm m/s2 For power-loss calculations only per diode; DC current per module per diode, DC current (typ.) per module (typ.) Creeping distance on surface Creepage distance in air Max. allowable acceleration Data according to IEC 60747 refer to a single diode unless otherwise stated ① for resistive load at bridge output. IXYS reserves the right to change limits, test conditions and dimensions. © 2004 IXYS All rights reserved 1-1 420
VBO88-18NO7 价格&库存
很抱歉,暂时无法提供与“VBO88-18NO7”相匹配的价格&库存,您可以联系我们找货
