rev. page page date date 1 of 10
04/2011
PART NUMBER: VHB75W
DESCRIPTION: half-brick dc-dc converter
description
The VHB75W series of DC-DC converters are designed for high reliability applications, featuring over-temperature protection, over-current protection. The wide 4:1 input range (9-36V or 18-75V) is very useful to stabilize an input source like batteries in various discharging and charging conditions. Additionally, high efficiency, fast response, tight regulations, remote sense and remote On/Off control make these converters very useful in many applications.
features
·37.5-75W isolated output ·Efficiency to 85% ·300 kHz switching frequency ·regulated output ·continuous short circuit protection ·industry standard half-brick size ·remote on/off ·over-temperature protection ·over-current protection
M ODEL
VHB75W-Q24-S3R3 VHB75W-Q24-S5 VHB75W-Q24-S12 VHB75W-Q24-S15 VHB75W-Q24-S24 VHB75W-Q24-S48 VHB75W-Q48-S3R3 VHB75W-Q48-S5 VHB75W-Q48-S12 VHB75W-Q48-S15 VHB75W-Q48-S24 VHB75W-Q48-S48
notes:
input voltage nominal range (V dc) (V dc)
output voltage (V dc)
output current 1 (A)
input current no load 2 full load 2 (mA) (mA)
efficiency typ. 3 (%)
24 24 24 24 24 24 48 48 48 48 48 48
9.0~36.0 9.0~36.0 9.0~36.0 9.0~36.0 9.0~36.0 9.0~36.0 18.0~75.0 18.0~75.0 18.0~75.0 18.0~75.0 18.0~75.0 18.0~75.0
3.3 5 12 15 24 48 3.3 5 12 15 24 48
15 15 6.25 5 3.12 1.56 15 15 6.25 5 3.12 1.56
50 50 50 50 50 50 50 50 50 50 50 50
2611 3811 3765 3720 3720 3811 1320 1905 1860 1860 1860 1860
79 82 83 84 84 82 80 83 84 85 85 84
1. see output derating (page 4) 2. input currents are measured at nominal input voltage 3. efficiency is measured at nominal line, full load
I NPUT
parameter input voltage range under voltage lockout conditions/description min 9 18 nom 24 48 8.8 8 17 16 max 36 75 units V dc V dc V dc V dc V dc V dc
remote on/off control 4 input filter
notes:
24 Vin power up 24 Vin power down 48 Vin power up 48 Vin power down section 15 in the application notes PI type
4. add suffix “N” to the model number for negative logic on/off control
*V-Infinity reserves the right to make changes to its products or to discontinue any product or service without notice, and to advise customers to verify the most up-todate product information before placing orders. V-Infinity assumes no liability or responsibility for customer’s applications using V-Infinity products other than repair or replacing (at V-I’s option) V-Infinity products not meeting V-I’s published specifications. Nothing will be covered outside of standard product warranty.
20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax
www.v-infinity.com
page date
2 of 10
04/2011
PART NUMBER: VHB75W
OUTPUT
parameter voltage accuracy transient response external trim adj. range ripple & noise (20MHz BW) conditions/description 25% step load change 3.3V, 5V 12V& 15V 24V 48V temperature coefficient short circuit protection continuous line regulation 5 load regulation 6 over voltage protection trip range, % Vo nom. over current protection % nominal output current ±0.03 ±0.2 ±0.2 140 160 min nom max ±1
很抱歉,暂时无法提供与“VHB75W-Q24-S48”相匹配的价格&库存,您可以联系我们找货
